Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC & Smartphones ( WM Without Touch)
HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices
Old 10-26-2008, 08:51   #1 (permalink)
MR.PRESIDENT's Avatar
Member: 152821
Thanks Meter: 67
How to hard reset cingular 2125 by htc to get rid of usercode?
how about cingular 2125 by htc ,how to hard reset because I want to get rid of unknown usercode.I found one at hardreset .eu but it seems that you can use only the written procedure when you can still browse the menu.The bottom line here is how can I hard reset without using the menu.thanks and more power.
Old 10-26-2008, 09:07   #2 (permalink)
Member: 45985
Thanks Meter: 96
Hold down both soft keys and then press and hold the Power button for 2 sec.
The "Cingular raising the bar" splash screen will come up.
Release Power but keep holding down both soft keys for a couple of more seconds.
The screen should turn black with some text in white letters asking you to press 0 to complete the hard reset.
At this point release the soft keys and press zero to confirm the hard reset.
Any other keypress will cancel the reset and continue with the normal boot process.
Found it somewhere,try and post your feedback.
br
Old 10-26-2008, 10:03   #3 (permalink)
I_sumo's Avatar
Member: 38103
Sonork: 100.100782
Thanks Meter: 165
While HOLDing two " _ " keys press Soft Reset key (Located near Charging socket). Release soft reset key BUT hold both keys until u get a Message on LCD. ONCE u see it - open keyboard press "R" and allow your phone to reboot and process rest.
Man its DONE !
Old 11-01-2008, 06:29   #4 (permalink)
Member: 152821
Thanks Meter: 67
thanks all of you,I succesfully decode usercode and as well as unlock after.
Old 05-07-2009, 10:53   #5 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 278
Man its DONE !
i do not know if the phone is in off state or on
Old 06-10-2009, 17:24   #6 (permalink)
Member: 337762
Sonork: 100.1581304
Thanks Meter: 50
pls mate am having same user lock problem here can u be more simply first i need to know if it the side keys or the topmost key or the one in the middle and also need to know if the fone need to be switch on during the process or off during the process pls explain
How To Get Rid of Mails By Iclarified.com unlock trigger Off Topic Zone 0 11-20-2008 19:30
How to get rid of consequences of input of a code *#73738# lukasartsDon NEC 0 01-03-2005 17:31
how to get rid of security code on spv fonefixer Various 3 08-16-2003 16:26
How to get rid of vodafone?? tha_noname Panasonic 0 06-18-2003 03:53
How To Get Rid Of "A little problem in the program found" On Jethro psmods Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 07-02-2001 14:17
Page generated in 0.29353 seconds with 8 queries
