Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 11-23-2014, 07:46   #1 (permalink)
Member: 1186156
Need help to S-off htc mini
hi
got a htc mini from a friend stuck on fastboot mode, dont know how it get there
***LOCKED***
HBOOT: 2.22.0000
OS: 3.10.502.3
eMMC-boot: 1024MB
jan 29 2014: 19:38:11.0
i tried to unlock the bootloader via htcdev after flashing fastboot flash unlocktoken Unlock_code.bin,nothing happening,no menu pop up,i tried rumrunner no sucess,cant enable the USB debugging mode,so i got errors, tried to flash dat stock rom RUU_M4_UL_JB_50_Cingular_US_1.32.502.3_Radio_1.19. 40d.00.14_10.20.40.4408L_release_333483_signed_2, it gave me usb connection error, plz help me fix the phone
Old 11-23-2014, 10:09   #2 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
1st post yur boot info use this took http://forum.gsmhosting.com/vbb/f485...eased-1789408/
put n fastboot mode run the tool read boot info
james
The Following 2 Users Say Thank You to jamesjerss For This Useful Post:
Old 11-23-2014, 17:14   #3 (permalink)
Member: 1186156
james
thx bro, but i cant get it work,i put my mail account, and my htcdev account too,everytime i tried i get this error sever did not accept user credential...
but the soft detect my phone
Model : M4_UL
IMEI : 356482050088889
Build : 3.10.502.3
CID : CWS__001
HBoot : 2.22.0000
MID : PO5822000
Security : ON
Region : AT&T
Connecting To Mail Server...Connecting To Mail Server...
Old 11-23-2014, 18:15   #4 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Download this AT&T OTA official zip rename the file as update (dnt change extension)
or try this RUU RUU_M4_UL_K44_SENSE60_MR_Cingular_US_4.13.502.3_Ra dio_1.29.40g.00.19_10.32.40.1115L_release_385202_s igned_with_hboot.exe
Boot yur mobile into recovery mode nd select recovery
There select apply update from adb
Cnnt yur device to pc wait for driver installation
Copy the ota zip to adb folder
Run cmmd below given
adb devices
adb sideload update.zip
james
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 11-23-2014, 18:46   #5 (permalink)
Member: 1186156
adb devices
james
the things i cant go nowhere it stuck on fastboot mode, if i go to recovery and press the power button it restart to the fastboot mode, i can only use fastboot command,adb devices dont show nothing,
C:\Users\asus\Desktop\adb>adb devices
List of devices attached
C:\Users\asus\Desktop\adb> but fastboot command give me this
C:\Users\asus\Desktop\adb>fastboot devices
HT385WA01315 fastboot
so it detect the phone
Old 11-23-2014, 19:03   #6 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
OK if revovery mode not gng den download that ruu.
Double click nd run it vil flash yur mobile
or extract firmware zip from OTA zip
flash via fastboot
fastboot oem rebootRUU
fastboot flash zip firmware.zip
after flash firmware.zip check may b yur mob goto recovery
or flash using ruu simply
james
Old 11-24-2014, 00:59   #7 (permalink)
Member: 1186156
flash via fastboot
james
hi
i tried flash via fastboot i get this C:\Users\asus\Desktop\adb>fastboot flash zip firmware.zip
sending 'zip' (37423 KB)... OKAY [ 4.960s]
writing 'zip'... INFOadopting the signature contained in this
i mage...
INFOsignature checking...
FAILED (remote: not allowed)
finished. total time: 9.857s[IMG][/IMG]
Old 11-24-2014, 01:27   #8 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Try that ruu jus cnnt yur mob n fast boot mode run the ruu
its official ruu from At&t
james
Sent from my SM-G900F using Tapatalk
Old 11-25-2014, 19:51   #9 (permalink)
Member: 1186156
T tried, but I'm still getting error 171(USB cable connection) I tried uninstall htc sync, drivers etc... Still getting the error, I tried on Windows xp pc same error, I search over de Internet how to fix Dat error, I tried some but it still giv me hard time...
Old 11-26-2014, 08:09   #10 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
You are directly flashing zip to phone which is wrong way to do this.
First "fastboot oem rebootRUU" after this command once phone reboot in black color display,then use fastboot flash zip "filename.zip".
Try and post result.
Old 11-28-2014, 18:01   #11 (permalink)
Member: 1186156
every time i send the fastboot oem rebootRUU command the phone respond reboot well, but dont stay at the black screen mode so i can use the fastboot flash command to start flashing,the fastboot recovery just come up again
C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot oem rebootRUU
(bootloader) [ERR] Cmd18 polling status timed out, MCI_STATUS: 0x4C2000
(bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2
(bootloader) [SD_HW_ERR] read data fail in CMD18
(bootloader) CMD18: cmd failed
(bootloader) [SD_HW_ERR] SD: Read data fail..
(bootloader) [ERR] partition_read_emmc(876): error 2
(bootloader) Start Verify: 3
(bootloader) [ERR] Cmd25 polling status timed out, MCI_STATUS: 0x4C0000
OKAY [ 0.056s]
finished. total time: 0.057s
OKAY [ 0.052s]
finished. total time: 0.067s
OKAY [ 0.047s]
finished. total time: 0.047s
Old 11-28-2014, 18:46   #12 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
hardware prob Seems lik yur emmc is faulty
james
Old 11-28-2014, 20:17   #13 (permalink)
Member: 1186156
Yeah I think I'm gonna disassembly it to take a look...
Sent from my iPhone using Tapatalk
Page generated in 0.26125 seconds with 8 queries
