HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
03-11-2015, 13:02 | #1 (permalink) |
Junior Member Join Date: May 2011 Location: jordan
Member: 1572129 Status: Offline Thanks Meter: 2 | i need rom for htc one m7 ruu Device Info Security status: S-ON Model Id: PN0711000 Custom Id: HTC__A48 Serial number: FA36PW915848 Product: m7_u IMEI: 354435053050340 Platform: HBOOT-8064 Bootloader ver: 1.57.0000 Baseband ver: 4T.28.3218.04 Cpld verersion: None Microp version: None Main version: 6.09.401.111 Battery Status: good Battery Volt: 4117mV PartitionLayout: Generic Commitno bl: dirty-6d8a0b9b Hbootpreupdate: 11 |
03-11-2015, 13:53 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Kitkat OTA_M7_U_K443_SENSE60_MR_HTC_Europe_6.09.401.111-6.09.401.108_.zip Lollipop OTA_M7_U_L50_SENSE60_MR_HTC_Europe_7.19.401.102-6.09.401.111 Copy to adb folder put yur mob n recovery mode there select update via adb Run below givn cmmds Note: rename the ota.zip as update dnt Change zip extension adb devices adb sideload update.zip |
The Following 2 Users Say Thank You to jamesjerss For This Useful Post: |
03-12-2015, 13:02 | #5 (permalink) |
Member: 1572129 Status: Offline Thanks Meter: 2 | Device Info Security status: S-ON Model Id: PN0711000 Custom Id: HTC__A48 Serial number: FA36PW915848 Product: m7_u IMEI: 354435053050340 Platform: HBOOT-8064 Bootloader ver: 1.57.0000 Baseband ver: 4T.28.3218.04 Cpld verersion: None Microp version: None Main version: 6.09.401.111 Battery Status: good Battery Volt: 4263mV PartitionLayout: Generic Commitno bl: dirty-6d8a0b9b Hbootpreupdate: 11 |
The Following User Says Thank You to ahmad.anabtawi For This Useful Post: |
03-12-2015, 16:31 | #6 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
Check second post Download lollipop frm it rename it as update.zip dnt change zip extension copy to adb folder put yur recovery mode there select update via adb run below givn cmmds adb devices adb sideload update.zip Br james | |
The Following User Says Thank You to jamesjerss For This Useful Post: |
04-28-2015, 10:11 | #7 (permalink) |
Insane Poster Join Date: Jun 2008 Location: visakhapatnam
Member: 786547 Status: Offline Sonork: 100.1645883 Thanks Meter: 8 | Model : M7_U IMEI : 3544 Build : 6.13.707.107 CID : HTC__038 HBoot : 1.57.0000 MID : PN0711000 Security : ON Region : ASIA_INDIA i need This RUU.exe can u plz provide |
04-28-2015, 10:30 | #8 (permalink) | |
Download M7 U asia wwe .zip flash via fastboot Sent from my XT1068 using Tapatalk | |
04-30-2015, 06:24 | #9 (permalink) |
Member: 786547 Status: Offline Sonork: 100.1645883 Thanks Meter: 8 | bro james i got this error after flashing in fastboot.. D:\HTC>fastboot flash zip firmware.zip sending 'zip'... (1201376 KB) OKAY sending time = 138.438 secs writing 'zip'... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) Read zipped android_info fail FAIL99 unknown fail FAILED (remote: 99 unknown fail) Execution time is 139(s) |
04-30-2015, 06:26 | #10 (permalink) |
Member: 786547 Status: Offline Sonork: 100.1645883 Thanks Meter: 8 | I tried through sideloader but device not going in adb mode , i flashed recovery twrp and unlocked the bootloader but still can't flash the rom as i get the error above... Plz give some suggestion |
