HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
12-27-2015, 05:37 | #1 (permalink) |
Junior Member Join Date: Dec 2015
Member: 2506208 Status: Offline Thanks Meter: 1 | Nead 820 a51_ul RUU Please for HTC 820n RUU_A51_UL_L50_DESIRE_SENSE60_MR_HTC_Europe_2.10.4 01.2 i wipe my Date accidentally and have : No OS Phone inf. product: a51_ul modelid: 0PFJ40000 cidnum: HTC__J15 version-main: 2.10.401.2 security: on Please Please Please Please Help |
The Following User Says Thank You to ba77ary For This Useful Post: |
12-27-2015, 07:59 | #2 (permalink) |
No Life Poster Join Date: Jan 2014 Location: GM7
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | OTA_A51_UL_L50_DESIRE_SENSE60_MR_HTC_Europe_2.10.4 01.2_R-1.29.401.5_release_453051.zip Don't forget to press Thanks Button Read The Rules Careful HERE Br M@SUD |
12-27-2015, 15:28 | #3 (permalink) |
Member: 2506208 Status: Offline Thanks Meter: 1 | thank you gsm_masud7 but .. thank you gsm_masud7 but this is OTA ? i want RUU i have this file but i dont know how to install i try via fastboot but didn't recognize i try install as a update from recovery but recovery freez on ! without options like uptade from sd card . please help me my device dead since 3 days only fast boot the problem i did advance wipe in twrp in have No OS then i return the stock recovery |
12-27-2015, 16:15 | #4 (permalink) |
Member: 2506208 Status: Offline Thanks Meter: 1 | i tray to put that file OTA_A51_UL_L50_DESIRE_SENSE60_MR_HTC_Europe on sd card and update and rename to update . zip and update from recovery sd menu but have this err : fraile to map the file .. i think the priblem is there are no os to update must be RUU to be currect via fastboot |
12-27-2015, 16:43 | #5 (permalink) |
Member: 2102992 Status: Offline Sonork: 100.1626305 Thanks Meter: 2,763 | try this way here is special fastboot Driver ,zip file flashing guide http://forum.gsmhosting.com/vbb/f485...guide-1952646/ Note : Relock bootloader then try Don't forget to press Thanks Button Read The Rules Careful HERE Br M@SUD |
The Following User Says Thank You to gsm_masud7 For This Useful Post: |
12-27-2015, 19:17 | #6 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Relock bootloader 1st Extract firmware.zip from ota flash it via fastboot fastboot oem rebootRUU fastboot flash zip firmware.zip fastboot reboot And then update the ful ota via sdcard or sideload via adb |
12-27-2015, 21:11 | #7 (permalink) |
Member: 2506208 Status: Offline Thanks Meter: 1 | thank you so much jamesjerss every thing done ok till to the last one : update the ful ota : from sd card of recovery : blutoth . apk not excist from sideload : phone return to recuvery menu and pc err from hbot :rename to 0PFJIMG and put in sd and go to fastboot ; take 5 min loading , checking , then press power to restart ; and nothing change ? |
12-27-2015, 21:40 | #8 (permalink) |
Member: 2506208 Status: Offline Thanks Meter: 1 | try sideload via twrp : when swipe to start sideload : device disconnect from pc and have this massage in twrp : unkown fail system: 'datamedia when press cancel : phone connect to pc |
12-28-2015, 00:12 | #9 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
You need this ful file to recover yur device then. search for it 0PFJIMG_A51_UL_L50_DESIRE_SENSE60_MR_HTC_Europe_2. 10.401.4_Radio_01 .01.010_U10305041_08.01.50512_release_458582_signe d.zip | |
The Following User Says Thank You to jamesjerss For This Useful Post: |
06-13-2016, 01:56 | #14 (permalink) | |
Junior Member Join Date: Feb 2015
Member: 2345975 Status: Offline Sonork: 100.1662691 Thanks Meter: 2 | Quote:
i suceeded flash this file..................... | |
06-22-2016, 15:33 | #15 (permalink) |
Insane Poster Join Date: Aug 2009 Location: maijdee,noakhali Age: 36
Member: 1092147 Status: Offline Sonork: rixonmusic Thanks Meter: 3 | pls help me..... i try to flash but.... now red light blinking only.... C:\Users\Mobile Gallery\Desktop\New folder (2)>fastboot oem rebootRUU ... (bootloader) Start Verify: 3 OKAY Execution time is 1(s) C:\Users\Mobile Gallery\Desktop\New folder (2)>fastboot flash zip firmware.zip sending 'zip'... (48986 KB) OKAY sending time = 4.196 secs writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... (bootloader) checking hboot version... (bootloader) start image[hboot] unzipping for pre-update check... (bootloader) total_image_number=8 (bootloader) start image[hboot] flushing... (bootloader) signature checking... (bootloader) [RUU]WP,hboot,0 (bootloader) [RUU]WP,hboot,99 (bootloader) [RUU]WP,hboot,100 (bootloader) ...... Successful (bootloader) current_image_number=0 (bootloader) start image[sbl1] unzipping for pre-update... (bootloader) start image[sbl1] flushing... (bootloader) signature checking... (bootloader) ...... Successful (bootloader) current_image_number=1 (bootloader) current_image_number=2 (bootloader) current_image_number=3 (bootloader) start image[rpm] unzipping for pre-update... (bootloader) start image[rpm] flushing... (bootloader) signature checking... (bootloader) ...... Successful (bootloader) current_image_number=4 (bootloader) start image[tz] unzipping for pre-update... (bootloader) start image[tz] flushing... (bootloader) signature checking... (bootloader) ...... Successful (bootloader) current_image_number=5 (bootloader) start image[hyp] unzipping for pre-update... (bootloader) start image[hyp] flushing... (bootloader) [RUU]WP,hyp,0 (bootloader) [RUU]WP,hyp,100 (bootloader) ...... Successful (bootloader) current_image_number=6 (bootloader) current_image_number=7 FAIL90 hboot pre-update! please flush image again immediately FAILED (remote: 90 hboot pre-update! please flush image again immediately) For "hboot-preupdate" response, restart the same procedure for device CC53VYC002 39... < waiting for device > |
