HARD RESET sapp310 HARD RESET sapp310 htc tmobile i need to hardreset |
plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz |
plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz |
http://forum.gsmhosting.com/vbb/f98/...6/#post6353372 why not use search button it is htc magic. here is procedure HTC Magic Hard reset - HTC Magic Soft reset |
Factory reset using key combination To reset the HTC Magic phone using phone buttons 1. With the phone turned off, press and hold the HOME and BACK buttons. 2. Briefly press the END CALL/POWER button while continuing to press the HOME and BACK buttons. 3. When you see the screen with the 3 Android images, release the HOME and BACK buttons, and then press the TRACKBALL. Tip If your phone hangs or freezes, remove the battery then wait for a few seconds, and then re-install it. After re-installing the battery, turn on the phone. |
Hi everyone, I tried all methods to reset my HTC Magic / format it, with phone switched off methods or switched on. After I touch SD Card & Phone Storage, I never get the item 'Factory reset'. Please advise urgently as I cannot use internet anymore on my mobile except when it is connected to WiFi. Many thanks, Lou |
HTC Magic hard reset HTC Magic soft reset Factory reset using key combination To reset the HTC Magic phone using phone buttons 1. With the phone turned off, press and hold the HOME and BACK buttons. 2. Briefly press the END CALL/POWER button while continuing to press the HOME and BACK buttons. 3. When you see the screen with the 3 Android images, release the HOME and BACK buttons, and then press the TRACKBALL. Tip If your phone hangs or freezes, remove the battery then wait for a few seconds, and then re-install it. After re-installing the battery, turn on the phone. Back to main site Hard reset� 2009 |
