Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 05-09-2015, 09:32   #1 (permalink)
ramcellular's Avatar
Member: 121974
Thanks Meter: 87
need flash file htc 501 603e
D:\D Drive\htc desire update\adb\adb>fastboot getvar all
INFOversion: 0.5
INFOversion-bootloader: 0.76.0000
INFOversion-baseband: N/A
INFOversion-cpld: None
INFOversion-microp: None
INFOversion-main: 1.40.707.7
INFOserialno: HT41VLM00195
INFOimei: 357862050666173
INFOproduct: csndug
INFOplatform: HBOOT-U8520
INFOmodelid: PO0910000
INFOcidnum: HTC__038
INFObattery-status: good
INFObattery-voltage: 3712mV
INFOpartition-layout: Generic
INFOsecurity: on
INFObuild-mode: SHIP
INFOboot-mode: FASTBOOT
INFOcommitno: 5c8000b7
INFOhbootpreupdate: 12
INFOgencheckpt: 0
INFOregion-id: 1
INFObatt_status: good
INFObatt_id: 1
INFObatt_volt: 3722mV
Old 05-09-2015, 09:44   #2 (permalink)
shaikh_shoeb50's Avatar
Member: 1586370
Sonork: 100.1618206
Thanks Meter: 154
INFOversion: 0.5
INFOproduct: csndug
INFOsecurity: on
INFOgencheckpt: 0
INFOregion-id: 1
INFObatt_id: 1
flash with fastboot commands..
rename zip to rom.zip
1) fastboot oem rebootRUU
2) fastboot flash zip rom.zip
https://mega.co.nz/#!QEsWxI4a!Nd4Ohm...EPuLY_GIQ6YzcM
Post result soon...
The Following User Says Thank You to shaikh_shoeb50 For This Useful Post:
Old 05-09-2015, 14:57   #3 (permalink)
Member: 121974
Thanks Meter: 87
bro getting flash error
Old 05-09-2015, 15:44   #4 (permalink)
Member: 121974
Thanks Meter: 87
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
D:\D Drive\htc desire update\adb\adb>fastboot flash zip rom.zip
error: cannot load 'rom.zip'
Old 05-09-2015, 15:48   #5 (permalink)
masterRt1994's Avatar
Member: 2105681
Sonork: Stoped Using...
Thanks Meter: 909
make sure ur file name is rom.zip and file is in same directry.
Old 05-11-2015, 10:30   #6 (permalink)
Member: 121974
Thanks Meter: 87
one of my friend saying
Can't flash new Htc device's with adb
Caus file incrypted
Will have to use mmc
Old 05-11-2015, 15:28   #7 (permalink)
Member: 121974
Thanks Meter: 87
Post result soon...
perfectly done thanks alot bro small modificatin without rename rom.zip done with direct flash file name many many thanks to shaikh_shoeb50
Old 05-26-2015, 06:03   #8 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
How you flash it?
Explain please.
When i try flash phone from SD error:
Main Version is older! Update Fail!
Old 05-26-2015, 07:25   #9 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
When try via "fastboot flash zip rom.zip"
This error: RUU Update Fail!
Old 05-26-2015, 18:52   #10 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
You need higher version firmware yu can not flash old version
Old 05-27-2015, 04:38   #11 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 158
I know about higher version, but all new versions install via OTA.
How may reflash phone. On the screen always: android.com error
Hard reset don't help
Old 07-27-2015, 20:37   #12 (permalink)
Member: 2178545
Thanks Meter: 24
no new flash file till date.. pls upload new files if anyone have.
Old 07-29-2015, 05:17   #13 (permalink)
Member: 2435937
jamesjerss sir can you provide the higher version firmware of htc desire 501
Old 07-29-2015, 10:19   #14 (permalink)
sajidmirza's Avatar
Member: 256461
Sonork: 100.1608049
Thanks Meter: 90
jamesjerss,me too need the higher version firmware of htc desire 501.
flash the lower version 1.40.707.... and now it just hangs on htc logo and four exclamation marks in four corners.
Old 08-16-2015, 14:57   #15 (permalink)
xx0o0xx1's Avatar
Member: 2033150
Thanks Meter: 624
try with this command may work
fastboot flash zip nameofzip.zip " if give error retype the command again "
fastboot reboot-bootloader
Page generated in 0.22993 seconds with 9 queries
