Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC & Smartphones ( WM Without Touch)
HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices
Old 09-17-2014, 17:12   #1 (permalink)
NOKIA EXPERT's Avatar
Member: 2227489
Thanks Meter: 190
Arrow Hard Reset HTC
Hard Reset HTC Desire 820
First method:
  1. First you should to enable Fast boot option in Settings.
  2. Next power off your phone.
  3. Then press and hold Volume Down + Power button until you see three Adroid images.
  4. Now select "Factory reset" using Volume Down to scroll and Power button to confirm.
  5. Well done!
Second method:
  1. Turn on your cell phone.
  2. Now navigate to Settings -> Backup & reset -> Reset phone -> Erase all data -> OK.
  3. After that your phone will reset and reboots.
  4. Success!
BR ,
NOKIA EXPERT .
DON'T FORGET TO HIT THANKS , IF YOU LIKE MY POST !
The Following 2 Users Say Thank You to NOKIA EXPERT For This Useful Post:
Old 09-17-2014, 17:13   #2 (permalink)
Member: 2227489
Thanks Meter: 190
Arrow Hard Reset HTC Desire 510
First method:
  1. Power on the phone.
  2. Next goto Menu -> Setting -> Privacy -> Factory Data Reset.
  3. Now confirm all informations on your screen, and wait until format is done.
  4. Good job!
Second method:
  1. Turn off your cell phone.
  2. Now press and hold Volume Down + Power button for about 10 seconds.
  3. After that you will be in HBOOT menu.
  4. In this menu choose option "Clear Storage" using Volume buttons to scroll, and Power button to confirm.
  5. Then wait until your phone will reset and reboots with factory settings.
  6. Well done!
BR ,
NOKIA EXPERT .
Old 09-17-2014, 17:15   #3 (permalink)
Member: 2227489
Thanks Meter: 190
Arrow Hard Reset HTC Mozart
First method:
  1. Power off your device.
  2. Next hold and press Volume Up + Volume Down + Power button.
  3. Then wait for instructions on your screen, and when you see this instructions, then release holded keys.
  4. Now follow the instructions to finish reset your device.
  5. Done!
Second method:
  2. Now from the Start screen, tap right arrow.
  3. Then goto Settings -> About phone -> reset your phone -> yes.
  4. Next you will see that your phone will reset and reboots.
  5. Good job!
Old 09-17-2014, 17:16   #4 (permalink)
Member: 2227489
Thanks Meter: 190
Arrow Hard Reset HTC One M8
Hard Reset HTC One M8 for Windows
First method:
  1. Power on the device.
  2. Next goto Settings -> Backup & reset -> Reset phone -> Eraase all data.
  3. Confirm your choice -> tap OK.
  4. Done!
Second method:
  1. Switch off your device.
  2. Next press and hold Volume Down + Power button.
  3. When you see the three Android images, then release holded keys.
  4. Then press Volume Down to select option "Factory reset", and press Power button to confirm.
  5. Good job!
Old 09-17-2014, 17:17   #5 (permalink)
Member: 2227489
Thanks Meter: 190
Hard Reset HTC One
First method:
  1. Power off the device by pressing Power button.
  2. Then hold Volume Down + Power button until you see three Android images.
  3. Now select option "FACTORY RESET" to browse use Volume Down, and to choose option Power button.
  4. Device will reboot itself.
Second method:
  1. Go to Settings, next tap Backup & reset.
  2. Select Reset phone.
  3. if u want delete all data (all the media) select Erase all data.
  4. Press OK.
Old 08-12-2016, 16:41   #6 (permalink)
Member: 1244368
Sonork: 1636833:Ranjit
Thanks Meter: 4
HTC Desire 530 Hard Reset....
1. First, make sure the phone is turned off
2. Next, press and hold “Volume down”
3. Press and hold “Power”, and release the button once the device vibrates
4. When you gain access to “hTC download mode” release “Volume down” too
5. Press “Volume down” repeatedly to navigate the menu and highlight “reboot to bootloader”
6. Press “Power” to select the highlighted option
7. Press “Volume down” to highlight “Boot to recovery mode” and press “Power”
8. When an exclamation mark appears on the display, press and hold “Power”, and press & release “Volume Up”
9. After you gain access to the “Android system recovery” menu, release all buttons
10. In the recovery menu, press “Volume down” repeatedly to highlight “wipe data / factory reset”
11. Press “Power” to select the option
12. After the reset is complete “Reboot system now” should be highlighted
13. Press “Power” one more time to confirm and reboot your phone
Page generated in 0.30243 seconds with 8 queries
