HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices |
05-09-2010, 01:38 | #1 (permalink) |
Product Manager Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,075 | All htc unlockers in one ftp free thanks to xda developers HTC UNLOCKER & ROMS Kind Regards Fast Unlocking. |
The Following 13 Users Say Thank You to Fast Unlocking For This Useful Post: |
05-09-2010, 02:00 | #2 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Resign
Member: 177036 Status: Offline Thanks Meter: 934 | nice info bro good luck начальник подякувати вам від мене, щоб обіцяти вам код, який ви не забувайте, хе-хе Крім того, бета-тестування мого ключа |
The Following User Says Thank You to darmiles For This Useful Post: |
05-09-2010, 06:49 | #4 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 97,075 | PSAS - Phone System Analysis Software What is it ? It is a development and debugging tool for Qualcomm mobiles and HTC mobiles in general. PSAS is the successor of QMAT, offering more features and stability ! Who may need it ? Mobile engineers / reverse engineers / cryptoanalysts and forensic labs Crypto Functions : - Calculate CRC-30, CRC-32, SHA1, SHA2 (SHA224 + SHA256), MD4 and MD5 of any file - Calculate AES, DES, ARC, TEA, RSA, RC4, CRC32 in several ways (ECD,CBC,CFB,OFB etc..) - Bruteforce bytes to fit CRC-30 needed when qcsblhd_cfgdata.mbn was edited - Extract Gzipped, LZW and LZMA data - Generate AKey, FSC, SPC and SPC3 for several providers - Decrypt and Encrypt any RSA-Message, including ASN-1 / SHA Signatures. (you can add publickeys to publickeys.xml) - Generate RSA Private Key and create .pvk files - Check firmware signature given Modulus and Exponent (for HTC and BQS mobiles) - Extract information from .pvk files - Search for algorithms in binary files (find cryptomethods + signatures) CRC8, CRC16, CRC32, MD4, MD5, SHARK, HAVAL, GZIP, ZIP, SHA1, ... and much more (you can add cryptosignatures to crypto.xml) - Generate several SPC, SP and Blackberry/Sierra Wireless Engineering Codes JTAG Interface : via Segger J-Link ARM (recommended hardware) and GDB server interface Functions for all mobiles with AT modes : 1. Send APDUs to SIM card 2. Read out all SMS with all headers 3. Send any AT command Functions for QC mobiles : 1. Load binary files for : Extraction of certificates Extraction of BMPs,GIFs,PNGs, JPGs 2. Load Partition File to get overview about NAND/NOR structure 3. Send any String to a COM/USB Port and backup all your SMS ! 4. Make usage of QCs Diag USB/COM Port Interface (Useful for any QC mobile in the world) Standard Features : - Send standard diag commands or any hexadecimal command you want (database included) - Read out all NVItems (range given) (all that exist, more than QPST normally extracts) - Backup and Restore all NVItems - Read out and Dump Firmware in Memory (SRam) - Read out complete EFS - Switch to FTM Mode (or anything else you want) - Get infos about phone ..... etc ..... a lot more functions - Generate SimSecure Command to write to SimSecure using given file (may brick your phone when used without knowledge) - Full Feature EFS Browser - TFS Browser - WINCE Rom Dump Tool and Nand Dump/Write Tool (using flashdrv.dll and ondisk.dll, thanks to itsme) - Time Utility to decode Timestamps - 7-Bit SMS Utility to search and decode 7-Bit SMS messages Bootloader / Downloadmode Features : - Load any file to mobile at any address and execute (bootloader f.e.) - Read out complete NAND Memory using bootloader (range given) with included MSM6250/A bootloader or any given bootloader Usage : Take out battery, put in battery, press ON # to enter emergency mode, Execute Loader or (with SL91,SF71 f.e.) enable FTM mode, Execute Loader - Use any Download Mode or Bootloader Command to experiment - Read application memory of newer Diag Ver 6 in Download Mode - Show complete infos about used NAND after loading of Bootloader Flasher Features : Flash any QC mobile (OBL Multiboot) with given bootloader - Flash PBL (dangerous), QCSBL, QCSBL Header and Config Bits, Partition, OEMSBL, OEMSBL Header, AMSS, AMSS Header and EFS Functions for BQS only : 1. Load AMSS to extract files or useful infos (EF81, E81C, EF91, SXG75, EF82, SF71, SL91 or similiar ones) Features : Extract Infos from AMSS : USBID, Product.Nr., SVN, SwBuild, Mobiletype Extract internal filesystem (mif,bar,sig etc. files) Extract AMSS signature bytes (if production key) Show all file references used by mobile 2. Check Firmware validity (signature) Functions for HTC only : 1. Check validity of HTC firmware (signature check) 2. Cut out signatures from .nbh file 3. Split radio.nb into qualcomm files for analysis 4. Find HTC Public keys using Cryptosearch 5. Generate Security passwords (SPL + radio) for newer HTC 6. Generate NBH Files (you can add any device into devlist.xml) 7. Dump Files from NBH (you can add any type into nbhtype.xml) 8. Fix radio.nb checksum 9. Generic Bootloader / AT Command interface with logging functions 10. Decrypt simsecure folder (governmental users only) Functions for Network Engineers Network Calculators : TDMA (GSM/UMTS) : -------------------- IMEI GSM A5-1 GSM A5-2 GSM A5-3 3G ECSD GEA3 - GPRS 3G SNOW 3G UEA2 3G UIA2 GSM A3/A8 COMP128 V1 GSM A3/A8 COMP128 V2 GSM A3/A8 COMP128 V3 3G Milenage 3G Milenage Resync CDMA : ------- CAVE CAVE Authentication CAVE CMEA CAVE EMEA CAVE EMEA_NF CAVE Wireless Residential Extension CAVE Datakey / Look Up Table / Mask CAVE DTC / DCCH CAVE KSG CAVE Long Block CAVE Short Block CAVE Enhanced Message CAVE Enhanced Voice Privacy CAVE Enhanced Data Mask and much more .... Planned in future : 1. Bugfixes 2. Blackberry USB support 3. Read out / Write back Addressbook 4. Restore backupped SMS to phone 5. much much more http://revskills.de/downloads/psas.zip Download details: Visual C++ 2008 Redistributable Package (x86) br |
The Following User Says Thank You to Fast Unlocking For This Useful Post: |
05-15-2010, 13:38 | #13 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Ahmedabad, Gujarat Age: 45
Member: 121078 Status: Offline Sonork: 100.1590676 Thanks Meter: 292 | Quote:
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
