HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
11-14-2014, 12:40 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: IRAN(land of heros) Age: 44
Member: 115172 Status: Offline Thanks Meter: 212 | Need help to find my phone region 9.99.9999.9 Below is my phone information but i'm totally confused coz i can not find appropriate stock official rom for it.It's HTC One SU,Please share ideas if you have any PS: The only official rom i could find is mentioned below.Could it be compatible with mine? Code: PM60IMG_CP2_DTG_JB_45_S_HTCCN_CHS_CMCC_2.14.1403.1_Radio_1.12.w1233p2.014.20_2_release_316570_signed_2_4 Code: dev[1] HC365PP02222 Mode: fastboot Hardware: cp2dtg Manufactory: HTC MID: PM6011000 Device Info Security status: S-ON Model Id: PM6011000 Custom Id: HTCCN704 Serial number: HC365PP02222 Product: cp2dtg IMEI: 353979058xxxxxx Platform: HBOOT-U8500 Bootloader ver: 0.74.0000 Baseband ver: N/A Cpld verersion: None Microp version: None Main version: 9.99.9999.9 Battery Status: good Battery Volt: 3856mV PartitionLayout: Generic Commitno bl: Hbootpreupdate: 12 |
11-14-2014, 12:52 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Should support yur main version oly showing wrong detail just rename the zip as PM60IMG (Dnt change zip extension) Copy rom.zip into adb folder Cnnt yur mob in fastboot mode fastboot devices fastboot oem rebootRUU fastboot flash zip PM60IMG.zip fastboot reboot |
11-14-2014, 13:45 | #3 (permalink) |
Member: 115172 Status: Offline Thanks Meter: 212 | FAILED (remote: 43 main version check fail) Code: C:\And>fastboot devices HC365PP02222 fastboot C:\And>fastboot oem rebootRUU ... (bootloader) [Batt][info] chg_ctrl, mode = 1 (bootloader) [Batt][info] chg_ctrl, link status = 0x0 (bootloader) [Batt][info] chg_ctrl, CH_USBCH_STAT1_REG(0xB02) = 0x80EA507 (bootloader) [Batt][info] chg_ctrl, UsbChOn = 0x1 Inited = 1 OKAY [ 0.075s] finished. total time: 0.075s C:\And>fastboot flash zip PM60IMG.zip sending 'zip' (577095 KB)... OKAY [ 61.748s] writing 'zip'... (bootloader) adopting the signature contained in this image... (bootloader) signature checking... (bootloader) rom parsing start ... (bootloader) rom parsing finish ... (bootloader) zip header checking... (bootloader) zip info parsing... (bootloader) checking model ID... (bootloader) checking custom ID... (bootloader) checking main version... FAILED (remote: 43 main version check fail) finished. total time: 263.289s C:\And> |
11-14-2014, 14:36 | #4 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Hard luck Only way is to recover yur mob using custom rom if i get files i vil post here Last edited by jamesjerss; 11-14-2014 at 14:42. |
The Following User Says Thank You to jamesjerss For This Useful Post: |
11-14-2014, 16:00 | #5 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Unlock bootloader Flash cwm recovery Here Download Rom Download Here Flash rom via custom recovery Before flash take backup yur current rom using cwm recovery wipe data,cache,system,delvik cache flash the rom after flash if yu face bootloop extract boot.img from rom flash via fastboot fastboot flash boot boot.img |
11-22-2014, 12:13 | #7 (permalink) | |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Quote:
Den flash the Cwm recovery If not wrk Download this Rom Extract boot.img frm this rom flash it via fastboot Den flash the cwm recovery Br james | |
11-23-2014, 10:13 | #11 (permalink) |
Member: 115172 Status: Offline Thanks Meter: 212 | At last i manged to get the ROM and after writing boot.img and recovery that you gave it won't enter recovery.Is there any other recovery for this model please? |
11-23-2014, 10:22 | #12 (permalink) | |
Try this recovery | |
04-24-2015, 08:40 | #14 (permalink) | |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Quote:
Br AzimBahar/ParvezAhmed | |
The Following User Says Thank You to aZimBahar For This Useful Post: |
