HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
12-17-2014, 14:14 | #16 (permalink) | |
No Life Poster Join Date: May 2008 Location: P@Ki$t@n
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | Quote:
12-17-2014, 14:26 | #17 (permalink) |
Super Moderator Join Date: Jan 2006 Location: [Egypt, Alex]
Member: 224065 Status: Offline Sonork: 100.1577902 Thanks Meter: 7,931 | Fastboot getvar all otherwise this thread will continue for ever And post all info here so i can give u correct firmware without causing hboot downgrade Sent from my iPhone using Tapatalk |
12-18-2014, 18:53 | #20 (permalink) |
Member: 777415 Status: Offline Sonork: 1589702 Thanks Meter: 1,420 | IF 3.28.4017 Then Download This File Firmware If 3.28.401.9 Then Download This File Firmware How To Flash This File a. Reboot phone into fastboot b. Copy the FW file to your fastboot folder on your PC (if you don't have fastboot in your system path) c. Rename the FW file firmware.zip (NOT firmware.zip.zip) d. Type: fastboot oem rebootRUU and wait for device to reboot e. Type: fastboot flash zip firmware.zip and wait for process to complete. Although you don't have to do this twice as you used to do with RUU ZIPs, it's STRONGLY recommended that you run this command a second time after the first has finished to make sure it 'takes' properly f. Type: fastboot reboot The phone will now reboot 0. All done! |
The Following User Says Thank You to ..::Rizwan::.. For This Useful Post: |
