HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
10-12-2017, 16:57 | #1 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2694036 Status: Offline Thanks Meter: 2 | Need correct ROM (bootloader) version: 0.5a (bootloader) version-bootloader: 1.39.0000 (bootloader) version-baseband: 5.1204.162.29 (bootloader) version-cpld: None (bootloader) version-microp: None (bootloader) version-main: 3.14.401.31 (bootloader) serialno: xxxxxxxxxxxxx (bootloader) imei: xxxxxxxxxxxxxxxx (bootloader) product: endeavoru (bootloader) platform: HBOOT-T30S (bootloader) modelid: PJ4610000 (bootloader) cidnum: 11111111 (bootloader) battery-status: low (bootloader) battery-voltage: 3560mV (bootloader) devpower: 7 (bootloader) partition-layout: None (bootloader) security: off (bootloader) build-mode: SHIP (bootloader) boot-mode: RUU (bootloader) commitno-bootloader: None (bootloader) hbootpreupdate: 2 (bootloader) gencheckpt: 0 all: Done! |
10-12-2017, 17:08 | #2 (permalink) | |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Quote:
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim | |
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post: |
10-12-2017, 17:20 | #4 (permalink) | |
I Updated For You Official exe! Please Check Again Link and Download That exe.
10-12-2017, 17:24 | #5 (permalink) |
Member: 2694036 Status: Offline Thanks Meter: 2 | thank you I hope this one will work because I tried flashing with xtc 2 clip software and got this error: Starting flash process... found large-zip header, file count: 2117 processing file 1/2117... sending 'zip' (179 KB)... OKAY [ 0.037s] writing 'zip'... (bootloader) shift signature_size for header checking... FAILED (remote: 32 header error) finished. total time: 0.276s Flash process completed. Flash not successfull, reboot will not be done |
10-12-2017, 17:45 | #6 (permalink) |
Member: 2694036 Status: Offline Thanks Meter: 2 | Hi the ROM update utility is saying my phones battery was low so I unplugged my phone and restart the utitliity and it gave me the same error even though my phones unplugged whats wrong |
10-12-2017, 18:28 | #7 (permalink) | |
Most Probably Battery is Low! You Should Charge Battery Before you Run RUU exe.
10-12-2017, 19:05 | #8 (permalink) |
Member: 2694036 Status: Offline Thanks Meter: 2 | the ruu.exe flashed my phone successfully however in the settings it still is stuck on "aeroplane mode is turning off" Please man I have had this phone for months and its still stuck on that |
10-12-2017, 19:37 | #9 (permalink) | |
Read This Thread Very Carefully! https://forum.xda-developers.com/sho....php?t=2009023
