Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Android based Phones / Tablets > _Games and App for Android phones
Old 08-24-2010, 21:46   #16 (permalink)
eyestrain's Avatar
Member: 237911
well its easy and simple as ABC process
just read it carefully and you will get it
Old 09-22-2010, 17:08   #17 (permalink)
Member: 1400421
Sonork: none
Hi guys
just down load this PC SUITE and u can manage and install all the application ( like pc suite )
PC Suite for Android Xperia X10-Manage Everything from PC » Gadgets | Technology Simplified
Old 12-05-2010, 16:39   #18 (permalink)
Member: 499615
Hi
I want arabic languge support alicition for my HTC Wildfire Android phone plz help me
Than you
Old 12-07-2010, 05:44   #19 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
@ zia811
Hi
There is no language solution for Android. only possible, that handset released for your continent. your country.
Old 12-10-2010, 03:25   #20 (permalink)
Member: 1234123
hi,
please help me
that i got xperia x10 mini (E10i),my device played by my friend
how can i remove the google account
when i open the "MARKET" menu
Android Market Terms of Service
Google Sign in
your entered the wrong password or your account has changed. please re-enter your password
user name: ****@googlemail.com
Password: ?????????
i dont know that password (device played)
please help me
thanks in advanced
Old 12-25-2010, 10:27   #21 (permalink)
Member: 319447
@ rangasuran
reset phone from inside menu. erase everything. set up everything from start. so u ll be able to setup with a new Gmail acc.
Old 01-06-2011, 17:56   #22 (permalink)
josebraga's Avatar
Member: 850071
I have a HTC HD2 as Windows operating system,
I would like to to use Android ,
how?
Old 01-08-2011, 04:43   #23 (permalink)
Member: 319447
how?
Make a specific thread for your problem or requirement. I ll go there.
Old 01-10-2011, 07:29   #24 (permalink)
Member: 1255232
how?
hi if you go to xda website there is loads of info for putting android on hd2 using a nand so no more windows mobile. make your phone look like htc desire hd ......
Old 01-14-2011, 20:28   #25 (permalink)
Member: 1248600
installation
Originally Posted by .:SUBRATA:. View Post
Android Phones - Installing Application
Many users asking about to install application into Android phones. here is a small tutorial. read this carefully so u ll learn how to do
-=No Application Request here.
Only Post if you ve question regarding installing application=-
How to Install Applications
To install applications using Android Market perform the following steps:
  • Open the Android Market application in the Applications menu.
  • You can select any option - Applications, Games, Search or My Downloads based on what you want to do. You will then get a list of applications or games to choose from.
  • You can also search for any particular application. You will then get a list of apps with their description and rating.
  • Click on the application you want and you will get more details of that application - the number of downloads and user comments.
  • To install it, just click on the Install button on the bottom of the screen.
  • In the next screen, it will give you more details about the application including the different functionalities it will need to access. Just click on OK to finish installing the application.
Using the Android SDK
There is one more method that can be used, you can install APK files into your phone using the Android SDK. Download the Android SDK.
First of all, install the Android SDK on your computer. You will also need to install the Android USB drivers to connect the SDK to your phone via USB. You can download it from here - USB Driver for Windows | Android Developers .
To install applications from other sources, you also need go to Settings -> Application Settings and enable Unknown Sources. Also go to Settings -> SD Card and Phone Storage -> Disable Use for USB Storage. You can enable it again later.
Next, just open Command Prompt and type: adb install path/file.apk
where path is the full path to the APK file and file is the name of the APK application file. Your application is now installed. This is all you need to do, now just open the application on your phone and use it.
Using the Application
You can rate and even leave a comment on the Android Market about the application.
To access the application, just go to your Menu and select the application you want to launch.
To check a list of all the applications you have downloaded, open up Android Market again and select the My Downloads option.
Check out some cool Android applications to install.
How to Remove Applications
To uninstall applications that you installed using the Android Market:
  • Open the Google Android Menu.
  • Go to the Settings icon and select Applications.
  • Next, click on Manage.
  • You will be presented with a list of applications you have installed.
  • Select the application you want to uninstall, and click the Uninstall button.
B.R
Subrata
How to install apps to storage card
Old 01-14-2011, 20:40   #26 (permalink)
Member: 1248600
How to install apps to storage. Card plz help me if u can. Thanks
Old 01-18-2011, 04:05   #27 (permalink)
Member: 396100
I need install flash player on my Galaxy 5500 upgrade froyo but cant running this app....
Any can help this prob.....
Old 01-21-2011, 10:07   #28 (permalink)
Member: 1353684
Sonork: hi
what is an android sdk ?
Old 01-22-2011, 00:54   #29 (permalink)
Member: 125632
sdk
system development kit....
Old 01-25-2011, 05:53   #30 (permalink)
amar181's Avatar
Member: 510122
Sonork: 100.1606547
how to install apps on memory card
hello
please tell me here that how to install apps on memory card.
the phone memory is only 70 mb and i want to install on mmc.
i want to do on htc tmobile g1
thanks
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 10 03-11-2013 15:27
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-16-2010 04:52
Page generated in 0.22541 seconds with 12 queries
