PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
12-14-2008, 08:17 | #1 (permalink) |
Junior Member Join Date: Dec 2008
Member: 922749 Status: Offline Thanks Meter: 0 | Software/App/Game install without hotsync, How to |
12-14-2008, 16:51 | #2 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: New York where the Giants roam Age: 34
Member: 457382 Status: Offline Sonork: 700p, Centro, Pre, Evo, I Thanks Meter: 4,365 | Quote:
If you don't have a hotsync ID then you can install MUH to your centro and create one.....also you can install your apps and game through the card reader on your pc to your sd card.......You will also need Resco Explorer once you install the apps on your sd card......Resco Explorer will allow you to move files from your card into your centro's main memory..... MUH and Resco Explorer can be found on this site by doing a search located at the top of the page.....Make sure you choose show posts and not show threads while using the search......good luck..... if you have more questions, feel free to ask anyone on this site....you will get an answer | |
12-15-2008, 07:50 | #3 (permalink) |
Member: 922749 Status: Offline Thanks Meter: 0 | I've been using resco explorer and now am using MUH, I knew of it but the acronym was what confused me. Now I'm working on getting chex quest 1-3 onto my palm. They run as .wads and I've been using zdoom trying to get it to work right. |
12-15-2008, 22:25 | #4 (permalink) | |
I followed these instructions and got it to work...... Installation: Download the executable and unpack the .zip file. Place the .prc into /Palm/Launcher of your memory card. Place the .zdk into /Palm/Programs/ZDoomZ of your memory card. Now you need files from the original Doom 1 or 2. You can also use the files from the demo version. Place the .wad files into /Palm/Programs/ZDoomZ of your memory card. | |
12-16-2008, 08:49 | #5 (permalink) | |
Member: 922749 Status: Offline Thanks Meter: 0 | Quote:
On another note after installing MUH my centro has had random resets. I'm not exactly sure if MUH is the cause but its been happening more often. What is the best software or prog out there to test for apps that cause the crash errors and or fix them? | |
12-17-2008, 05:58 | #6 (permalink) | |
You can try either safeguard or dbfixit for the crash errors.....do a search..... MUH is more for the older models of palm os......try out hsnswitch...... do a search...... | |
12-17-2008, 09:23 | #7 (permalink) |
Member: 922749 Status: Offline Thanks Meter: 0 | I went ahead and setup Safeguard, I never heard of dbfixit anymore and I'm almost 100pct sure that the reset error loops are caused by MUH, Went and installed. hsnswitch will post results later. |
12-17-2008, 09:46 | #8 (permalink) | |
No Life Poster Join Date: May 2008 Location: C E B U C I T Y
Member: 774786 Status: Offline Thanks Meter: 1,455 | dbFixit 1.1b Quote:
DbFixIt for Palm OS® is a new utility that is designed to detect and repair errors in Palm OS databases. In particular, it knows the precise structure of the standard Palm OS and proprietary PalmOne PIM databases and can selectively repair those errors. Corrupt databases can cause all kinds of problems from crashing applications, hanging or crashing conduits, or causing unexpected errors such as retrieving the wrong record on a global find. DbFixIt is the first Palm OS utility to address all these issues. It will be especially of interest to those people who rarely sync with a desktop, or run into a corruption issue when no desktop is around to refresh the database from, or when the associated conduit just won't run. A one-touch Easy Ck. or Easy Fix button checks all the standard PIM databases and repairs them, making operation very simple. For advanced users, there is the ability to scan individual databases, backup and restore databases, and remove selected ranges of records. There is a feature that will scan every record in a database for a matching string and then allow the record to be deleted (useful if the application in question crashes when attempting to access a record that appears to be corrupt). DbFixIt has an unlimited trial period during which it will detect, but not repair errors. Only the registered version has the ability to repair errors and certain other functions are not available on the unregistered version. Registering the program also allows you to take advantage of further, advanced technical support to repair or recover damaged databases. Registering DbFixIt will then selectively fix the errors, and in all cases where it is technically feasible to do so, without losing the data in the record. Most importantly, registering DbFixIt includes further advanced support on specific issues related to the recovery and repair of corrupt databases more details here: http://www.pimlicosoftware.com/dbfixit.htm | |
The Following User Says Thank You to eon For This Useful Post: |
iPhone 3g v2.1 missing Installer and Cidya, how to install without restore? | Boshko_Alfa | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 12-27-2008 21:22 |
i have netmonitor software fore 7650 but don't know how to install,Please help | bankbang | WD2 & APE (Symbian Phones) | 6 | 07-15-2003 06:54 |
6210 without network, how to fix? | magnarpeder | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-11-2002 21:54 |
