PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
01-22-2005, 22:15 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: A O T E A R O A - Land of the long,white cloud Age: 47
Member: 8985 Status: Offline Thanks Meter: 3 | * * * The first Treo 600 Unlock Step By Step by SPguru * * * This version doesn't need SD card!!! --------------------------------------- 1.Check your phone version,write everything down just in case if something goes wrong.It's a menu in the phone for it.You should have like these: IMEI:01021500xxxxxxxx HS SN:HAGAD409xxxxx SA number: 100131xxxx Firmware: 02.04 Software: Treo600-1.07-AWS Hardware: B 2.Do own backup of all your stuff 3.Turn the phone off,hold reset at the back and turn it on for getting full HW RESET 4.Get registered (free) by http://mytreo.net to get access for download area 5.Download the RIGHT flash for your phone from here.These are the latest ones (V03.05-06) you must use them against getting screwy phone,funny menu,etc... here: http://mytreo.net/downloads/modules....titleA&show=20 6.Install phonesync software from either PALM website or CD. 7.Start install tool on PC the add the downloaded flash file to it. 8.Do syncronization by pushing the big button in the middle of the cable plug, the flashfile will get downloaded into Treo 600 memory 9.Now You can find a new "blue box" on the Treo Desktop,start that,follow the instructions to flash your phone.Wait about 15 minutes,have a cofee or smoke 10.Do HW reset again just in case as step 3. 11.Download the patched flash parts for all the firmwares from the website in step 5 .This works only with those!!! Here: URL http://www.cyberjet.com/mtn/T6GSMUP305.zip 12.Unzip them onto your harddrive then add each file in the install tool software what you used in step 7.Do syncronization again. 13.You should have again a new "blue box" with different name on the Treo desktop,start it then follow the instructions. 14.The phone will upgrade in case patch itself 15 You have fully unlocked Treo 600 with latest firmware without hassles This is the only fully detailed instruction about Treo 600 unlocking on the internet.It took couple days along with hassles to get there... BR SPguru Last edited by spguru; 01-22-2005 at 22:24. Reason: Mistake to submit in half.. |
01-26-2005, 20:12 | #4 (permalink) |
No Life Poster Join Date: Jun 2003 Location: root
Member: 31049 Status: Offline Thanks Meter: 4 | >> * * * The first Treo 600 Unlock Step By Step by SPguru * * * ???????????? solution is old, for treo600 12mounts btw I was a member(atari) of gang that make thet solution on best place for treo users .....central, mytreo.net wasnt even existed at thet time.... Last edited by danilo_nop; 01-27-2005 at 02:01. |
01-26-2005, 23:18 | #5 (permalink) | |
No Life Poster Join Date: Mar 2004 Location: New York City, USA Age: 58
Member: 56365 Status: Offline Thanks Meter: 28 | Quote:
This is very old solution and is definitely not first step by step solution my friend. PS: have you seen this link??? https://forum.gsmhosting.com/vbb/f487/treo-600-unlock-124058/ Regards, JOHNNY. | |
01-27-2005, 06:39 | #6 (permalink) |
Member: 8985 Status: Offline Thanks Meter: 3 | Ha ha ha Never Mind Guys you can deify each other.But the fact is all your posts were useless.(Your link to) That topic is just correspondence nothing else. (Danilo nop first answer for the question: "I have the solution too") No comment this kind of help-answer.The patch which is downloadable on the first few pages is for old firmware.To patch that is absolutely mistake as the old patched firmware plays up.First of all you were talkin' about the solution which based on SD card,no info about the "memory solution" that was just mentioned but that's all even on mytero.net.Second: nobody said the solution is recent or new.Third:Have you posted STEP by STEP solution deeply detailed for beginners who cannot even imagine what's the PDA at all? NO Why do you pick me? Before you do that read carefully what I have listed. By the way don't be jelous! I'm not that as**ole who keeps the info inside of himself then just starts requestioning (getting post number along with "stars" ) rather than doing accurate support. Like it or not this is the ONLY useful STEP by STEP solution to unlock Treo 600 because if you follow the steps you don't need to spend hours on the net to find out how to do it exactly.Your posts and links just take people in the jungle...What I have done is just collected the informations from the NET then Put them together.I hadn't said I discovered the Treo 600 Unlock solution!!! BR |
01-27-2005, 10:35 | #7 (permalink) |
Member: 31049 Status: Offline Thanks Meter: 4 | read old post,but not only 1st page you will find "memory solution" I dont like free solution thet was reason thet I didnt put it here... When I help to made this unlock solution I was charge 50e for unlock... But thet was all long ago..... |
01-27-2005, 18:37 | #8 (permalink) | |
Member: 8985 Status: Offline Thanks Meter: 3 | Quote:
Yes you're probably right.New solutions are not for free but when I started to work on my first treo I just ran into a problems.When it finished realised the method is old and people know it just nobody wants to make it clear.It took more stress and spent hours what it should have been...Certainly I read the topics about it even on mytreo.net the issue was same,I just got pissed off because of people keep requestiong... therefore I have put the available informations and my experience together. I did a mistake too,left one word out of the subject "first USEFUL or CLEAR step by step..." also should have been posted like that "special thanks to mytreo.net" Finally I do apologise for being rude about the previous reply felt you guys complained copyright however I still reckon it's not fair. I was gonna help,got picking.No worries I don't really bother about it now,it's not the first time when someone wants help then got pick instead of appreciate. BR | |
02-02-2005, 09:27 | #9 (permalink) |
Freak Poster Join Date: Sep 2001 Location: ASIA
Member: 6569 Status: Offline Thanks Meter: 15 | Hello Spguru, After Loading Gsmup305.zip My Imei No Of The Treo 600 Gone Blank & Even Wireless Mode Does Not Get On. Before Updating It Was: Imei Nember: Xxxxxxxxxx77297 Hs Sn: Xxxxxxxxxx0pb Sa No: 100123433 Firmwire: 03.05 Software: Treo 600 -1.12-ouk Hardware: B After Updating It Is: Number: Imei Number: Hs Sn: Xxxxxxxxxx0pb Sa Number: Firmwire: Software: Treo 600-1.12-ouk Now What To Do, Pls Help |
02-03-2005, 17:36 | #12 (permalink) | |
@ SPGURU, Although solution has been posted it is true you have posted a good tutorial for those in the dark. So I will give you crdit for that. Regards, JOHNNY. | |
03-02-2005, 21:07 | #13 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Manila, Philippines
Member: 10541 Status: Offline Thanks Meter: 8 | @spguru hello! would you you mind sending me the tokenwriter program coz i have some difficulty downloading it. and one more thing, can this program change the imei of the treo600? thanks and more power!!!! mvr my email: [email protected] |
03-03-2005, 06:00 | #14 (permalink) | |
it can repair imei but i have never tried.might work. | |
03-03-2005, 08:28 | #15 (permalink) |
No Life Poster Join Date: Sep 2003 Location: WATCHING YOU
Member: 38562 Status: Offline Thanks Meter: 1,478 | [QUOTE=spguru]here you go... remove .txt extension! it can repair imei but i have never tried.might work.[/QUOTE ur not sure ....not working for me... |
treo 600 unlock | zeroiceone | PalmOS /HP and others | 154 | 10-27-2010 15:45 |
treo 600 unlocker | jache_1011 | PalmOS /HP and others | 5 | 10-02-2006 00:48 |
Treo 600 Unlock?? | Moto A630 | Smart-Clip | 1 | 03-17-2005 09:55 |
treo 600 unlocking | mobile star | Various | 2 | 06-07-2004 07:10 |
Please Help: Treo 600 Unlocking | vish0402 | Phone Unlocking Codes & Maps | 1 | 12-31-2003 18:30 |
