Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > PalmOS /HP and others
PalmOS /HP and others Palm, Treo, Sony CLIΙ, Tungsten, Zire, Handspring and other Palm Operating System based Devic
Old 12-19-2008, 14:51   #15061 (permalink)
Member: 718168
Sonork: Treo650 507mhz, Nokia5800
Thanks Meter: 441
Originally Posted by myblackz28 View Post
How much ram do u usually keep free?
I have a treo 650 and mine has 6.4 mb free. I have 278 apps installed, mostly on my card. I need to free some more memory because the big games need more space to run when they are copied to the main memory with zlauncher, but mostly run very well. It its very stable.
Old 12-19-2008, 15:17   #15062 (permalink)
Member: 725754
Thanks Meter: 65
Originally Posted by r_castro View Post
Use "palm internals" and check the system alarms and see if at the time your phone wakes up there is a alarm and what app is doing this. Could be a background app, callfilter can do that when it gets a sms, powerman turns on display when it changes profiles, etc...
Palm internals? is that an app i need to install? I dont have any of those apps u mentioned. I also have 6.4mb ram free.
Old 12-19-2008, 15:47   #15063 (permalink)
Member: 725754
Thanks Meter: 65
So I downloaded palm internals. Here are the results:
Alarm information:
•12/19/08 22:00:05 'Butler' m68k 731A9E8A
•12/20/08 03:00:00 'BackupMan'
•1/22/09 00:00:00 'Contacts-PAdd'
•4/5/09 02:00:00 'Date & Time' ref 00000002
•4/11/09 21:00:00 'Omer'
Total alarms: 5
Notify information:
count 234 of 235
–––-pdb–––Protected database deletion
•0 'Butler'
•4 'VolumeCare'
•5 'Luach'
•6 'MultiUserHack5'
•11 'Hebrew'
•15 'Ringo'
–––Hwap–––
•27 'Ringo'
–––KEY!–––
•28 'Butler'
–––NAG!–––
•29 'Butler'
–––bsbc–––
•46 'Butler'
–––hapl–––
•95 'Butler'
•96 'PrefDoctor'
•97 'VolumeCare'
•98 'MultiUserHack5'
–––hapq–––
•99 'BackupMan'
–––hede–––
•100 'Butler' m68k 731B0666 DBCache
•101 'TopAreaCodes' m68k 644F2D80 Dyn pri 32
–––hots–––Hotsync started
•108 'Butler'
•113 'VolumeCare'
•114 'Luach'
•115 'MultiUserHack5'
•121 'Hebrew'
•125 'Ringo'
–––lazy–––Late wakeup
•133 'Butler'
•134 'UDMH'
–––nuts–––
•162 'Ringo'
–––rstf–––Reset finished
•170 'Hebrew'
•171 'BackupMan'
–––scrs–––
•175 'PalmInternals'
–––slp!–––Before sleep
•182 'UDMH'
–––slpq–––Ack about sleep
•186 'Butler'
–––sync–––Hotsync finished
•200 'VolumeCare'
•201 'Luach'
•205 'Hebrew'
•209 'Ringo'
•210 'WordView+'
–––volm–––Volume mounted
•223 'BackupMan'
I have no idea what this means!
Old 12-19-2008, 15:47   #15064 (permalink)
surfsup1's Avatar
Member: 631598
Thanks Meter: 267
Phone resets
I know this might not be the place to post this but you guys have been very helpful.
This problem happens occassionaly on my treo650:
Sometimes when I want to use the phone, I will press the red button to wake up the screen and nothing happens. About 15 seconds later the screen will wake up and any button I press will not do anything and then the screen goes back off. To resolve this, I do a soft reset and the phone works fine. Ive done hard resets and started from scratch. This problem still happens. And the weird thing is, I notice it happening only when im at work in the city. It wont happen at home. Could the location be messing up the phone? Is that possible? Anyone else have such a problem?
You might also try to install the Safeguard app which is on this forum (just search) and it will usually tell you what app on the phone is causing the reset. It isn't always 100% correct but at least it will give you some clue so that you can start troubleshooting. Hope this helps.
Surfsup1
The Following User Says Thank You to surfsup1 For This Useful Post:
Old 12-19-2008, 15:54   #15065 (permalink)
Member: 725754
Thanks Meter: 65
Surfsup1
Ive tried safeguard. That doesnt really tell me anything. The phone doesnt reset. Sometimes when I wake up the screen, it takes like 15 seconds for the screen to go on and once its on, it takes the keygaurd another 15 seconds to respond so thats when I do a soft reset and it works fine till the problem happens again. Like i said, it only happens when Im at work. Maybe sumthin messes up when the signal is weak? I have no idea. How frustrating!
Old 12-19-2008, 16:06   #15066 (permalink)
surfsup1's Avatar
Member: 631598
Thanks Meter: 267
Does it only do it when you wake the phone with the red power button? Have you tried using another button, like the applications button to wake it? It should wake when you press any of the four function buttons (ie phone, email, calendar or apps). In your original post you said when you press the red button is when it does it.
Old 12-19-2008, 16:10   #15067 (permalink)
Member: 725754
Thanks Meter: 65
Im pretty sure its any of the functions buttons, not just the red.
Old 12-19-2008, 16:28   #15068 (permalink)
surfsup1's Avatar
Member: 631598
Thanks Meter: 267
That is odd! I wouldn't think that a weak signal would cause the problem. It sounds like it is some app or a piece of an application that remains in memory that could be causing the problem. You might try backing up your phone with Resco Backup (on this forum), then do a hard reset then install the Uninstall app (also on this forum) and reinstall all your apps one at a time with the Uninstall app on your phone first which monitors your installs and allows you to remove all pieces of code if you later uninstall an app. I know that is a bit drastic but it could be the solution. Does anyone else have a solution? I know how frustrating it can be. I am having a problem with DTG and a corrupted excel file. Good luck. Sorry I don't have a firm solution.
Old 12-19-2008, 16:33   #15069 (permalink)
Member: 725754
Thanks Meter: 65
I did a hard reset and installed one app at a time. And still. The problem doesnt always happen. A day or 2 can go by and its fine. But it only happens at work!
Old 12-19-2008, 17:20   #15070 (permalink)
Member: 802826
Thanks Meter: 5
Hi King i downloaded the TomTom navigator for centro
I'm guessing because i have a centro i need to buy a device that can provide GPS for me
But i saw in your instructions that you stated to do the steps over again with the us maps
I searched for TomTom maps and i saw the one you got from a torrent
I don't know how to use torrents
Is there a US Maps with MIDI Files included (like the Guam file included in the download)
Thanks in advance
Old 12-19-2008, 18:04   #15071 (permalink)
kingtyce's Avatar
Member: 457382
Sonork: 700p, Centro, Pre, Evo, I
Thanks Meter: 4,362
Cool
Thanks in advance
There is no US Map with midi files included.....It is too large....That's the reason why it's in a torrent download....
Old 12-19-2008, 20:17   #15072 (permalink)
Member: 802826
Thanks Meter: 5
king does that mean i can put the us map torrent on the card?
Or is there another step or process i need to do
Thanks in advance
Old 12-19-2008, 20:24   #15073 (permalink)
Member: 723458
Smile QuickIM
Has anyone a keygen or a key for QuickIM ? QuickIM 1.4.0 13a
Thanks in advance
Old 12-19-2008, 20:34   #15074 (permalink)
kingtyce's Avatar
Member: 457382
Thanks Meter: 4,362
Cool
Thanks in advance
Yes, that's the only place it can go.....It says so in the instructions included in the download
The Following User Says Thank You to kingtyce For This Useful Post:
Old 12-19-2008, 20:38   #15075 (permalink)
Member: 802826
Thanks Meter: 5
My bad thanks King
Pocket PC Appz & Games HuBMOBILE HTC & PDA WM( With Touchscreen) 8202 12-12-2018 03:44
Nokia Latest Appz & Games Section HuBMOBILE Nokia Multimedia 17 11-21-2010 13:03
Palm OS Appz & Gamez LBOZ_GSM PalmOS /HP and others 1014 05-05-2009 21:45
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% usman8416 Nokia Multimedia 0 06-24-2008 21:01
WM5 Pocket PC Appz & Games eboy44 HTC & PDA WM( With Touchscreen) 2 08-08-2006 22:23
Page generated in 0.50743 seconds with 9 queries
