HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
05-09-2013, 14:44 | #8 (permalink) |
No Life Poster Join Date: Sep 2002 Location: Portugal
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | You can NOT use RUU from One X+, on normal One X model. Put the phone in bootloader, select fastboot mode, connect phone to pc use adb as usual enter command "fastboot oem readcid" or fastboot getvar cid Will show your phone CID, HTC__*** ... this is important, for you to know which rom you can flash |
05-14-2013, 17:10 | #11 (permalink) |
Member: 15312 Status: Offline Sonork: 100.1576041 Thanks Meter: 1,097 | power off phone completly. Press volume down + power button You will enter in bootloader, now select fastboot using volume buttons and select with power button. Connect usb cable. Use adb and insert commands to reveal your phone CID. CID is important for you to know which ROM you can flash. |
05-16-2013, 18:35 | #13 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Lima - Perú
Member: 598854 Status: Offline Thanks Meter: 141 | In this mode connect it to pc, open CMD , browse to folder where you have adb .exe and fastboot.exe and in command line window type : fastboot oem readcid this commanod will return a result like this. HTC__044 please paste the result here |
11-14-2013, 09:27 | #15 (permalink) |
Junior Member Join Date: Apr 2010
Member: 1288327 Status: Offline Sonork: hassawne Thanks Meter: 0 | (bootloader) version: 0.5 (bootloader) version-bootloader: 2.10.0000 (bootloader) version-baseband: 3.12.38.00.24 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 1.01.401.03 (bootloader) version-misc: PVT SHIP S-ON (bootloader) serialno: HT2CVW300968 (bootloader) imei: 354370050234862 (bootloader) product: evita_utl (bootloader) platform: HBOOT-8960 (bootloader) modelid: PJ8350000 (bootloader) cidnum: HTC__J15 (bootloader) battery-status: good (bootloader) battery-voltage: 4125mV (bootloader) partition-layout: Generic (bootloader) security: on (bootloader) build-mode: SHIP (bootloader) boot-mode: FASTBOOT (bootloader) commitno-bootloader: dirty-b27b8968 (bootloader) hbootpreupdate: 11 (bootloader) gencheckpt: 0 all: Done! |
