Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 12-11-2015, 22:37   #31 (permalink)
ttechno1985's Avatar
Member: 2426327
Sonork: 100.4294967295
Thanks Meter: 70
HTC 816 DUAL
HTC 8126 DUAL PHONE IS SWITCH DURING THE UPDATE THROUGH WIFI.AFTER THAT ONLY I CAN ACCESS RECOVERY MODE .I WILL NOT GET FAST BOOT MODE.HOW CAN FIND OUT ITS CID,
Old 12-11-2015, 22:46   #32 (permalink)
Member: 2426327
Thanks Meter: 70
HTC 816 DUAL
HTC 816 SWITCH OFF WHILE UPDATING THROUGH WIFI . AFTER THAT ONLY CAN ACCESS RECOVERY MOD.I WILL NOT CHECK CID number,main version.now phone cannot switch to fastboot mode.how i can find out its cid version ?
Old 12-15-2015, 07:43   #33 (permalink)
Member: 1013861
Thanks Meter: 3
hii james sir guide how to flash htc 516 via sd
Old 01-08-2016, 09:44   #34 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 569
hello sir one x cid 044 bricked i am using this file
OTA_ENDEAVOR_U_JB_50_S_hTC_Asia_WWE_4.19.707.3-3.14.707.24_release_3346060yp26w70ibi8zm1g
i renamed it as= pg46img
but not working please guide me
Old 01-08-2016, 21:17   #35 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,374
Get full firmware from here http://forum.gsmhosting.com/vbb/f485...wares-1890836/
Guide nd fastboot drivere : http://forum.gsmhosting.com/vbb/f485...guide-1952646/
Old 01-08-2016, 21:20   #36 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,374
Copy file to sdcard hold both vol key +pwr or try vol dwn+pwr.
Old 01-11-2016, 12:19   #37 (permalink)
Member: 136052
Thanks Meter: 75
Reading information...
Using Fastboot mode...
Reading common information
(bootloader) version: 0.5
(bootloader) version-bootloader: 1.44.0000
(bootloader) version-baseband: 4A.15.3250.22
(bootloader) version-cpld: None
(bootloader) version-microp: None
(bootloader) version-main: 1.29.1402.25
(bootloader) version-misc: PVT SHIP S-OFF
(bootloader) serialno: HC39MW900192
(bootloader) imei: 355653777708614
(bootloader) meid: 00000000000000
(bootloader) product: m7_u
(bootloader) platform: HBOOT-8064
(bootloader) modelid: PN071****
(bootloader) cidnum: 11111111
(bootloader) battery-status: good
(bootloader) battery-voltage: 3770mV
(bootloader) partition-layout: Generic
(bootloader) security: off
(bootloader) build-mode: SHIP
(bootloader) boot-mode: RUU
Please help what file i need wright to thease
Old 01-11-2016, 12:47   #38 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,374
Download m7 u europe or asia file
http://forum.gsmhosting.com/vbb/f485...p-ruu-1863513/
Old 01-12-2016, 07:56   #39 (permalink)
Member: 136052
Thanks Meter: 75
if i flash these file
PN07IMG_M7_U_L50_SENSE60_MR_HTC_Europe_7.19.401.12 1_Radio_4T.35.3218.16_10.33Q.1718.01D_release_4303 65_signed_2_4.zip
i haw these error
Starting flash process...
sending 'zip'... (50278 KB) OKAY
writing 'zip'... (bootloader) rom parsing start ...
(bootloader) rom parsing finish ...
(bootloader) zip header checking...
(bootloader) zip info parsing...
Execution time is 3653(ms)
FAIL22 loading zip info fail
FAILED (remote: 22 loading zip info fail)
Flash process completed.
if i flash these
PN07IMG_M7_UL_L50_SENSE60_MR_HTC_Europe_7.19.401.2 _Radio_4T.35.3218.16_10.33Q.1718.01L_release_42179 0_signed.zip
these error too
sending 'zip'... (43286 KB) OKAY
Execution time is 3594(ms)
for these
PN07IMG_M7_U_L50_SENSE60_MR_HTC_WWE_MMR_7.24.1136. 4_Radio_4T.35.3218.16_10.33Q.1718.01D_release_4376 56_signed_2_4.zip
sending 'zip'... (50282 KB) OKAY
Execution time is 7160(ms)
these file 100% work files , and others phones work fine with these
and these phone work with custom rom , bat phone do not HAWED CUSTOM RECOVERY ...
I WONT FLASH ORIGINAL FIRMWARE , bat these nothing happened
if i wright these file with combo boot cable (y cable) i rename these files to PN07IMG.zip
phone write not flash file or flash file wrong after scan in hboot and then nothing
Old 01-14-2016, 10:55   #40 (permalink)
Member: 7700
Thanks Meter: 28
C:\ADB>fastboot flash zip PN07IMG.zip
sending time = 2.906 secs
writing 'zip'... (bootloader) adopting the signature contained in this image...
(bootloader) signature checking...
(bootloader) Read zipped android_info fail
FAILED (status read failed (Too many links))
Execution time is 9(s)
please help sir
Old 01-14-2016, 11:40   #41 (permalink)
Member: 7700
Thanks Meter: 28
i try download again file
PN07IMG_M7_UL_L50_SENSE60_MR_hTC_Asia_HK_7.18.708. 2_Radio_4T.35.3218.29_10.33R.1718.01L_release_4205 59_signed
try to extrack but corrupt
i think thatfile corrupt
Old 01-14-2016, 13:12   #42 (permalink)
Member: 2512501
Failed Reading block 524288
Hello to you
When I use the command fastboot oem rebootRUU, I receive the following errors:
INFOError: Command never completed
Error: Command timeout error
Error: Command completed with errors
1. Why?
2. How can I avoid it?
Thanks in advance
Old 01-14-2016, 19:24   #43 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,374
If unable to reboot yur device into ruu mode then mostly hardware issue friend .
Sent from my XT1068 using Tapatalk
Old 01-15-2016, 00:01   #44 (permalink)
Member: 7700
Thanks Meter: 28
sir, help another link download for this file
Old 01-17-2016, 18:59   #45 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,374
Always check sticky before request
The Following User Says Thank You to jamesjerss For This Useful Post:
Page generated in 0.22401 seconds with 8 queries
