HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
07-16-2015, 03:58 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | need help in htc opcv1 unlocking i serch alredy here no found unlock guide so reqwest to all member plz guide how to unlock this handset i uplode some imege here |
02-25-2017, 18:47 | #5 (permalink) |
Insane Poster Join Date: Feb 2010
Member: 1239965 Status: Offline Sonork: Akeiro Thanks Meter: 37 | help me!!! [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886808.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886815.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886825.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886836.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886843.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886854.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886865.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886873.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886892.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886900.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886909.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886921.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886930.jpg[/IMG] [IMG]http://www.************/forum/uploads/monthly_02_2017/post-22276-1487886936.jpg[/IMG] |
02-25-2017, 19:09 | #6 (permalink) |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | @Akeiro What Happened to your phone? PLease Explain here and Post Your Getvar all info. Htc Most of phone free unlock not possible. for unlock you shound need a professional devices. Anyways, You wrote in post only "help me"! Just like this topic no anyone help you. you should write your exact problem in a new thread. Forum Rules in Sticky. Before You post any problem First Read forum Rules |
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post: |
02-25-2017, 19:29 | #7 (permalink) |
Member: 1239965 Status: Offline Sonork: Akeiro Thanks Meter: 37 | I need help to unlock this htc Use xtc2clip for unlock the bootloader, extract to spc, change the cid and more.. Install root explorer, simlockhelperfree, shortcur master, copy the HtcOMADM_SPCS.apk into the phone memory, install a kernel, recovery and root... Use root explorer and rename HTCOMADM_SPCS.apk and HTCOMADM_SPCS.odex to something else (like HTCOMADM_SPCS2.apk and HTCOMADM_SPCS.2odex) from /system/app Directory now copy the HTCOMADM_SPCS.apk attached in this post make sure you have set the permission rw-r-r and reboot.. Open htc on sim unlock helper on your phone it will say htc one device check fail now click the 3 menu dot and click on display sim unlock log then hit the back button it should say Device Verified, now hit start and scroll down to simlock it will freeze for few seconds and then press back button it should be successful reboot Delete the modified HTCOMADM_SPCS.apk and rename the original HTCOMADM_SPCS.apk and HTCOMADM_SPCS.odex to original state which we renamed in previous steps to avoid vdm client stopped error. Open shtorcut master and search the word network, search and open com.android.phone.NetworkModeSelectionActivity, select GSM / WCDMA / LTE Automatic and reboot.... But I can not even raise the signal. I do not know that I can miss to be able to raise the signal.... |
