Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 11-01-2012, 00:18   #1 (permalink)
Member: 1514899
Thanks Meter: 49
Htc Wildfire s touch screen not working
Hi all,
I have Htc Wildfire s which had a cracked glass.
Touch screen was working but was damaged.
I replaced the Glass and now the touch screen doesn't work.
Not responding to touch.
Otherwise phone turns on ok.
I bought another touch screen revision 3 and still not working.
I also made a hard reset but it's the same.
Why the touch screen doesn't work? Althought I tried 2 touch screens.
What is the solution?
Best Regards
Old 11-01-2012, 00:30   #2 (permalink)
reserve's Avatar
Member: 521
Thanks Meter: 69
Exclamation w2,w3
Originally Posted by worldwideunlock View Post
Hi all,
Best Regards
this phone has two types of touch w2 and w3
shall be adequate to touch version works
Best Regards
Old 11-01-2012, 00:37   #3 (permalink)
Member: 50306
Thanks Meter: 49
you can try doing calibration. https://www.google.ee/webhp?sourceid...w=1366&bih=643
Old 11-01-2012, 01:45   #4 (permalink)
Member: 1514899
Thanks Meter: 49
Best Regards
The one I have is revision 3, or version 3 and this one Im trying
but no joy.
Any other ideas? I'll make a picture of what is the original touch screen.
Old 11-01-2012, 02:02   #5 (permalink)
Member: 1514899
Thanks Meter: 49
Originally Posted by cesarq View Post
Calibration doesn't work.
It says Update Fail.
Old 11-01-2012, 03:08   #6 (permalink)
Member: 1514899
Thanks Meter: 49
Sorry for multiply posting but How to identify the proper version of the touch screen?
I get confused now with revision numbers. I got both for revision 3 and that's what says at the back of the ribbon for the cracked touch screen and the new ones.
Old 11-02-2012, 22:53   #7 (permalink)
Member: 1514899
Thanks Meter: 49
Hi,
Just refreshing the thread.
Can anybody help me with this Htc Wildfire S digitizer?
I can't upload the picture of the back ribbon hence it's to small and hard to see.
At the back of the ribbon it says Rev 3, and the cracked one also has Rev 3.
Touch screen not responding.
I tried Hard Reset and also tried a reset with the micro sim - No joy.
Would you know what is the reason for Touch not working?
The cracked screen worked perfectly fine before opening the phone.
Thanks in advance
Old 11-02-2012, 22:54   #8 (permalink)
The Repair Shop's Avatar
Member: 307549
Thanks Meter: 187
New faulty screen maybes?
Old 11-02-2012, 23:18   #9 (permalink)
Member: 1514899
Thanks Meter: 49
Are you sure?
I try to press harder, sqeeze the screen and it is almost responding and sliding slightly, but a little bit. Maybe there is a gap between the screen and the digitizer, maybe that is the problem?
Old 11-02-2012, 23:22   #10 (permalink)
reserve's Avatar
Member: 521
Thanks Meter: 69
Arrow more info...
Are you sure?
There is not much philosophy can only be a touch or in hardware in question
what are you up to now has changed on that phone touch w2, w3 version or?
give a little more information to my brother to help you if little information das
more info
Old 11-02-2012, 23:36   #11 (permalink)
Member: 1514899
Thanks Meter: 49
more info
The Touch glass is version 3 (rev 3).
The one before that is cracked is also version 3 (rev 3).
The screen doesnt respond to touch.
I pressed harder and it started to respond, but only a little bit but not responding now again. The thing on the screen to slide down to Unlock it started to work but now won't slide down anymore.
I know that it should work fine but it doesn't, although I tried 2 touch screens. Im really getting sick of this phone.
Old 11-02-2012, 23:49   #12 (permalink)
reserve's Avatar
Member: 521
Thanks Meter: 69
problem
That phone is normally a problem with regard to touch personally, I hate doing
The hardware in question is a flex slot or an EMI filter for touch and perhaps a framework could be
good luck
try new software...##
2------
HTC Wildfire Calibration
Wildfre S Touch Screen Calibration instructions.
WARNING: ALL YOUR PERSONAL DATA WILL BE LOST SO PLEASE BACKUP ANY IMPORTANT INFORMATION PRIOR TO THIS PROCEDURE
1. Please download the zip file named; "CalibrateWildfire.zip" at the end of this page.
2. Unzip the file into a folder
3. Copy the files into the root of your memory card (Do not place them in a folder)
4. Insert the memory card into your phone
5. Switch off the phone
6. With the phone switched off keep hold of the 'VOLUME DOWN' button and press the 'POWER' button once
7. Wait 10 seconds until screens displays "Get OEMSBL time out! ........... Press VOLDN to exit".
8. PRESS Volume Down button once
9. The screen will diplay "Vol-Dn=> DIAG" in red writing
10. PRESS Volume Down button once
11. At this point the digitizer will be calibrated. Let the process complete.
12. Once complete a screen will appear with the heading in blue "MAL SERVICE HDIAG 1.00"
13. You can now remove the battery and switch on the phone as normal and it should work fine.
NOTE:
- ALL PERSONAL DATA FROM PHONE MEMORY WILL BE ERASED.
- If the process is not working then the files have not been copied or the steps have not been followed correctly.
- This calibration software is ONLY for the HTC Wildfire phone and will not work on anything else.
Old 11-03-2012, 00:03   #13 (permalink)
Member: 1514899
Thanks Meter: 49
good luck
2------
NOTE:
I did try that but it said FAILED!
Old 11-03-2012, 00:06   #14 (permalink)
reserve's Avatar
Member: 521
Thanks Meter: 69
Red face good luck
I really do not know what could be more thing that came to mind I told you already
I'm sorry
good luck
The Following User Says Thank You to reserve For This Useful Post:
Old 11-03-2012, 19:32   #15 (permalink)
Member: 1514899
Thanks Meter: 49
I tried the cracked touch screen today and it doesn't work either.
I bought the inner Lcd.
Hope that will help.
I'll let you know if that resolved the issue.
Thanks for your help.
Page generated in 0.41574 seconds with 7 queries
