PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
10-22-2006, 03:11 | #586 (permalink) |
Freak Poster Join Date: Oct 2006 Location: www.th3palmz.com/th3palmz
Member: 361063 Status: Offline Thanks Meter: 2 | WebPro on LifeDrive |
10-22-2006, 03:30 | #587 (permalink) |
Member: 361063 Status: Offline Thanks Meter: 2 | NetFront v3.1 r2.0.34 Here are all the files I needed to install NetFront Pro on my LifeDrive. This may not work for everyone because MaxX, a required file, only works for a limited number of devices. http://rapidshare.com/files/195868/nf31.rar.html For more info on MaxX: http://palmpowerups.com/modules.php?...details&lid=21 Please report whether this does or does not work for you and what device you are using. |
10-22-2006, 04:00 | #590 (permalink) | |
No Life Poster Join Date: Oct 2006
Member: 363899 Status: Offline Thanks Meter: 38 | Quote:
I tried to figure out that prc edit but man NO CAN DO! can anyone give a SIMPLE laymans explination on that I realy need these 2 apps udmh - unlimited dynamic memory hack Description: the famous UDMH Version: Filesize: 0 bytes Added on: 06-Aug-2005 Downloads: 33063 Rating: 8.0 (6 Votes) HomePage | Rate Resource | Details UnCache Description: Set Waht programs get to launch at reset. This can speed up the boot process and free up DbCache on NVFS device | |
10-22-2006, 04:23 | #591 (permalink) | |
Freak Poster Join Date: Jan 2006
Member: 226491 Status: Offline Thanks Meter: 21 | Quote:
About the privacy software....AppLock... | |
10-22-2006, 04:36 | #592 (permalink) | |
Freak Poster Join Date: Jul 2006
Member: 316665 Status: Offline Thanks Meter: 9 | Quote:
10-22-2006, 05:03 | #593 (permalink) | |
Still looking for MapView and Virtual Pool Mobile patch.... Last edited by wheeliestunt; 10-22-2006 at 05:14. | |
10-22-2006, 05:31 | #594 (permalink) |
Member: 226491 Status: Offline Thanks Meter: 21 | Let's see.... Pocket Mini Golf Full....I have Pocket Mini Golf Extra Full....I have IconsPlus 2....I HAVE (this is a hard one) AppLock 1.12....Hell I have (VERY hard to find) But before I post them I'd like to get a little back from all I've already posted... I need Virtual Pool Mobile 1.46 patch or keygen, not serial as I want to get rid of MUH.... MapView (from www.indevsoftware.com) patch or keygen.... Bhajis Loops (from www.chocopoolp.com/bhajis). This is an easy one as I need an old version like 1.5 and down (not patched)....someone may have it in their hard drive.... Lastly, OnLaunch 1.71 (or somewhere arond. The same, not patched. http://slawa.homeip.net/palm/onlaunch.html) which is also an easy one as someone may have it laying around.... Please take a look into your old files and the new ones I'm looking for....I just need those and I have a LOT to give....BTW, how did that UnCache worked? |
10-22-2006, 09:23 | #596 (permalink) | |
Freak Poster Join Date: Aug 2006
Member: 325718 Status: Offline Thanks Meter: 48 | Quote:
For Articulation: I don't think I can patch it. They have changed their protection so that it doesn't show up anything whe nteh 45 secs are over. That means it is hard to find a place where to patch the app. | |
10-22-2006, 09:31 | #597 (permalink) |
Member: 325718 Status: Offline Thanks Meter: 48 | I tried these apps, but you can't patch it, the code is encrypted and sometimes native ARM which can't be read by the decompiler. Serials do not work because they're HS-Name dependent and the tools detect MultiUserHack and HSNSwitch. But you can edit the SavedPreferences in order to renew the trial: navigate to the entries with the creator ID "psys" the entry with the number "3200" has to be deleted then it works again. When the trial is over a one-day trial is activated. Then an other ID again "psys" with nearly the same number is created. Delete it again, and trial is reset. |
10-22-2006, 13:53 | #600 (permalink) | |
share your source? | |
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
