HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
11-23-2014, 07:46 | #1 (permalink) |
Junior Member Join Date: Dec 2009 Location: haiti Age: 35
Member: 1186156 Status: Offline Thanks Meter: 0 | Need help to S-off htc mini got a htc mini from a friend stuck on fastboot mode, dont know how it get there ***LOCKED*** HBOOT: 2.22.0000 OS: 3.10.502.3 eMMC-boot: 1024MB jan 29 2014: 19:38:11.0 i tried to unlock the bootloader via htcdev after flashing fastboot flash unlocktoken Unlock_code.bin,nothing happening,no menu pop up,i tried rumrunner no sucess,cant enable the USB debugging mode,so i got errors, tried to flash dat stock rom RUU_M4_UL_JB_50_Cingular_US_1.32.502.3_Radio_1.19. 40d.00.14_10.20.40.4408L_release_333483_signed_2, it gave me usb connection error, plz help me fix the phone |
11-23-2014, 10:09 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | 1st post yur boot info use this took http://forum.gsmhosting.com/vbb/f485...eased-1789408/ put n fastboot mode run the tool read boot info Br james |
The Following 2 Users Say Thank You to jamesjerss For This Useful Post: |
11-23-2014, 17:14 | #3 (permalink) | |
Member: 1186156 Status: Offline Thanks Meter: 0 | Quote:
but the soft detect my phone Model : M4_UL IMEI : 356482050088889 Build : 3.10.502.3 CID : CWS__001 HBoot : 2.22.0000 MID : PO5822000 Security : ON Region : AT&T Connecting To Mail Server...Connecting To Mail Server... Last edited by juniorgourde; 11-23-2014 at 17:24. | |
11-23-2014, 18:15 | #4 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Download this AT&T OTA official zip rename the file as update (dnt change extension) or try this RUU RUU_M4_UL_K44_SENSE60_MR_Cingular_US_4.13.502.3_Ra dio_1.29.40g.00.19_10.32.40.1115L_release_385202_s igned_with_hboot.exe Boot yur mobile into recovery mode nd select recovery There select apply update from adb Cnnt yur device to pc wait for driver installation Copy the ota zip to adb folder Run cmmd below given adb devices adb sideload update.zip Br james |
The Following User Says Thank You to jamesjerss For This Useful Post: |
11-23-2014, 18:46 | #5 (permalink) | |
C:\Users\asus\Desktop\adb>adb devices List of devices attached C:\Users\asus\Desktop\adb> but fastboot command give me this C:\Users\asus\Desktop\adb>fastboot devices HT385WA01315 fastboot so it detect the phone | |
11-23-2014, 19:03 | #6 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | OK if revovery mode not gng den download that ruu. Double click nd run it vil flash yur mobile or extract firmware zip from OTA zip flash via fastboot fastboot oem rebootRUU fastboot flash zip firmware.zip after flash firmware.zip check may b yur mob goto recovery or flash using ruu simply Br james |
11-24-2014, 00:59 | #7 (permalink) | |
i tried flash via fastboot i get this C:\Users\asus\Desktop\adb>fastboot flash zip firmware.zip sending 'zip' (37423 KB)... OKAY [ 4.960s] writing 'zip'... INFOadopting the signature contained in this i mage... INFOsignature checking... FAILED (remote: not allowed) finished. total time: 9.857s[IMG][/IMG] Last edited by juniorgourde; 11-24-2014 at 01:07. | |
11-24-2014, 01:27 | #8 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Try that ruu jus cnnt yur mob n fast boot mode run the ruu its official ruu from At&t Br james Sent from my SM-G900F using Tapatalk |
11-25-2014, 19:51 | #9 (permalink) |
Member: 1186156 Status: Offline Thanks Meter: 0 | T tried, but I'm still getting error 171(USB cable connection) I tried uninstall htc sync, drivers etc... Still getting the error, I tried on Windows xp pc same error, I search over de Internet how to fix Dat error, I tried some but it still giv me hard time... |
11-26-2014, 08:09 | #10 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | You are directly flashing zip to phone which is wrong way to do this. First "fastboot oem rebootRUU" after this command once phone reboot in black color display,then use fastboot flash zip "filename.zip". Try and post result. |
11-28-2014, 18:01 | #11 (permalink) |
Member: 1186156 Status: Offline Thanks Meter: 0 | every time i send the fastboot oem rebootRUU command the phone respond reboot well, but dont stay at the black screen mode so i can use the fastboot flash command to start flashing,the fastboot recovery just come up again C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot oem rebootRUU ... (bootloader) [ERR] Cmd18 polling status timed out, MCI_STATUS: 0x4C2000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [SD_HW_ERR] read data fail in CMD18 (bootloader) CMD18: cmd failed (bootloader) [SD_HW_ERR] SD: Read data fail.. (bootloader) [ERR] partition_read_emmc(876): error 2 (bootloader) Start Verify: 3 (bootloader) [ERR] Cmd25 polling status timed out, MCI_STATUS: 0x4C0000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 OKAY [ 0.056s] finished. total time: 0.057s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot oem rebootRUU ... (bootloader) [ERR] Cmd18 polling status timed out, MCI_STATUS: 0x4C2000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [SD_HW_ERR] read data fail in CMD18 (bootloader) CMD18: cmd failed (bootloader) [SD_HW_ERR] SD: Read data fail.. (bootloader) [ERR] partition_read_emmc(876): error 2 (bootloader) Start Verify: 3 (bootloader) [ERR] Cmd25 polling status timed out, MCI_STATUS: 0x4C0000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 OKAY [ 0.052s] finished. total time: 0.067s C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot oem rebootRUU ... (bootloader) [ERR] Cmd18 polling status timed out, MCI_STATUS: 0x4C2000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 (bootloader) [SD_HW_ERR] read data fail in CMD18 (bootloader) CMD18: cmd failed (bootloader) [SD_HW_ERR] SD: Read data fail.. (bootloader) [ERR] partition_read_emmc(876): error 2 (bootloader) Start Verify: 3 (bootloader) [ERR] Cmd25 polling status timed out, MCI_STATUS: 0x4C0000 (bootloader) [ERR] sdcc_command: sdcc_poll_status error, rc: 2 OKAY [ 0.047s] finished. total time: 0.047s C:\Program Files (x86)\Minimal ADB and Fastboot> |
