PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
11-18-2006, 19:14 | #1712 (permalink) | |
Freak Poster Join Date: Oct 2006
Member: 371901 Status: Offline Thanks Meter: 6 | Quote:
11-18-2006, 19:47 | #1715 (permalink) | |
Insane Poster Join Date: Oct 2006 Age: 43
Member: 370919 Status: Offline Thanks Meter: 0 | Quote:
For the most part it works pretty well. If they would release a version that works properly with the 700p, and if they would fix the problems with keylock then I would be happy. | |
11-18-2006, 20:36 | #1716 (permalink) |
Freak Poster Join Date: Oct 2006 Location: www.th3palmz.com/th3palmz
Member: 361063 Status: Offline Thanks Meter: 2 | errr... uh... i can't seem to get MobiTV to do anything on my (now functioning again!) LifeDrive. and NesEm briefly flashes on then exits... any tips? Last edited by iamajd; 11-18-2006 at 20:49. |
11-18-2006, 22:12 | #1717 (permalink) | ||
Freak Poster Join Date: Nov 2006
Member: 383736 Status: Offline Thanks Meter: 9 | Quote:
I havent heard of any program that does that,, only way I know of is if you reboot your modem and while your rebooting hope that a different person on the same isp gets assigned your previous number.. Then the DHCP will just give you a new one.. Sometime one modem reboot(unplug/plugin power cable) will do it and sometimes after 20 reboots you will still have the same IP.. So its all luck I guess... | ||
11-18-2006, 23:49 | #1718 (permalink) |
Member: 383736 Status: Offline Thanks Meter: 9 | OK this *****,, I got my new card today 2G Sandisk UltraII. I was under the impression that I could just copy all my crap with my pc from card to card. This is not the case. First try I just made a new folder on my desktop and dragged all my old cards contents to it. Then I inserted the new card and copied all if it to the new one. I then put the new card into my treo and I get a popup that says the card is not formatted.. ok so I format it and put it back into my pc. I drag the files and drop into corresponding folders.. Put it back into my treo and try to lauch a shortcut from zlauncher and it removes the card from the menu.. I remove and instert the card again(treo) and try to navigate to the card tab in zluancher and it errors out and makes the card dissapear again.. No programs that I have on the card work.. I have used power run to make shortcuts and also just recently set up zluancher.. I dont want to start all over. I have searched but figured I would ask here first.. Any way to do what Im trying to do? Thanks Blind EDIT Ok the original card is a transflash 256M that I used to use in my V710 with an sd adaptor... The new one is 2G regular sd card,, Sandisk UltraII. I had another sandisk 256M full size card laying around that I used to use in my camera.. So I did a test and copied all the files from the original card to the card I had laying around... EVERYTHING WORKS.. So,, Do I have a bad 2G card? or does the treo support 2G? Whatcha think please? Thanks thanks.. Last edited by BlindDude; 11-19-2006 at 00:37. |
11-19-2006, 01:22 | #1719 (permalink) | |
11-19-2006, 01:25 | #1720 (permalink) | |
Member: 364604 Status: Offline Thanks Meter: 8 | Quote:
NesEm should work as long as the OS is higher than 5.0, and that shouldn't be the problem with the device you have. v1.9 should be the one you are using. | |
11-19-2006, 02:36 | #1722 (permalink) | |
I will install 1.9 if I can find it. | |
11-19-2006, 06:18 | #1725 (permalink) | |
When adding a file like that erases all other bookmarks. And since I had made like 7 or so of my own, when I loaded that one, I lost all the other ones. I first loaded your original, then added a handful of my own, then thought... Hey, this will add all the others that aren't already on there, but all it did was overwrite what was on there. So as a caution for other, unless you've backed up stuff like I did, and could go into resco and select the files, and bam, back to normal, you'll lose any bookmarks you may have, so be warned. It should just add them, or heck, i'd even be happy if it re-added, and you just deleted a duplicate, but that kind of ***** it can't do one of those two, and all it does is replace. I don't think there is an option otherwise unless i'm missing something, but maybe that should be a future request. | |
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
