12-10-2018, 04:47 | #1 (permalink) |
Junior Member Join Date: Jul 2018 Location: Los Angeles
Member: 2849208 Status: Offline Thanks Meter: 6 | How To Install SP Flash Tool Sp Flash Tool Is Used To Flash Stock ROM and Custom ROM based on scatter files. Used to fixed bricked MTK smartphones. Can be used top formatting, or erase your MTK device. Also useful for advanced memory testing and verifying and use to read or write parameters. SP Flash Tool Download Requirements These are the basic requirements that require to use SP flash tool. You are supposed to have a PC or a Laptop in order to execute the tool. As you are downloading the tool into your PC or a laptop, it is essential to have a proper USB cable to connect your mobile into the PC. Also, you have to install media Tek drivers. Before flashing your mobile, you have to take a complete backup of your mobile. It is essential to have Scatter file + files, you need to be flashed. How To Install SP Flash Tool Step Guide Step 1: Download SP Flash tool and unzip the Downloaded file. Step 2: Open SPFLASHTOOL EXE file and now load the scatter file by clicking on the scatter loading. Step 3: Remember to uncheck all the boxes. Step 4: Navigate to the recovery box from the list and load recovery image based on your device or the preference. Step 5: Notice that the recovery box is checked and also you will notice the recovery image location. Step 6: Turn of tour MTK smartphone. Step 7: Now connect your device and click on the Download button located on the top and if it asks you are supposed to click on the yes button. Rest will be done the SP flash tool. SP flash tool is yet a desktop support program and there is no APK version is available to download. So, in order to use the application, you have to own a PC and also it is asked to install the necessary drivers. There is no way to download SP flash tool APK format. before making use the Application to flash your handset, remember to backup all your existing data. The thank should be completely devoted to MediaTek Inc, for developing such a tiny tool for the usage of all the MTK users. |
