PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
10-31-2011, 22:42 | #1 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1267882 Status: Offline Thanks Meter: 48 | all about palm first palm pre activation ur stuck up here u need palm profile to login but dont have one ok lets get started FOr windows vista and win7 only 1. Uninstall any existing SDK or PDK installations
Download and install the latest version of Java™. To verify that Java is installed, go to the Command Prompt and type: java -versionIf Java is installed, Java version information appears. Download Java 3. Install VirtualBox 3.2.6 The Palm emulator is built on VirtualBox™, virtual machine software that you can download free from Oracle®. VirtualBox is required before installing the Palm webOS SDK. Download Virtualbox 4. Install the Palm webOS SDK for Windows
Windows 64-bit Windows Vista & Windows 7 only Download SDK Windows 32-bit |
10-31-2011, 23:14 | #2 (permalink) |
Member: 1267882 Status: Offline Thanks Meter: 48 | after installing all the above Download the activation-bypass tool, which is available here, and save it in the location of your choice.(like C: drive) Boot your device into recovery mode. Phones Off, Hold volume Up and connect to Usb.it should be like this [IMG]http://4.bp.********.com/-mPzDi8Bc47Y/Tiy45qWTsZI/AAAAAAAAAI8/9GxH7-TNLXo/s400/USBDriveMode_RecoveryMode_CasS09.png[/IMG] Run the activation-bypass tool from the command line by issuing the following command: java -jar devicetool.jar Uploaded with ImageShack.us http://cdn.downloads.palm.com/sdkdow...devicetool.jar |
10-31-2011, 23:54 | #4 (permalink) |
Member: 1267882 Status: Offline Thanks Meter: 48 | next coming up hp veer activation its abit long process Hopefully this tutorial will help out new users like myself who are probably confused on what to do(Well I wasn’t . Just saying). I didn’t find any guide like this 1) Turn on phone (duh ) At this point you need a sim card in the phone. If you already turned on the phone, you can still put it in after it boots. 2) Once Firstboot runs press on the bottom right corner of the screen(it will display a phone symbol) and select emergency call 3) delete the 911 number and type in #*DEVMODE# use the dialer. #*DEVMODE# = #*3386633# 4) The Dev mode option should appear, enable it and reboot the phone 5)download preware installer and install preware in phone Index of / 6) On the phone connect to a Wi-Fi hotspot. 7) you need to start Preware select Preware menu >Manage Feeds and make sure the WebOS Internal feed is turned on. Make sure the packages are then updated, click the search button and enter Impostah, select and install it. 7)run Impostah 8) Run activation and input your login credentials. Either login or create a new profile 9) Go back and select accounts. Higlight Dr.Skipped Firstboot and select delete. Afterwards go back again and select Palm profile, then Reset Palm Profile, it will now ask you to reboot. 10) Once reboot finishes Firstboot should run. Double check that Wi-Fi is still working and if it is then go on ahead and login with your profile. |
10-31-2011, 23:57 | #5 (permalink) |
Member: 1267882 Status: Offline Thanks Meter: 48 | more to come next tommorow i will post how to easily unlock these models Unlocker for Palm Pre/Pixi and HP Veer Phones i had struglled a lot to get going in the correct process and taken long time to know this process so kindly a thanks can make me happy |
12-19-2011, 16:53 | #9 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | very nice job, my palm pixi plus is acivated ! thank you, just for information in the last step i just executed devicetool.jar directly, no nead any command. thank you babji |
12-24-2011, 19:23 | #10 (permalink) | |
Member: 1267882 Status: Offline Thanks Meter: 48 | Quote:
but if u have installed nokia pc suite u will need it | |
12-29-2011, 02:32 | #11 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: uk
Member: 372163 Status: Offline Thanks Meter: 57 | Quote:
The Following User Says Thank You to abaa For This Useful Post: |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
I am looking for information about GSM-CABLES.NE | DUPOND | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 08-03-1999 15:29 |
all for GSM: http://fly.to/spear | spear | GSM Mobile Links | 0 | 07-11-1999 22:01 |
Question about 51xx/61xx | Comic | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-06-1999 23:47 |
