PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic |
08-13-2008, 11:55 | #2 (permalink) |
No Life Poster Join Date: Jun 2003 Location: kinshasa, D.R.C. Age: 59
Member: 31246 Status: Offline Thanks Meter: 54 | Soft reset A soft reset will restart your Treo smartphone. This comes in handy if your device freezes, crashes, shows an error message, or exhibits unexpected behavior. This type of reset does not delete your personal data or the applications you've added. Instructions for the Treo 700w or 700wx: If charging, disconnect your smartphone from its charger. Turn off wireless mode by pressing and holding the red Power/End key . Turn off the screen of your smartphone and wait a few seconds¹. Take off the battery cover, then remove the battery for approximately one second. Re-insert the battery and replace the cover. Hard reset If a soft reset doesn't solve your problem, you may need to perform a hard reset, which deletes all data on your device, including Outlook information and add-on applications. Warning Before performing a hard reset, please read the section below regarding what data is backed up during an ActiveSync synchronization and how to restore your data. A hard reset deletes all information and third-party software on your smartphone. Never perform a hard reset without first trying a soft reset. You can restore previously synchronized information the next time you sync. Some third-party applications do not create a backup on your computer when you synchronize. If you perform a hard reset, you may lose data in these applications and you will need to reinstall the application after the hard reset. Please contact the developer to find out which data is backed up during synchronization. Why perform a hard reset? A hard reset can tell you whether a persistent problem stems from your smartphone or from an application installed on it. If you do not experience the problem after you perform a hard reset, the problem may be related to software you installed. How to perform a hard reset If charging, disconnect your smartphone from its charger. Take off the battery door, but don't take out the battery yet. Press and hold Power/End . While holding Power/End, remove the battery for approximately one second, then replace it while still holding Power/End. When you see "Erase all data?" you can release Power/End. Press Up to confirm the hard reset. If a language selection screen appears, pick the same language you use in your desktop software. |
9500 System Locked ????? | waleed2500 | Nokia Multimedia | 0 | 04-23-2005 14:58 |
9210 Lock Code . or System lock !!!!! | makona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 04-10-2005 10:09 |
9210 system locked | kurdi99 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-10-2002 04:42 |
9000 " system lock " | Goyang65 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-15-2001 19:13 |
