HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices |
01-04-2009, 14:48 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: UAE
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | HTC kais 130 successfull unlock can any one tell me now what shold i do very very argent pls |
The Following 3 Users Say Thank You to delower10 For This Useful Post: |
01-04-2009, 21:42 | #2 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: Hungary Age: 47
Member: 365452 Status: Offline Thanks Meter: 838 | Quote:
Flash it with a proper radio rom or official rom(full official roms contain radio rom and those 100% compatible).Maybe your unlock method works with radio downgrade or a different radio rom,that needs reflash original radio rom after unlock. BR Szig | |
02-09-2009, 11:56 | #5 (permalink) |
Member: 890592 Status: Offline Sonork: 100.1581951 Thanks Meter: 4,429 | Kais 130 rom download Bro update ur kais then all ok this file working 100% thanks |
The Following 11 Users Say Thank You to delower10 For This Useful Post: |
02-09-2009, 13:15 | #6 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 852575 Status: Offline Thanks Meter: 11 | hi, Flash it with a proper radio rom or official rom(full official roms contain radio rom and those 100% compatible.)its always better to flash with orginal firmware. you can search it from fourm its there. |
02-09-2009, 16:05 | #7 (permalink) | |
It's strange.The first sentence is so familiar to me,why? That is what I wrote above: Hi! Flash it with a proper radio rom or official rom(full official roms contain radio rom and those 100% compatible).Maybe your unlock method works with radio downgrade or a different radio rom,that needs reflash original radio rom after unlock. BR Szig Please appreciate my work and at least quote my post,not copy-paste. Thanks! Szig | |
02-10-2009, 05:54 | #8 (permalink) | |
Insane Poster Join Date: Jul 2007 Location: sylhet
Member: 556786 Status: Offline Thanks Meter: 20 | Quote:
05-29-2009, 19:35 | #13 (permalink) |
Freak Poster Join Date: Jul 2008 Location: WORKS WITH THE BEST
Member: 821156 Status: Offline Thanks Meter: 42 | please, i need to unlock my kais 130 can any body give me procedure as to how i can unlock it. it is t mobile and network code. thanks in advance |
05-29-2009, 19:37 | #14 (permalink) |
No Life Poster Join Date: Jul 2007 Location: (¯`». Catch Me If U Can .«´¯) Age: 35
Member: 553445 Status: Offline Sonork: 100.1585581 Thanks Meter: 8,184 | FIRST YOU NEED TO UNLOCK CID UNLOCK YOUR DEVICE. DOWNLOAD LINK : http://rapidshare.com/files/85462026...-tool.zip.html Instructions ============ 0. Make sure there is a working SIM in the device. 1. Make sure you installed HardSPL as follows: power off and then press power on while keeping camera pressed, this will enter the so called bootloader mode and you see a tri-color screen (Red, Green, Blue). You should see "SPL-1.0 OliPof" or "SPL-1.1.JockyW" on the second line in the top left corner. You can exit this mode by means of a "soft reset": press the reset button with the stylus. Note that the security unlocker does not work with "SPL-3.28.Hard" and "SPL-3.29.Hard". 2. Make a note of the radio version that is currently installed. You see the version strings in the splash screen which appears soon after power on (e.g. "R 1.27.14.09"). Since we will flash a special radio in step 5 you need to flash back your original radio in the last step. You can download radio roms from XDA devs here. 3. Connect PC and Kaiser with a USB cable and keep it connected until the last step. 4. Power on the Kaiser and let it boot into Windows Mobile. On the PC make sure the activesync icon is green. 5. After you unpacked the download you see directories "step1" and "step2". Go into "step1" and run KaiserCustomRUU.exe. This will flash the special patched radio rom. Follow the instructions until it is finished. IMPORTANT: Make sure that the flash correctly finished. The device will restart automatically once the flashing is completed. 6. Power off and power on in tri-color bootloader mode. 7a. right-click activeync icon and uncheck "Allow USB connections" from Connection Settings 7b. On your PC go into the "step2" directory and run "kaiser-supercid.exe". If all went well you will see the text below 7c. right-click activeync icon and check "Allow USB connections" from Connection Settings Text shown if all went well: Code: === Kaiser SuperCID and Security Unlocker v0.2 (c)2008 by jockyw2001 === Donations happily accepted, paypal to [email protected] [] Done, your device should now be superCID and Security Unlocked [] Your device is unlocked and you can change anything anytime [] Don't forget to flash your original radio Press Enter to exitIf you see this: Code: === Kaiser SuperCID and Security Unlocker v0.2 (c)2008 by jockyw2001 === Donations happily accepted, paypal to [email protected] Your CID = HTC__001 [] Failed! Please soft reset and try again [] To soft reset press and hold camera button and then press reset with stylus Press Enter to exitthen do a soft reset (press and hold the camera button first and then shortly press the reset button with the stylus) and run "kaiser-supercid.exe" again. 8. Download the original radio from here to the "step3" directory on your PC and flash it with KaiserCustomRUU.exe That's all folks AFTER CID UNLOCK USE THIS ROM FOR ENGLISH LANGUAGE. http://rapidshare.com/files/57816419..._Ship.rar.html |
The Following 3 Users Say Thank You to nasirkhan007 For This Useful Post: |
htc kais 130 o2 unlock? | zena1122 | HTC & Smartphones ( WM Without Touch) | 0 | 11-17-2008 12:55 |
HTC kais 130 stuck on "smart mobility" | dannyogolo | HTC & Smartphones ( WM Without Touch) | 1 | 10-14-2008 18:27 |
Htc kais 130 | Warptech | HTC & PDA WM( With Touchscreen) | 1 | 10-13-2008 05:01 |
HTC Kais 130 | vipimg | HTC & PDA WM( With Touchscreen) | 0 | 09-26-2008 07:04 |
HTC Kais 130 (TyTN II) | grgoni | HTC & Smartphones ( WM Without Touch) | 0 | 09-03-2008 17:41 |
