Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > PalmOS /HP and others
PalmOS /HP and others Palm, Treo, Sony CLIÉ, Tungsten, Zire, Handspring and other Palm Operating System based Devic
Old 06-19-2008, 18:46   #1 (permalink)
Member: 295919
Thanks Meter: 2
Red face treo 650 loop reset problem
Hi,
i have treo 650 and it has problem of loop reseting , i tried soft and hard reset but no results. also tried to do warm and zeroout reset as i read in online support forum , but my phone can't perform this two method . anybody know the solution ? plz help
Old 06-25-2008, 16:26   #2 (permalink)
Member: 780213
Thanks Meter: 6
I wonder if you are completing the hard reset cycle properly.
Forgive me if you already do this, but i suspect it may be because when you do the hard reset, you might release the power button too early. You should hold the power button until the progress bar on the screen has completed and the Palm logo appears.
Cod
The Following 2 Users Say Thank You to codpiece1960 For This Useful Post:
Old 06-25-2008, 16:30   #3 (permalink)
Member: 780213
Thanks Meter: 6
Also, your phone can perform a warm reset, but again you need to be sure that the Palm logo appears before you release the 'up' button.
After this, you have safe mode with all hack and extentions disabled, and you can delete any app that you have recently installed that might cause the reset loop.
After that, a pin reset will restore you treo to normal.
At least, that is the theory
Cod
The Following 3 Users Say Thank You to codpiece1960 For This Useful Post:
Old 06-29-2008, 20:03   #4 (permalink)
Member: 668986
¿instalaste alguna aplicación antes de que tuvieras el problema de loop reset?. Si es así, la aplicacion no es compatible con tu Treo 650. Tienes que borrarla y revisar compatibilidad.
Does any application installed before you had the problem of loop reset?. If so, the application is not compatible with your Treo 650. You have to delete and revise compatibility.
The Following User Says Thank You to television For This Useful Post:
Old 07-04-2008, 15:01   #5 (permalink)
Member: 295919
Thanks Meter: 2
Smile
Cod
hi friend
thanks for your reply but as u told i did all resets perfectly but i think my treo's rom may be totaly corrupted and thatswhy it cannot perform all this resets, so have u any solution to reinstall the rom of my treo650,also i have the rom tool downloaded from the net, but i dont have the ROM, so pl. reply if u have any solution. thanks again.
Old 07-04-2008, 16:16   #6 (permalink)
Member: 780213
Thanks Meter: 6
No, I am sorry. I do not have the full GSM ROM file. That got lost ages ago when I reformatted my laptop carelessly.
I do have my own custom ROM for unlocked GSM treo 650.
It does not have
Versamail
Real Player
Any other language than english
No tips files
But it does include
Blazer with fast mode
SDHC drivers and FAT 32
NV Backup
Resco Explorer 2008
If that is any good, I will try to send it to you.
PM me with your email.
Cod
Old 07-06-2008, 12:46   #7 (permalink)
Member: 295919
Thanks Meter: 2
Smile
It does not have
Versamail
Real Player
No tips files
But it does include
NV Backup
Resco Explorer 2008
Cod
hi dear,
plz send me the rom , my email id is [email protected],also guide me in brief so that i can restart my treo as before and also tell me one thing that my treo is of cingular ,import from usa and unlocked in india, so can i perform this operation with rom tool,
thanks again .also send me yr email plz.
Old 07-06-2008, 13:52   #8 (permalink)
Member: 780213
Thanks Meter: 6
My Treo 650 is GSM unlocked and unbranded, so I think I am correct in saying that my ROM would be incompatible anyway.
You should go to Treo Central and read the thread here <link> to see if there is anything there that can help you. The forum is brilliant for asking well thought out questions, so register free and someone will help you.
You should read the threads first and try to understand as much as possible before asking someones help.
Good luck
Cod
Old 07-10-2008, 09:56   #9 (permalink)
ibraheem0079's Avatar
Member: 524695
Sonork: 100.1590277
Thanks Meter: 154
man just go to shadowmite website and download the ROM from there, you also will find some customs ROMs.
Old 07-10-2008, 15:49   #10 (permalink)
Member: 780213
Thanks Meter: 6
OK that is true, but it states categorically in the threads at Treo Central that the Grack ROM tool is far safer to use and the risks are so small that even i learned the job
Cod
Old 06-14-2013, 14:00   #11 (permalink)
Member: 1549708
Thanks Meter: 19
Treo 650..reset problem ok..100%n\injoy...regkeypower and vol down..and in battary
The Following User Says Thank You to khairulislam For This Useful Post:
treo 650 unlock code problem dennis2003 Gsmfather The Wholesale Unlocking Database 13 05-20-2013 19:13
Reset Treo 650 ? Ibn'arabi PalmOS /HP and others 14 07-29-2011 20:24
My Treo 650 keeps on resetting ztreobot PalmOS /HP and others 3 01-21-2007 07:16
how to reset security code on treo 650 MichieMax PalmOS /HP and others 0 08-26-2005 10:44
Page generated in 0.18183 seconds with 9 queries
