Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC & Smartphones ( WM Without Touch)
HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices
Old 08-18-2008, 16:24   #1 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,672
HTC KAISER 130 Windows Mobile 6.1 english
How to change language from Dansk to English i need.
ROM version: 1.56.403.4
ROM dato: 09/018/07
Radioversion: 1.27.12.32
Protoklversion: 22.45.88.07H
ExtROM version: 1.56.403.8001
The Following 2 Users Say Thank You to [email protected] S For This Useful Post:
Old 08-18-2008, 17:47   #2 (permalink)
rajan nishchal's Avatar
Member: 75612
Thanks Meter: 1,395
ROM dato: 09/018/07
FIRST YOU NEED TO UNLOCK CID UNLOCK YOUR DEVICE.
DOWNLOAD LINK :http://rapidshare.com/files/85462026...-tool.zip.html
Instructions
0. Make sure there is a working SIM in the device.
1. Make sure you installed HardSPL as follows: power off and then press power on while keeping camera pressed, this will enter the so called bootloader mode and you see a tri-color screen (Red, Green, Blue). You should see "SPL-1.0 OliPof" or "SPL-1.1.JockyW" on the second line in the top left corner. You can exit this mode by means of a "soft reset": press the reset button with the stylus. Note that the security unlocker does not work with "SPL-3.28.Hard" and "SPL-3.29.Hard".
2. Make a note of the radio version that is currently installed. You see the version strings in the splash screen which appears soon after power on (e.g. "R 1.27.14.09"). Since we will flash a special radio in step 5 you need to flash back your original radio in the last step. You can download radio roms from XDA devs here.
3. Connect PC and Kaiser with a USB cable and keep it connected until the last step.
4. Power on the Kaiser and let it boot into Windows Mobile. On the PC make sure the activesync icon is green.
5. After you unpacked the download you see directories "step1" and "step2". Go into "step1" and run KaiserCustomRUU.exe. This will flash the special patched radio rom. Follow the instructions until it is finished. IMPORTANT: Make sure that the flash correctly finished. The device will restart automatically once the flashing is completed.
6. Power off and power on in tri-color bootloader mode.
7a. right-click activeync icon and uncheck "Allow USB connections" from Connection Settings
7b. On your PC go into the "step2" directory and run "kaiser-supercid.exe". If all went well you will see the text below
7c. right-click activeync icon and check "Allow USB connections" from Connection Settings
Text shown if all went well:
=== Kaiser SuperCID and Security Unlocker v0.2 (c)2008 by jockyw2001
=== Donations happily accepted, paypal to [email protected]
[] Done, your device should now be superCID and Security Unlocked
[] Your device is unlocked and you can change anything anytime
[] Don't forget to flash your original radio
Press Enter to exitIf you see this:
Your CID = HTC__001
[] Failed! Please soft reset and try again
[] To soft reset press and hold camera button and then press reset with stylus
Press Enter to exitthen do a soft reset (press and hold the camera button first and then shortly press the reset button with the stylus) and run "kaiser-supercid.exe" again.
8. Download the original radio from here to the "step3" directory on your PC and flash it with KaiserCustomRUU.exe
That's all folks
AFTER CID UNLOCK USE THIS ROM FOR ENGLISH LANGUAGE.
http://rapidshare.com/files/57816419..._Ship.rar.html
The Following User Says Thank You to rajan nishchal For This Useful Post:
Old 08-18-2008, 18:15   #3 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,672
the phone work with other sim card, i try to update but stop at 0% proces
Old 08-18-2008, 18:44   #4 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,672
i have this problem see photo
Old 08-18-2008, 21:33   #5 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
Thanks Meter: 3,672
i have problem with downloading
Error
You want to download the following file:
http://rapidshare.com/files/85462026...erCID-tool.zip | 9131 KB
The download session has expired. Please click here to start the download again.
Old 03-30-2009, 04:33   #6 (permalink)
Member: 958082
Error
Try reading the below links. Final pages has the links to unlock your device
http://wiki.xda-developers.com/index...ame=HTC_Kaiser
Old 11-10-2009, 20:55   #7 (permalink)
aikonmani's Avatar
Member: 304090
Thanks Meter: 196
Instructions
Your CID = HTC__001
That's all folks
My kaiser 130 have.......
rom-3.28.........fre
radio-1.65.17.56.........
protocal-25.83.40........
spl-3.28.......(but not spl-3.28 hard)
but.... not sim locked
now..i want to change language to English...
I need the procedure......
Old 11-12-2009, 00:13   #8 (permalink)
xchris's Avatar
Member: 8490
Thanks Meter: 23
How to Install A Hard SPL:
1. Plug the device into your PC
2. Copy JumpSPL 1.94 to your device.
3. Take out your SD card & SIM Card.
4. Run Jump SPL on your device
5. Wait for the bootloader screen to appear and "USB" to show.
6. Right-click activesync, go into connection settings and ensure Allow USB Connections is unchecked
7. Unplug your device from the USB port, wait 5 - 20 seconds, plug it back in.
8. Run KaiserCustomRUU.exe and flash the SPL
Now flash with any rom...
Old 12-24-2009, 21:15   #9 (permalink)
shd_ndm's Avatar
Member: 122893
Thanks Meter: 15
i have this problem image
Old 09-28-2010, 14:53   #10 (permalink)
Member: 178616
Thanks Meter: 83
Arrow problem same invalid vendor id
dear problem same not updated to english rom
Old 10-23-2010, 22:40   #11 (permalink)
Nurettin Duman's Avatar
Member: 115596
Thanks Meter: 1,115
My kaiser 130
==Kaiser Debug Output==
==Made by Olipro - 2008. www.xda-developers.com==
-Version 2.0-
SPL Flashed!
==Patching Radio==
==Radio Patched!==
SECURITY_TEST unlocked,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
RUU_Kaiser_HTC_GER_3[1].28.407.0_radio_sign_25.83.40.02_1.65.17.56_Ship okeyyyyyyyyyyyyyyyyyyyyyyy
==Running Unlocker==
http://www.4shared-china.com/file/20...rUnlocker.html
Kaiser SIM/CID Unlocker & Changer
http://forum.xda-developers.com/show....php?t=375583:
The Following User Says Thank You to Nurettin Duman For This Useful Post:
Old 10-25-2010, 14:48   #12 (permalink)
Member: 1426795
HTC Help
You should check out all the HTC stuff at supaswap dot info
Old 10-25-2010, 19:37   #13 (permalink)
Member: 1427193
thanks for nice post ...........
Old 09-15-2017, 07:01   #14 (permalink)
Member: 2708690
all link is dead. help melp me for unlock kais 130
Official Update - HTC Kaiser - TyTN II - Windows Mobile 6.1 .:SUBRATA:. HTC & PDA WM( With Touchscreen) 4 07-25-2010 12:27
tomtom htc touch dual windows mobile 6.0 liverpool211 GPS devices , Navigators & Maps 1 11-02-2009 12:17
HTC Touch Pro Unlocked Smartphone with 3.2 MP Camera, Windows Mobile 6.1, Wi-Fi, GPS, IPMART ipmart WebShop 0 05-27-2009 16:40
HTC S621 Microsoft Windows Mobile 6 Phone IPMART ipmart WebShop 0 11-29-2008 07:10
Page generated in 0.43105 seconds with 9 queries
