HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
11-01-2019, 08:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: MOROGORO,TANZANIA Age: 45
Member: 87204 Status: Offline Thanks Meter: 146 | k2_ul HTC__001 (HTC-WWE) RUU PLEASE HELP Device Info Security status:S-ON Model Id:PL8010000 Custom Id:HTC__001 (HTC-WWE) Serial number:HT312TP05178 Product:k2_ul IMEI:352803050564575 Platform:HBOOT-8930 Bootloader ver:2.00.0000 Baseband ver:1.14.40a.00.01_2 Cpld verersion:None Microp version:None Main version:2.14.401.2 Battery Status:good Battery Volt:3825mV PartitionLayout:Generic Commitno bl:dirty-55528ab0937fdd014e0ac3b530f9b2af4122dd94 Hbootpreupdate:11 |
11-01-2019, 19:09 | #2 (permalink) | |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Quote:
TA: 2.14.401.2 - 1.17.401.5 (379 MB) How to flash: Suggest: Disable Fastboot on Smartphone from "Settings" ==> "Power" Download the OTA update ZIP File. Copy OTA ZIP File on Smartphone. (Internal Storage or SD Card). Boot to Recovery, from the PC command line (adb reboot bootloader) OR with button combinations on the phone. (Power + Vol. Down) In Bootloader Select Recovery. Wait until you see the picture. Simultaneously Press the "Power" Button and "Volume Up", Until you see the Stock Recovery "Android System Recovery <3e>". Select "apply from phone storage" OR "apply from sd card". Select the zip file that you copied from the PC. Do the Install, should take 10 minutes. Tell it to Reboot. If it brings you back to that dark screen with the battery icon, reboot again (Press Power + Vol. Up). It will then reboot regularly, and say "Android is upgrading... optimizing app xxx of yyy." Credit: Xda
__________________ __________________ Rules are for the obedience of fools and the guidance of wise men. Best Regards, Shamim | |
