Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 06-30-2015, 11:56   #1 (permalink)
androidlabs's Avatar
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 611
[Solved] HTC M9 Phone disabled by EE by Babar Abbasi
First of all install latest build of twrp and then root the phone
here are partitions we need to wipe/format
mmcblk0p60: 01000000  00000200  "absolute"
mmcblk0p30: 01600000  00000200  "persist"
here is the platform
f9824900.sdhci
boot your phone into twrp and use these commands
adb shell
mke2fs /dev/block/platform/f9824900.sdhci/by-name/absolute
dd if=/dev/zero of=/dev/block/platform/f9824900.sdhci/by-name/absolute
mke2fs /dev/block/platform/f9824900.sdhci/by-name/persist
dd if=/dev/zero of=/dev/block/platform/f9824900.sdhci/by-name/persist
exit
if you are unable to communicate with phone using twrp you can manually remove base.apk form file manager on twrp goto [/CODE]/data/app/com.absolute.android.agent/base.apk [/CODE]delete base.apk wipe data/freset wipe cache and reboot you will be in manu then trun usb debugging from phone and try to communicate.
Good Luck everyone.
The Following 14 Users Say Thank You to androidlabs For This Useful Post:
Old 06-30-2015, 17:56   #2 (permalink)
brokendreem's Avatar
Member: 1150957
Thanks Meter: 60
bootloader unlock,terp recovery complete, root complete,
all command working but problem not solve,
steel disable by EE
C:\ADB Fastboot Tool>adb shell
~ # ←[6nmke2fs /dev/block/platform/f9824900.sdhci/by-name/absolute
mke2fs 1.42.9 (28-Dec-2013)
Warning: the fs_type small is not defined in mke2fs.conf
Discarding device blocks: done
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=0 blocks, Stripe width=0 blocks
1024 inodes, 4096 blocks
204 blocks (4.98%) reserved for the super user
First data block=0
1 block group
32768 blocks per group, 32768 fragments per group
1024 inodes per group
Allocating group tables: done
Writing inode tables: done
Writing superblocks and filesystem accounting information: done
~ # ←[6ndd if=/dev/zero of=/dev/block/platform/f9824900.sdhci/by-name/absolute
dd: writing '/dev/block/platform/f9824900.sdhci/by-name/absolute': No space left
on device
32769+0 records in
32768+0 records out
16777216 bytes (16.0MB) copied, 1.991531 seconds, 8.0MB/s
~ # ←[6nmke2fs /dev/block/platform/f9824900.sdhci/by-name/persist
Filesystem label=
OS type: Linux
1408 inodes, 5632 blocks
281 blocks (4.99%) reserved for the super user
First data block=0
Maximum filesystem blocks=8388608
1 block group
1408 inodes per group
~ # ←[6ndd if=/dev/zero of=/dev/block/platform/f9824900.sdhci/by-name/persist
dd: writing '/dev/block/platform/f9824900.sdhci/by-name/persist': No space left
on device
45057+0 records in
45056+0 records out
23068672 bytes (22.0MB) copied, 2.660530 seconds, 8.3MB/s
~ # ←[6nexit
exit
Old 06-30-2015, 18:02   #3 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 611
did you hard reset the phone right after using these commands ?
The Following User Says Thank You to androidlabs For This Useful Post:
Old 07-01-2015, 12:25   #4 (permalink)
Member: 1150957
Thanks Meter: 60
Yes i try hard reset
and try this command 2 times but same problem
not solve disable by ee problem
Old 07-01-2015, 18:55   #5 (permalink)
Member: 1150957
Thanks Meter: 60
C:\ADB Fastboot Tool>fastboot getvar all
< waiting for device >
(bootloader) kernel: lk
(bootloader) product: htc_himauhl
(bootloader) version: 1.0
(bootloader) imei: 3572xxxxxxxx
(bootloader) version-main: 1.32.61.15
(bootloader) boot-mode: download
(bootloader) version-bootloader: 1.0.0.0000
(bootloader) mid: 0PJA10000
(bootloader) cid: ORANG001
all:
finished. total time: 0.004s
try all procedure but can not success,
log all commands
(bootloader) imei: 357226064393408
all:
Filesystem label=
OS type: Linux
First data block=0
1 block group
on device
32769+0 records in
32768+0 records out
16777216 bytes (16.0MB) copied, 1.292194 seconds, 12.4MB/s
Filesystem label=
OS type: Linux
First data block=0
1 block group
on device
45057+0 records in
45056+0 records out
23068672 bytes (22.0MB) copied, 0.938794 seconds, 23.4MB/s
~ # ←[6nexit
exit
delete also > data/app/com.absolute.android.agent/base.apk file
can you explain me where i am wrong...................
Old 07-04-2015, 19:31   #6 (permalink)
Member: 1150957
Thanks Meter: 60
finally thanks to ANDROIDLABS
because he is really good man & help me finally solve this problem,
now i am very happy
Old 07-04-2015, 19:44   #7 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 611
now i am very happy
I am glad to hear success report. commands worked on your phone are
adb shell
dd if=/dev/zero of=/dev/block/p30
dd if=/dev/zero of=/dev/block/p60
Old 07-07-2015, 19:36   #8 (permalink)
Member: 1150957
Thanks Meter: 60
Dear
Babar Abbasi
one problem when i connect phone to internet then its again ask pin code and show disable by EE
now what can i do..............
Old 07-08-2015, 01:57   #9 (permalink)
Member: 355613
Sonork: 100.1674359
Thanks Meter: 160
pls can any one make zip flashable file for remove disabled by EE
Old 07-08-2015, 20:47   #10 (permalink)
Member: 2157308
Sonork: 100.1655088
Thanks Meter: 611
Dear
Babar Abbasi
do the process again hard reset the phone right after commands.
Old 07-09-2015, 09:03   #11 (permalink)
norskgsm's Avatar
Member: 2368438
Sonork: 100.1660498
Thanks Meter: 5
hi androidlabs br babar abbasi
what about htc m8 ee account have any sulution.........
The Following User Says Thank You to norskgsm For This Useful Post:
Old 07-09-2015, 09:30   #12 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,464
Try to find name of preset on location /dev/block/platform/f9824900.sdhci/by-name/ and wipe it using dd command.
The Following 3 Users Say Thank You to Rahul_Bhutani For This Useful Post:
Old 07-11-2015, 08:04   #13 (permalink)
Member: 1150957
Thanks Meter: 60
again problem
when try full process then its done, but 2 days later same problem again come disable by EE
its permanent solution or Temporary solution?
because my phone 3 times show this problem
The Following User Says Thank You to brokendreem For This Useful Post:
Old 10-12-2015, 04:05   #14 (permalink)
Member: 1793498
Thanks Meter: 3
help me whit s6 g920t
hi i need help whit s6 t-mobile , whith block EE any solution
android version is 5.1.1 help me please
Old 10-16-2015, 16:07   #15 (permalink)
Member: 2384553
Thanks Meter: 73
how to install latest build of twrp and root the phone ???
Page generated in 0.42386 seconds with 7 queries
