PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
11-16-2006, 14:47 | #1607 (permalink) |
Freak Poster Join Date: Oct 2006
Member: 371901 Status: Offline Thanks Meter: 6 | Reset Doctor 1.4 beta Anyone have this patched or can patch it ? Reset Doctor 1.4 beta formerly pref Dr by hobbyist software http://www.hobbyistsoftware.com/downloads.php |
11-16-2006, 16:14 | #1608 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 390425 Status: Offline Thanks Meter: 4 | Ok I tested out Universe 3.0.3 on the treo 700p. It hasnt made my phone reset (yet). I tried opening the app, closing the app, using volume buttons on side (i tested these because some apps will crash when you do that! I learned the hard way), tried different menu options (not all of them) and everything seems to be working fine. The only issues so far that i've seen were when you try to open certain websites, the browser just tries to connect and it goes through this redirecting, receiveing, redirecting, etc... cycle and it eventually reaches its redirect max limit and stops there. Dosnt happen with all sites but some of them. And some of them it just wont connect to the site. Anyway, the browser is nice. I really like it. Cant wait for the final release! Just thought I'd share my experience with yall if anyone wanted to know how it worked with the 700p. |
11-16-2006, 16:33 | #1609 (permalink) | |
Freak Poster Join Date: Jul 2006
Member: 316665 Status: Offline Thanks Meter: 9 | Quote:
11-16-2006, 16:57 | #1610 (permalink) | |
Insane Poster Join Date: Nov 2006
Member: 385260 Status: Offline Thanks Meter: 6 | Quote:
syncname = "Dmitry" Last edited by neilyoung; 11-16-2006 at 21:06. | |
11-16-2006, 17:03 | #1611 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: www.th3palmz.com/th3palmz
Member: 361063 Status: Offline Thanks Meter: 2 | Quote:
11-16-2006, 17:08 | #1612 (permalink) |
Member: 390425 Status: Offline Thanks Meter: 4 | does anyone happen to have a keygen or patched mRing v3.3.3? The keygen I found here dosnt work. I searched but that was the only thing I found. Maybe I overlooked it? Thanks a lot! |
11-16-2006, 18:04 | #1613 (permalink) |
Member: 385260 Status: Offline Thanks Meter: 6 | Download the latest versions of Namco games from http://palm.namcogames.com/ attached is the keygen (run with ie) |
The Following User Says Thank You to neilyoung For This Useful Post: |
11-16-2006, 18:31 | #1615 (permalink) |
Insane Poster Join Date: Oct 2006 Age: 43
Member: 370919 Status: Offline Thanks Meter: 0 | Neither did I... btw, is there any way to use it without the stylus? Like in blazer you can use up and down to select links and right and left to scroll up and down (or is it the other way around). I can't seem to select links or inputs without the stylus. I've run into the redirect thing as well. It will be nice when that is fixed. The other weird thing I've seen is that text input boxes let me enter multiple lines of text. I thought that was pretty funny. |
11-16-2006, 18:56 | #1616 (permalink) |
Member: 385260 Status: Offline Thanks Meter: 6 | Follow the keygen instructions and all is well. I just tried it on a treo 650, shows as registered when I select the Register menu option. Remember that there are some hardware-specific features in the license, so you have to run the keygen on the actual PDA that you want to register. When registering, I used the same made-up 5-digit registration code as when I ran the keygen, not sure if they actually have to be the same or not. Here's what I did: - Installed MRing 3.3.3 - Installed LMReg.patched (note, it's older than the one it replaces) - [I was testing on a PDA that had never been hotsynced, so in MUH, I assigned the same name to LMReg, mLicense, mRing. You shouldn't need to do this step if you already have a hotsync ID] - Ran mLicense, entered 12345 - Don't connect to internet, reg. manually - Wrote down 16 8-digit codes (ignore any garbage after the 1st 8 hexidecimal characters) - Installed original LMReg.prc - entered 12345 - Don't connect to internet, reg. manually - Entered code #6 of the 16...it works! the patched file lmreg is in the old version here: http://rapidshare.com/files/3616313/...patch.zip.html the new version is here (install first): http://rapidshare.com/files/3613832/mRing650.zip.html follow directions and it'll work. |
11-16-2006, 20:22 | #1617 (permalink) |
Member: 390425 Status: Offline Thanks Meter: 4 | aight thanks. i followed all directions and it finally told me that this version is not compatible with my device (700p). this is only for the 650 that ***** because on the mRing website it says that it will run on the 700p. but anyway, appreciate your help |
11-16-2006, 20:30 | #1618 (permalink) | |
Member: 371901 Status: Offline Thanks Meter: 6 | Quote:
u dont need that program on the 700p , u can already assign individual ringers for specific contacts... | |
11-16-2006, 20:38 | #1619 (permalink) |
Member: 390425 Status: Offline Thanks Meter: 4 | well thats not really what I need it for. I have certain calls that I want to send directly to voicemail or silence. I've already assigned different rings for people. this is all I really want mring for. if there's any other app out there that can do the same thing i will give it a try. I tried callfilter but that didnt work on my model either. thanks |
11-16-2006, 20:51 | #1620 (permalink) |
Member: 371901 Status: Offline Thanks Meter: 6 | call filter didnt work..hmm was going to suggest that, u might want to try lightwav, also in this forum i can send u a silent ringer, lol then u can assign that to callers that u want to go to v/m i actually think the 700p comes with a silent ringer for default, check it out the attachment is a ringer which states unidentified voice call, good for private callers Last edited by italiangspot; 11-16-2006 at 21:26. |
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
