[Solved] HTC M9 Phone disabled by EE by Babar Abbasi First of all install latest build of twrp and then root the phone here are partitions we need to wipe/format Code: mmcblk0p60: 01000000 00000200 "absolute" Code: mmcblk0p30: 01600000 00000200 "persist" here is the platform Code: f9824900.sdhci Code: adb shell Code: mke2fs /dev/block/platform/f9824900.sdhci/by-name/persist if you are unable to communicate with phone using twrp you can manually remove base.apk form file manager on twrp goto [/CODE]/data/app/com.absolute.android.agent/base.apk [/CODE]delete base.apk wipe data/freset wipe cache and reboot you will be in manu then trun usb debugging from phone and try to communicate. Good Luck everyone. |
bootloader unlock,terp recovery complete, root complete, all command working but problem not solve, steel disable by EE C:\ADB Fastboot Tool>adb shell ~ # ←[6nmke2fs /dev/block/platform/f9824900.sdhci/by-name/absolute mke2fs /dev/block/platform/f9824900.sdhci/by-name/absolute mke2fs 1.42.9 (28-Dec-2013) Warning: the fs_type small is not defined in mke2fs.conf Discarding device blocks: done Filesystem label= OS type: Linux Block size=4096 (log=2) Fragment size=4096 (log=2) Stride=0 blocks, Stripe width=0 blocks 1024 inodes, 4096 blocks 204 blocks (4.98%) reserved for the super user First data block=0 1 block group 32768 blocks per group, 32768 fragments per group 1024 inodes per group Allocating group tables: done Writing inode tables: done Writing superblocks and filesystem accounting information: done ~ # ←[6ndd if=/dev/zero of=/dev/block/platform/f9824900.sdhci/by-name/absolute dd if=/dev/zero of=/dev/block/platform/f9824900.sdhci/by-name/absolute dd: writing '/dev/block/platform/f9824900.sdhci/by-name/absolute': No space left on device 32769+0 records in 32768+0 records out 16777216 bytes (16.0MB) copied, 1.991531 seconds, 8.0MB/s ~ # ←[6nmke2fs /dev/block/platform/f9824900.sdhci/by-name/persist mke2fs /dev/block/platform/f9824900.sdhci/by-name/persist mke2fs 1.42.9 (28-Dec-2013) Warning: the fs_type small is not defined in mke2fs.conf Discarding device blocks: done Filesystem label= OS type: Linux Block size=4096 (log=2) Fragment size=4096 (log=2) Stride=0 blocks, Stripe width=0 blocks 1408 inodes, 5632 blocks 281 blocks (4.99%) reserved for the super user First data block=0 Maximum filesystem blocks=8388608 1 block group 32768 blocks per group, 32768 fragments per group 1408 inodes per group Allocating group tables: done Writing inode tables: done Writing superblocks and filesystem accounting information: done ~ # ←[6ndd if=/dev/zero of=/dev/block/platform/f9824900.sdhci/by-name/persist dd if=/dev/zero of=/dev/block/platform/f9824900.sdhci/by-name/persist dd: writing '/dev/block/platform/f9824900.sdhci/by-name/persist': No space left on device 45057+0 records in 45056+0 records out 23068672 bytes (22.0MB) copied, 2.660530 seconds, 8.3MB/s ~ # ←[6nexit exit C:\ADB Fastboot Tool> |
did you hard reset the phone right after using these commands ? |
Yes i try hard reset and try this command 2 times but same problem not solve disable by ee problem |
C:\ADB Fastboot Tool>fastboot getvar all < waiting for device > (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) imei: 3572xxxxxxxx (bootloader) version-main: 1.32.61.15 (bootloader) boot-mode: download (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: ORANG001 all: finished. total time: 0.004s C:\ADB Fastboot Tool> try all procedure but can not success, log all commands C:\ADB Fastboot Tool>fastboot getvar all < waiting for device > (bootloader) kernel: lk (bootloader) product: htc_himauhl (bootloader) version: 1.0 (bootloader) imei: 357226064393408 (bootloader) version-main: 1.32.61.15 (bootloader) boot-mode: download (bootloader) version-bootloader: 1.0.0.0000 (bootloader) mid: 0PJA10000 (bootloader) cid: ORANG001 all: finished. total time: 0.004s C:\ADB Fastboot Tool>adb shell ~ # ←[6nmke2fs /dev/block/platform/f9824900.sdhci/by-name/absolute mke2fs /dev/block/platform/f9824900.sdhci/by-name/absolute mke2fs 1.42.9 (28-Dec-2013) Warning: the fs_type small is not defined in mke2fs.conf Discarding device blocks: done Filesystem label= OS type: Linux Block size=4096 (log=2) Fragment size=4096 (log=2) Stride=0 blocks, Stripe width=0 blocks 1024 inodes, 4096 blocks 204 blocks (4.98%) reserved for the super user First data block=0 1 block group 32768 blocks per group, 32768 fragments per group 1024 inodes per group Allocating group tables: done Writing inode tables: done Writing superblocks and filesystem accounting information: done ~ # ←[6ndd if=/dev/zero of=/dev/block/platform/f9824900.sdhci/by-name/absolute dd if=/dev/zero of=/dev/block/platform/f9824900.sdhci/by-name/absolute dd: writing '/dev/block/platform/f9824900.sdhci/by-name/absolute': No space left on device 32769+0 records in 32768+0 records out 16777216 bytes (16.0MB) copied, 1.292194 seconds, 12.4MB/s ~ # ←[6nmke2fs /dev/block/platform/f9824900.sdhci/by-name/persist mke2fs /dev/block/platform/f9824900.sdhci/by-name/persist mke2fs 1.42.9 (28-Dec-2013) Warning: the fs_type small is not defined in mke2fs.conf Discarding device blocks: done Filesystem label= OS type: Linux Block size=4096 (log=2) Fragment size=4096 (log=2) Stride=0 blocks, Stripe width=0 blocks 1408 inodes, 5632 blocks 281 blocks (4.99%) reserved for the super user First data block=0 Maximum filesystem blocks=8388608 1 block group 32768 blocks per group, 32768 fragments per group 1408 inodes per group Allocating group tables: done Writing inode tables: done Writing superblocks and filesystem accounting information: done ~ # ←[6ndd if=/dev/zero of=/dev/block/platform/f9824900.sdhci/by-name/persist dd if=/dev/zero of=/dev/block/platform/f9824900.sdhci/by-name/persist dd: writing '/dev/block/platform/f9824900.sdhci/by-name/persist': No space left on device 45057+0 records in 45056+0 records out 23068672 bytes (22.0MB) copied, 0.938794 seconds, 23.4MB/s ~ # ←[6nexit exit C:\ADB Fastboot Tool> delete also > data/app/com.absolute.android.agent/base.apk file can you explain me where i am wrong................... |
finally thanks to ANDROIDLABS because he is really good man & help me finally solve this problem, now i am very happy |
Code: adb shell |
Dear Babar Abbasi one problem when i connect phone to internet then its again ask pin code and show disable by EE now what can i do.............. |
pls can any one make zip flashable file for remove disabled by EE |
hi androidlabs br babar abbasi what about htc m8 ee account have any sulution.........:rolleyes: |
again problem Quote:
its permanent solution or Temporary solution? because my phone 3 times show this problem |
help me whit s6 g920t hi i need help whit s6 t-mobile , whith block EE any solution android version is 5.1.1 help me please |
how to install latest build of twrp and root the phone ??? |
