HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
06-03-2015, 13:07 | #78 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Not All HTC w/o Slot Sd Card accept Simlock Menu....only with Y cable read in automatic these txt file and no need any Pc or CMD command just connect one side of Y cable in External charger of wall... never i've used PC for S-Offed HTC..only with this M9 just becouse was in front pc...but can gain S-OFF also w/o any Pc... |
07-08-2015, 09:45 | #81 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @ElBerryKM13 Java Card NOT UNLOCK any HTC, is for S-OFF, SUPERCID itc... If you want unlock w/o spent to much money buy one code in server...(who support this model), or Unique other way at the moment is the MOD EDIT...this Unlock ecc...and working perfect if set correct BR allumts Last edited by Rahul_Bhutani; 07-09-2015 at 08:35. Reason: Please do not use box/dongle names in this section |
10-12-2015, 19:09 | #82 (permalink) |
Freak Poster Join Date: Jan 2008 Location: phone care
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | m8 s-off Dear brother i buy s-off java card but when i insert this card in card sloote in m8 and hit hboot its cheking some file say no img file or wrong file etc and come again hboot.i open this card in my pc there is no any name m8 its show only m7 and some other file..i create txt file and rename sf.txt and copy in java card in txt file i wrote 0 but still same no s-off .when i use comman its show error C:\adb>Fastboot OEM writesecureflag 0 usage: fastboot [ <option> ] <command> commands: update <filename> reflash device from update.zip flashall flash boot + recovery + system flash <partition> [ <filename> ] write a file to a flash partition erase <partition> erase a flash partition format <partition> format a flash partition getvar <variable> display a bootloader variable boot <kernel> [ <ramdisk> ] download and boot kernel flash:raw boot <kernel> [ <ramdisk> ] create bootimage and flash it devices list all connected devices continue continue with autoboot reboot reboot device normally reboot-bootloader reboot device into bootloader help show this help message options: -w erase userdata and cache (and format if supported by partition type) -u do not first erase partition before formatting -s <specific device> specify device serial number or path to device port -l with "devices", lists device paths -p <product> specify product name -c <cmdline> override kernel commandline -i <vendor id> specify a custom USB vendor id -b <base_addr> specify a custom kernel base address. default: 0x10000000 -n <page size> specify the nand page size. default: 2048 -S <size>[K|M|G] automatically sparse files greater th an size. 0 to disable |
10-12-2015, 19:55 | #83 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | When have created sf.txt file with 0 inside Just execute in cmd the command "fastboot oem writesecureflag 0" (w/o " ) Not "C:\adb>Fastboot OEM writesecureflag 0 Make suse that phone is in "Usb fastboot mode" BR allumts |
The Following User Says Thank You to allumts For This Useful Post: |
10-13-2015, 08:41 | #85 (permalink) |
Member: 667941 Status: Offline Sonork: 100.1611812 Thanks Meter: 61 | C:\adb>fastboot oem writesecureflag 0 ... (bootloader) SecuritySDInit: counter = 2 (bootloader) m8_init_sd, SD card already power on (bootloader) [SPEW] GPIO 0 status is 0 (bootloader) sdhw_7xxx_open: id=0 (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) sdcc_init_memory_device done (bootloader) SD clock freq = 19MHz.... (bootloader) GPLL0 is enabled (bootloader) clock_update_cfg_sd is done (bootloader) sd clock set done (bootloader) [Tuxera][Error] No exFAT partition found (bootloader) writesecureflag: KeyCard remain count 1856 (bootloader) PID:272 (bootloader) Start Verify: 3 (bootloader) [PGFS] partition_update_pgfs: pg1fs_security OKAY [ 1.255s] finished. total time: 1.255s |
10-27-2015, 20:50 | #86 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside MTK Age: 38
Member: 248182 Status: Offline Thanks Meter: 786 | Java Card app SMART_IO error Hi, When i open SMART_IO to set the card to 0 value, I got error "The managed card could not be installed. contact the card provider for more information" Please see the attached screen short for your reference. Kindly let me know how to solve this error. Regards Bluffmaster |
10-28-2015, 01:37 | #87 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | NEVER touch this file "SMART_IO_CREDIT", this is info file and there are credit for working you Java Card, if have damaged this file you are now w/o credit and you reseller NOT charge nothing. Why not Ask what you want do instead of damage this card? BR allumts |
