Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 11-01-2019, 08:43   #1 (permalink)
freshwhite's Avatar
Member: 87204
Thanks Meter: 146
k2_ul HTC__001 (HTC-WWE) RUU
I NEED RUU FOR k2_ul HTC__001 (HTC-WWE) RUU
PLEASE HELP
Device Info
Security status:S-ON
Model Id:PL8010000
Custom Id:HTC__001 (HTC-WWE)
Serial number:HT312TP05178
Product:k2_ul
IMEI:352803050564575
Platform:HBOOT-8930
Bootloader ver:2.00.0000
Baseband ver:1.14.40a.00.01_2
Cpld verersion:None
Microp version:None
Main version:2.14.401.2
Battery Status:good
Battery Volt:3825mV
PartitionLayout:Generic
Commitno bl:dirty-55528ab0937fdd014e0ac3b530f9b2af4122dd94
Hbootpreupdate:11
Old 11-01-2019, 19:09   #2 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
PLEASE HELP
Device Info
Model Id:PL8010000
Product:k2_ul
Platform:HBOOT-8930
Cpld verersion:None
Microp version:None
Battery Status:good
Battery Volt:3825mV
Hbootpreupdate:11
Try to flash OTA
TA: 2.14.401.2 - 1.17.401.5 (379 MB)
How to flash:
Suggest: Disable Fastboot on Smartphone from "Settings" ==> "Power"
Download the OTA update ZIP File.
Copy OTA ZIP File on Smartphone. (Internal Storage or SD Card).
Boot to Recovery, from the PC command line (adb reboot bootloader) OR with button combinations on the phone. (Power + Vol. Down)
In Bootloader Select Recovery.
Wait until you see the picture.
Simultaneously Press the "Power" Button and "Volume Up", Until you see the Stock Recovery "Android System Recovery <3e>".
Select "apply from phone storage" OR "apply from sd card".
Select the zip file that you copied from the PC.
Do the Install, should take 10 minutes.
Tell it to Reboot.
If it brings you back to that dark screen with the battery icon, reboot again (Press Power + Vol. Up).
It will then reboot regularly, and say "Android is upgrading... optimizing app xxx of yyy."
Credit: Xda
__________________
__________________
Rules are for the obedience of fools and the guidance of wise men.
Best Regards,
Shamim
Page generated in 0.53664 seconds with 8 queries
