05-28-2015, 07:20 | #1 (permalink) |
Junior Member Join Date: May 2015 Location: US
Member: 2392164 Status: Offline Thanks Meter: 1 | How to install apps on external sd card? |
The Following User Says Thank You to thebestappgames For This Useful Post: |
05-29-2015, 23:07 | #3 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | well I use adb a lot for installing apps ! and it saves my time cause clients here some are newbis 1st.. adb shell set-install-location 2 you type this and deafult apk are installed in sdcard 2nd which i prefer more adb install -s name.apk this method you use to install apk always 1 by 1 to sdcard ! and 100% work all the best ! |
06-09-2015, 21:08 | #4 (permalink) |
Junior Member Join Date: Feb 2015 Location: Pakistan
Member: 2341935 Status: Offline Thanks Meter: 1 | 1-Install apkinstaller on pc 2- download apks 3- connect phone with pc (usb debugging must be enabled) 4- open apkinstaller 5- check mark on sd card option 6- select apks and hit install button 7- smile |
06-09-2015, 21:10 | #5 (permalink) |
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | why use an app while you can try to be more pro and do it your self via adb commands ? ! you dont need a GUI |
07-15-2015, 20:05 | #8 (permalink) | |
Junior Member Join Date: Dec 2014
Member: 2309104 Status: Offline Thanks Meter: 5 | try using app FolderMount: Quote:
