HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices |
12-09-2011, 16:00 | #1 (permalink) |
Product Manager Join Date: Oct 2007 Location: 乂事Lover事&
Member: 619738 Status: Offline Sonork: 100.1582811 Thanks Meter: 5,212 | Repair IMEI HTC Phones This thread for my brother xxxman and at his request Repair imei htc touch+exca100+gene100 Here repair htc imei Touch(elf0101..) 1. Using goldcard..(sd card) 2. Create Goldcard. XDADeveloperWiki - Elf_Gold Card. 3. Copy to goldcard 2 files: elfdiag.nbh+ELFIMG.nbh(mfg patch). 4. Put sd into htc touch without battery after put battery and press power+camera button. 5. Show in htc.. "input pass" pass is: keys send+end + center button press this buttons.ok 6. Press again center button to unlock htc touch .. 7. Repeat processes remove the battery in htc..insert battery..press power+camera button enter pass: digit: key send+key end +key center after press power button to reflash wait to successful processes. 8. Desactive actyvesync ..desactive option allow usb connection. 9. Open mtty program connect htc elf. 10. Digit in mtty: erasedata+enter IMEI XX XX XX XX XX XX XX XX+enter Reset Device+enter 11. Is all |
The Following 5 Users Say Thank You to hamada-almasry For This Useful Post: |
12-09-2011, 16:05 | #2 (permalink) |
Member: 619738 Status: Offline Sonork: 100.1582811 Thanks Meter: 5,212 | xca imei without gold-card Solution thanks to Dexter team monoxide .and ovalle team..STEP 1. 1. Unzip the file USPLMFG inside a folder called excavation or whatever. 2. Excalibur Htc Sync .. q with the syn actives ync get in verdesito. March. Inside the folder you unzipped q q is a small program called sda unlock Correlo .. and dale click to remove .. 4. Now give upsl.bat and click to see by looking at the screen on the Excalibur on the screen of the excavation permits were installed give yes and yes and enter on the pc .. 5. Now the screen goes blank Excalibur If it does not repeat the process until the blank .. q 6. Q After the screen is blank Excalibur .. see a folder called Excalibur-q-CUP upsl go to update and correlate rom is flashed dale accept a file and you will end the message congratulations. 7. After q turn the Excalibur and put off the active sync in Excalibur Nla tricolor boot you do this by giving a touch to down the Power and Botond and leaving the chamber. 8. After q is in the open tricolor mtty and you click on usb usb saldra das clik n cmd. Digitas him erase data 1 AND ENTER IMEI 35 15 57 01 61 96 08 50 And ENTER Reset Device Here the computer will restart q batteries here waiting restarts and when you leave the bar filling the battery lequitas setting ... 9. You place the battery put in tri-mode or boot the open Excalibur mtty and digits: IMEI 35 15 57 01 61 96 08 50 And ENTER Reset Device 10. Normal clothes and let Q Excalibur While you probably q give out a red screen .. ok yes * Connect the excavation and sincronozas - 11. After normal garment Excalibur proceed to open the band .. for this you open a folder called q q Excalibur bands send you via mail .. ok open the Dash2bunlock of software to sync the Excalibur simobolo green active sync .. you will get a black screen in Dos give him enter, and then will ask you to run a file with the name of imei q is inside the same folder .. wait a while and the team with the bands there will be open .. We now proceed to put the imei you want .. q 12. To put it simply disable Active syc in trichloro and want to put the imei q example erase data 1 and enter IMEI 35 01 02 23 11 12 32 12 AND ENTER Reset Device and ENTER 13. Q hoped to restart the waiting exca lighting batteries go you expect q saldra mobile operator the glimpse of hope from there will tell you des q ready click the bar you fill out allli you remove the battery - 14 - Put the battery put back in tricolor and digits .. IMEI 35 01 02 23 11 12 32 12 AND ENTER Reset-device and ENTER files may upload in 4 hours.. |
The Following User Says Thank You to hamada-almasry For This Useful Post: |
12-09-2011, 16:08 | #5 (permalink) |
Member: 619738 Status: Offline Sonork: 100.1582811 Thanks Meter: 5,212 | Here diag opal100 same htc Viva only put opaldiag in SD(goldcard)..Insert sd in htc remove battery..put battery and on hct with power button+down volume button. Input pass is: Digit send button+end button +center button..after power button is All..Unlock free 1 min.... |
12-09-2011, 19:07 | #6 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Java Age: 46
Member: 166000 Status: Offline Thanks Meter: 26 | Hello sir, do you have a solution for imei repair at o2 stealth? i got o2 stealth that radio module could not activate, when i checked imei was missing. thanx. |
12-19-2011, 01:22 | #7 (permalink) | |
Junior Member Join Date: Apr 2008 Location: Bogotá D.C
Member: 757010 Status: Offline Thanks Meter: 2 | Opal imei? Opal repair imei, possible??? Quote:
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
