Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Android based Phones / Tablets > _Games and App for Android phones
Old 03-10-2011, 18:12   #31 (permalink)
mirzabaziz's Avatar
Member: 1185793
good information...
can you help, if andriod htc stop in Logo when On phone ??? or how we can flash an andriod phone ???
Old 04-23-2011, 18:06   #32 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.157????
Red face
Originally Posted by .:SUBRATA:. View Post
Make a specific thread for your problem or requirement. I ll go there.
hi sir i have Galaxy gt -p 1000 i need to install market i have a apps but i cant install from mmc pls help me i was full flash the phone but same
Old 04-23-2011, 22:12   #33 (permalink)
mirzabaziz's Avatar
Member: 1185793
can i get Spanish Language ROm of HTC Legend please...its urgent...advance thanks
Old 04-24-2011, 06:36   #34 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Install "Astro" using USB Cable + ADB Method.
After installing astro u can easily install any apps u want.
Old 04-24-2011, 14:48   #35 (permalink)
Member: 276151
Sonork: 100.157????
Question
hi sir Astro ? can you give that links & all so how to use that
Old 04-25-2011, 06:43   #36 (permalink)
Member: 319447
http://subrata.mobi/astro.apk
The Following User Says Thank You to .:SUBRATA:. For This Useful Post:
Old 04-25-2011, 12:34   #37 (permalink)
athreyu_v6's Avatar
Member: 772925
go to Gsm-beyond for more apps android sources
Old 06-25-2011, 17:58   #38 (permalink)
Member: 417008
Android Phones - Installing Application
Many users asking about to install application into Android phones. here is a small tutorial. read this carefully so u ll learn how to do
-=No Application Request here.
Only Post if you ve question regarding installing application=-
How to Install Applications
To install applications using Android Market perform the following steps:
  • Open the Android Market application in the Applications menu.
  • You can select any option - Applications, Games, Search or My Downloads based on what you want to do. You will then get a list of applications or games to choose from.
  • You can also search for any particular application. You will then get a list of apps with their description and rating.
  • Click on the application you want and you will get more details of that application - the number of downloads and user comments.
  • To install it, just click on the Install button on the bottom of the screen.
  • In the next screen, it will give you more details about the application including the different functionalities it will need to access. Just click on OK to finish installing the application.
Using the Android SDK
There is one more method that can be used, you can install APK files into your phone using the Android SDK. Download the Android SDK.
First of all, install the Android SDK on your computer. You will also need to install the Android USB drivers to connect the SDK to your phone via USB. You can download it from here - USB Driver for Windows | Android Developers .
To install applications from other sources, you also need go to Settings -> Application Settings and enable Unknown Sources. Also go to Settings -> SD Card and Phone Storage -> Disable Use for USB Storage. You can enable it again later.
Next, just open Command Prompt and type: adb install path/file.apk
where path is the full path to the APK file and file is the name of the APK application file. Your application is now installed. This is all you need to do, now just open the application on your phone and use it.
Using the Application
You can rate and even leave a comment on the Android Market about the application.
To access the application, just go to your Menu and select the application you want to launch.
To check a list of all the applications you have downloaded, open up Android Market again and select the My Downloads option.
Check out some cool Android applications to install.
How to Remove Applications
To uninstall applications that you installed using the Android Market:
  • Open the Google Android Menu.
  • Go to the Settings icon and select Applications.
  • Next, click on Manage.
  • You will be presented with a list of applications you have installed.
  • Select the application you want to uninstall, and click the Uninstall button.
B.R
Subrata
Dear mr.subrata
Recently I am bought HTC wildfire. The problem is I am not able to download any applications from android market.
I signin in android market same mail id I was entered in my mobile initial setup.
but the message is coming that 'no android device avilable with this user'
wt I can do now ? Expecting solution fom u
Thanks in advancd.
The Following User Says Thank You to kamal_127 For This Useful Post:
Old 06-25-2011, 18:29   #39 (permalink)
Member: 1597506
Originally Posted by kamal_127 View Post
Dear mr.subrata
Thanks in advancd.
Hi
make necessary backup like contacts photos etc. make factory reset from inside menu. after hard reset login with your desired gmail id.
I believe after that u ll be able to get your apps.
B.R
Unlockcodedb
Old 06-26-2011, 07:58   #40 (permalink)
Member: 417008
Dear Mr. B.R
i did according to ur procedure. when i made hard reset my mobile reboot and start initial settings i was given my gmail id and connected to internet it sucessfully connected to google servers but same i open market no device found.
Again i made factory reset i was given another gmail account same above procedure. but still same problem.
Any solution ???
Old 06-26-2011, 08:23   #41 (permalink)
Member: 319447
Dear Mr. B.R
Any solution ???
Hi
I read ur problem, let me think about this. in the mean time leave ur S/N here. so i can ck something.
Old 06-26-2011, 14:23   #42 (permalink)
Member: 417008
Thank you Mr.subrata
my mobile model: HTC WILDFIRE A3333
My mobile serial no is : SH13APY02087
And one more thing is by job perpose I am living in sudan, there is any security reasons to google servers ??
I know applications is not request here but I need only one application. I am serching for that 'VOIPDISCOUNT 'dialer for my phone to make cheap international calls.
Need help from u
thanks
Old 06-30-2011, 08:00   #43 (permalink)
Member: 1603245
i have htc smart f3188 which have airtel logo i tried to upgrade but but still it shows airtel, and i cant find market in this phone????????
Old 07-09-2011, 15:19   #44 (permalink)
Member: 1612977
Copy the APK file to your Android’s memory card and insert the card into your phone.
Download and install the Apps Installer application from the Android Market
Once installed, the Apps Installer will display the APK files on the memory card.
Click and install your APK files.
Old 07-18-2011, 10:20   #45 (permalink)
Member: 1603245
its not showing application market in my htc.... only airtel application is there
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 10 03-11-2013 15:27
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-16-2010 04:52
Page generated in 0.40073 seconds with 12 queries
