06-24-2019, 08:27 | #1 (permalink) |
Junior Member Join Date: Apr 2019 Location: Los Angeles
Member: 2905924 Status: Offline Thanks Meter: 6 | How to root Android 8.0 with Magisk What is Magisk? It is an open source rooting management tool that you can use for Android Oreo. There is the APK version for this tool but you should have a rooted device with TWRP recovery to download it. But there is another version of the application called Magisk Manager and it can be downloaded to any kind of Android device even the unrooted ones. You can use both of them in need. Installing a custom recovery When you speaking about custom recovery TWRP recovery is the best. it will allow you to safely work with the firmware of the internal system. When you want to root or flash a new firmware this is the tool that creates a safer environment for you. So go to its website and download the recovery tool. Make sure to follow a proper guide of instructions when you install it. If you like you can check the below video about it. Install Magisk Manager
Final Verdict It is true that Android encourages the user to root their device. But yet rooting android Oreo become a kind of a challenging. But with the right tool, you can do anything. Another benefit you will get by using this manager tool is it can hide your root status and download apps that do not run on rooted apps. So use it as you want. Try it first. |
