PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
02-25-2008, 11:32 | #7503 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: super saiyan BLOCK,G-O-Ds CITY
Member: 678547 Status: Offline Thanks Meter: 30 | Quote:
yup!! i was just wondering if there is another way to log onto ******** i want to view that forum thanks LD | |
02-25-2008, 11:32 | #7504 (permalink) | |
does it work with macbook???? | |
02-25-2008, 11:57 | #7505 (permalink) | |
ok.... so the mundu im i posted on page 499... that's what i think it is ... that particular patch of mundu im works fantastic with the LD install the latest build frm mundu and overwrite with the patch all other patches might cause crashes to you i used to use this patch frm a long time but i heard about 4.1 and installed that it was 4.0 only but it caused many crashes so go in for the patch on pg 499 it's the best patch ever created for mundu it won't even say that it's a trial version and ask you to register enjoy LD | |
02-25-2008, 12:03 | #7507 (permalink) | |
hey mike ... what URL do you use.????? the one i use... http://www.********.com/********/... it only says that the connection has timed out and it's the same from like ages thanks LD | |
02-25-2008, 12:19 | #7510 (permalink) | |
i really want to view the site LD | |
02-25-2008, 12:19 | #7511 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: New York where the Giants roam Age: 34
Member: 457382 Status: Offline Sonork: 700p, Centro, Pre, Evo, I Thanks Meter: 4,365 | Quote:
here is the newest version of chess HiArcs v9.7. with keygen. first you need to extract folder. do not remove any files from folder, because that is part of the process. then run keygen(TM_HiaArcs). keygen will create an ARM patched file in folder. install the HIarcsARM_patched file and hbookmed file to your device. then run hiarcs chess after installing it. it will say unregistered. this is where we use keygen again. you should see reg code on the uregistered screen. reg code should look something like this for example: A1-27B9-9997-7E. you will type your reg code in your keygen but you are going to replace the second digit with a zero. so it should look like this. A0-27B9-9997-7E. then press enter. it will create a another file within the folder starting with HK1. install that file on your device and you are now fully registered. if you have any problems just post your reg number and i will do it for you. | |
02-25-2008, 15:02 | #7513 (permalink) |
Member: 457382 Status: Offline Sonork: 700p, Centro, Pre, Evo, I Thanks Meter: 4,365 | here is braingym v1.2 http://rapidshare.com/files/94795075...ob1_2.rar.html reg with W4W5T-V5K8B-Y6F6N-S4Q9C |
The Following 3 Users Say Thank You to kingtyce For This Useful Post: |
02-25-2008, 16:00 | #7514 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: $Dollorado$
Member: 691050 Status: Offline Thanks Meter: 74 | Quote:
LD, I'm just typing in www.********.com delete everything in the address bar including the http://. And only put in www.********.com or the actual site is www.********.com/login.php I clicked on the link you posted and it just kept redirecting me over and over to a blank page saying it was redirecting me.....lol, I could see that was happening over and over again. Last night when I just copied and pasted the link in my first response telling you it is back up, I clicked on it to see if it would take me there. It came up with some warning page saying this wasn't suppose to happen.....so Don't copy and past the link I have posted. For some reason you HAVE to Manually put the address in. Hope this helps. And yes, at that site they do Have basically everything for PALM OS EVER MADE. Even stuff you never heard of or thought of. Just to let you guys also know I found a SUPER AWSOME SITE for WINDOWz OS this one site has EVERYTHING....I MEAN REALLY EVERYTHING FOR WINDOWZ and I even found 2 Palm OS apps....Kinda like here but this is Palm OS. Register is free and I haven't found any Virus or anything like that at all at this site. Here you guys go enjoy. www.warezws.com WHO MIKE JONES!!!! Last edited by MIKEJONES13; 02-25-2008 at 16:08. | |
02-25-2008, 17:41 | #7515 (permalink) |
Junior Member Join Date: Dec 2007
Member: 641910 Status: Offline Thanks Meter: 4 | Lifedrive: Could we tone down the multi-color, huge-font, twenty-spaces-between-lines posts? And then quoting those posts in your own follow-up posts? Is what you have to say that much more important than what anyone else has? From the looks of it...not usually. Do you crave attention that badly? From the looks of it...absolutely. |
Pocket PC Appz & Games | HuBMOBILE | HTC & PDA WM( With Touchscreen) | 8203 | 12-05-2019 14:12 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Palm OS Appz & Gamez | LBOZ_GSM | PalmOS /HP and others | 1014 | 05-05-2009 21:45 |
Nokia N73 Appz and games collection.Binpda+get unsigned appz signed with secman.100% | usman8416 | Nokia Multimedia | 0 | 06-24-2008 21:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
