Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 02-26-2015, 19:25   #16 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
@cale,
and wath you want do with only this Diag file if havent Java Card?, lol you can find, just use Search button or google, (both are you big friends), any Diag file you want, but w/o Micro Sd Card with JAVA SCRIPT you cannot do nothingh....
allumts
Old 02-26-2015, 19:33   #17 (permalink)
allumts's Avatar
Member: 1564612
Originally Posted by cellsolution View Post
Have you done any ????? Y Cable is very common thing Bro but such models don't have Diag files to s-off too it has tool to be run from PC & Y cable don't sync with PC.
You not must need any PC for use Original Java Card, just use HD7 cable or how all know this the Y cable, one side receive the Micro Sd Card reader, ona side have Usb for Charger and last side have Microusb cable for connect in the phone, no must need any pc and any Syncronie.
Who have selled you these FAKE procedure w/o any Diag file with only one .txt file and 2 EXE is very idiot of reseller, and in this case is permisse say IDIOTE of the reseller, becouse this isn't ORIGINAL Java Card but only one "Home development" and i have very big doubt you can work with this type of thingh.
allumts
Old 02-26-2015, 21:20   #18 (permalink)
cale's Avatar
Member: 10742
Thanks Meter: 13
Sir i have java card. but there is no desire 510, 610, 200 diags. so i just ask if you can upload here?!
thanks
Old 02-26-2015, 21:54   #19 (permalink)
allumts's Avatar
Member: 1564612
thanks
and i've just answere:
Or contact you reseller and ask to him.
Old 02-26-2015, 22:23   #20 (permalink)
cale's Avatar
Member: 10742
Thanks Meter: 13
Anyone else has diag files for desire 510, 816, 610, 200.. ??? Does those models be unlocked via java card??
Thanks
Old 02-26-2015, 22:41   #21 (permalink)
allumts's Avatar
Member: 1564612
Thanks
Java Card NOT unlock HTC but get S-OFF and Supercid (00000000), for unlock network use easy server by small credits and have unlocked in few minuts.
allumts
Old 03-24-2015, 00:19   #22 (permalink)
Member: 191258
Thanks Meter: 36
htc 610 need procedure to unlock via htc java card
i have htc java card
need procedure how to unlock htc 610 via htc java card.
user manual..
downlod files from pack add in pack to java card and..
no information how to unlock htc desire 610..
I need information that files should be put on the card to unlock the HTC 610..
Old 03-24-2015, 20:11   #23 (permalink)
allumts's Avatar
Member: 1564612
user manual..
Contact you reseller and ask you...isn't good only for to take you money...if is serious reseller...but i think that in this last mounths all you are purchasing these Java Card in BAD reseller..becouse you aren't the unique that not know nothingh about and post in forum....
Often..or more good always....purchase with 10$ more give you good result...
allumts
Old 03-25-2015, 23:15   #24 (permalink)
Member: 191258
Thanks Meter: 36
you're right no one provides support for the Java card and I asked the reseller and he does not know how it works for some models there is a solution that has the files on the web but for HTC desire 610 is nowhere where to find a solution to unlock..
best regards bro...
Old 03-25-2015, 23:50   #25 (permalink)
cale's Avatar
Member: 10742
Thanks Meter: 13
You can unlock 610 without diag files. Only java card
Old 03-26-2015, 12:40   #26 (permalink)
allumts's Avatar
Member: 1564612
best regards bro...
No bro, isn't true this....all depend where you and others are purchasing these "Java Card"... (i'm curios of know where purchase and who is this Bad reseller)....i have my Java Cards with all New Diag files M8 inclusing and other easy method for use this w/o any Diag File for ALL HTC....but if you reseller or the developer not give you and all other Right info How To use.... these are the result... i've posted also CLEAR how to use the HD7 cable, the Y cable...more of you are thinking that must need the PC, it's FALSE...any PC you have need for use Java Card...
you can use this in any part where have an electrical outlet+female battery charger for receive Usb side of HD7 cable...no more trouble...
allumts
Old 03-28-2015, 07:41   #27 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
Model you are asking diag for are protected,even you can't do it if you have java card and diag both,it will ask you to sync with software.
Old 03-28-2015, 22:19   #28 (permalink)
allumts's Avatar
Member: 1564612
But Java Card NOT unlock the phone....only any old Htc can be....the purpose of Java Card is to get S-OFF and can write Supercid....then any ROM/RUU....for UNLOCK must need Good Tool or Box or charger in server for chip price...just a few $...NOT to buy Java Card for Unlock Htc phone...are only lost money....
If you search good or use search button
@Rahul_Bhutani, (good friend) have developed for FREE many tool that are very useful for many purposes....just use Search button....
allumts
The Following User Says Thank You to allumts For This Useful Post:
Old 03-29-2015, 07:49   #29 (permalink)
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
allumts
If you have diag you can unlock phone ( Gsm only which ask for PIN ) by clean S58 data,once you done it will not ask you code anymore.
But if you have phone like M8 (Sprint) or M7 (Sprint) it will remain locked after clean S58.
The Following 2 Users Say Thank You to Rahul_Bhutani For This Useful Post:
Old 03-29-2015, 08:08   #30 (permalink)
kzafquiel's Avatar
Member: 1318721
Thanks Meter: 166
so I understand the java card is only to facilitate the s-off and super cid
I think the best project that was Mr. raskal
with xtc clip since towards gold card, s-off,super cid and clear s58data
I hope they continue with a new similar project, since all dongles or box for htc only thing they have is read htc and unlockboot loader
nothing we can do
since at xda developers are the recovery, cwm, TWRP.
be interesting to some dongle or box that has a better support and be automated
Page generated in 0.26478 seconds with 9 queries
