HTC KAISER 130 Windows Mobile 6.1 english How to change language from Dansk to English i need. ROM version: 1.56.403.4 ROM dato: 09/018/07 Radioversion: 1.27.12.32 Protoklversion: 22.45.88.07H ExtROM version: 1.56.403.8001 |
DOWNLOAD LINK :http://rapidshare.com/files/85462026...-tool.zip.html Instructions ============ 0. Make sure there is a working SIM in the device. 1. Make sure you installed HardSPL as follows: power off and then press power on while keeping camera pressed, this will enter the so called bootloader mode and you see a tri-color screen (Red, Green, Blue). You should see "SPL-1.0 OliPof" or "SPL-1.1.JockyW" on the second line in the top left corner. You can exit this mode by means of a "soft reset": press the reset button with the stylus. Note that the security unlocker does not work with "SPL-3.28.Hard" and "SPL-3.29.Hard". 2. Make a note of the radio version that is currently installed. You see the version strings in the splash screen which appears soon after power on (e.g. "R 1.27.14.09"). Since we will flash a special radio in step 5 you need to flash back your original radio in the last step. You can download radio roms from XDA devs here. 3. Connect PC and Kaiser with a USB cable and keep it connected until the last step. 4. Power on the Kaiser and let it boot into Windows Mobile. On the PC make sure the activesync icon is green. 5. After you unpacked the download you see directories "step1" and "step2". Go into "step1" and run KaiserCustomRUU.exe. This will flash the special patched radio rom. Follow the instructions until it is finished. IMPORTANT: Make sure that the flash correctly finished. The device will restart automatically once the flashing is completed. 6. Power off and power on in tri-color bootloader mode. 7a. right-click activeync icon and uncheck "Allow USB connections" from Connection Settings 7b. On your PC go into the "step2" directory and run "kaiser-supercid.exe". If all went well you will see the text below 7c. right-click activeync icon and check "Allow USB connections" from Connection Settings Text shown if all went well: Code: === Kaiser SuperCID and Security Unlocker v0.2 (c)2008 by jockyw2001 === Donations happily accepted, paypal to [email protected] [] Done, your device should now be superCID and Security Unlocked [] Your device is unlocked and you can change anything anytime ;) [] Don't forget to flash your original radio Press Enter to exitIf you see this: Code: === Kaiser SuperCID and Security Unlocker v0.2 (c)2008 by jockyw2001 === Donations happily accepted, paypal to [email protected] Your CID = HTC__001 [] Failed! Please soft reset and try again [] To soft reset press and hold camera button and then press reset with stylus Press Enter to exitthen do a soft reset (press and hold the camera button first and then shortly press the reset button with the stylus) and run "kaiser-supercid.exe" again. 8. Download the original radio from here to the "step3" directory on your PC and flash it with KaiserCustomRUU.exe That's all folks AFTER CID UNLOCK USE THIS ROM FOR ENGLISH LANGUAGE. http://rapidshare.com/files/57816419..._Ship.rar.html |
the phone work with other sim card, i try to update but stop at 0% proces |
1 Attachment(s) i have this problem see photo |
i have problem with downloading Error You want to download the following file: http://rapidshare.com/files/85462026...erCID-tool.zip | 9131 KB The download session has expired. Please click here to start the download again. |
Try reading the below links. Final pages has the links to unlock your device http://wiki.xda-developers.com/index...ame=HTC_Kaiser |
My kaiser 130 have....... rom-3.28.........fre radio-1.65.17.56......... protocal-25.83.40........ spl-3.28.......(but not spl-3.28 hard) but.... not sim locked now..i want to change language to English... I need the procedure...... |
2 Attachment(s) How to Install A Hard SPL: 1. Plug the device into your PC 2. Copy JumpSPL 1.94 to your device. 3. Take out your SD card & SIM Card. 4. Run Jump SPL on your device 5. Wait for the bootloader screen to appear and "USB" to show. 6. Right-click activesync, go into connection settings and ensure Allow USB Connections is unchecked 7. Unplug your device from the USB port, wait 5 - 20 seconds, plug it back in. 8. Run KaiserCustomRUU.exe and flash the SPL Now flash with any rom... BR;) |
i have this problem image |
problem same invalid vendor id dear problem same not updated to english rom |
My kaiser 130 ==Kaiser Debug Output== ==Made by Olipro - 2008. www.xda-developers.com== -Version 2.0- SPL Flashed! ==Patching Radio== ==Radio Patched!== SECURITY_TEST unlocked,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, RUU_Kaiser_HTC_GER_3[1].28.407.0_radio_sign_25.83.40.02_1.65.17.56_Ship okeyyyyyyyyyyyyyyyyyyyyyyy ==Running Unlocker== http://www.4shared-china.com/file/20...rUnlocker.html Kaiser SIM/CID Unlocker & Changer http://forum.xda-developers.com/show....php?t=375583: |
HTC Help You should check out all the HTC stuff at supaswap dot info |
thanks for nice post ........... |
all link is dead. help melp me for unlock kais 130 |
