HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
01-05-2015, 11:28 | #1 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2319841 Status: Offline Thanks Meter: 0 | Install Recovery without Adb? Device Incredible S. i tried flashing recovery. but : FAILED (remote: signature verify fail) (bootloader) version-bootloader: 1.13.0000 (bootloader) version-baseband: 3805.06.03.03_M (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 2.00.000.0 (bootloader) product: vivo (bootloader) platform: HBOOT-7630 (bootloader) modelid: PG3213000 (bootloader) cidnum: HTC__J15 |
01-05-2015, 11:57 | #2 (permalink) | ||
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Anyway, if Fastboot are working, try push via fastboot a "recovery philz_touch", instead of Twrp. - Dowload right "philz_touch" for you model Push with these command: Quote:
BR allumts | ||
01-05-2015, 13:14 | #3 (permalink) | |
Member: 2319841 Status: Offline Thanks Meter: 0 | Quote:
01-06-2015, 07:24 | #4 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | remote: signature verify fail Its mean the rom you try its not for your phone,can you post here roms which you try ? In case you flashing zip in fastboot and flashing directly without booting your phone into RUU mode you will get this error even if rom is for your phone and correct cid. Correct way of flashing rom with fastboot is "fastboot oem rebootRUU" now wait phone to come in blackdisplay. "fastboot flash zip filename.zip" now flashing should be start. In case file size is higher then 1GB or something,fastboot cannot flash it,you need RUU. |
The Following User Says Thank You to Rahul_Bhutani For This Useful Post: |
01-08-2015, 21:11 | #5 (permalink) | |
RUU_Vivo_Gingerbread_S_HTC_WWE_2.30.405.1_Radio_20 .2808.30.085AU_3805.06.03.03_M_release_199308_sign ed RUU_Vivo_Gingerbread_S_HTC_ARA_2.30.415.1_Radio_20 .2808.30.085AU_3805.06.03.03_M_release_199399_sign ed but i need : RUU_Vivo_Gingerbread_S_HTC-GCC_2.00.000.0_Radio_20.2808.30.085AU_3805.06.03.0 3_M ? | |
01-08-2015, 22:05 | #6 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: Dhaka, Bangladesh.
Member: 552244 Status: Offline Sonork: 100.1578827 Thanks Meter: 180 | Quote:
