Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Android based Phones / Tablets > _Games and App for Android phones
Old 06-24-2012, 08:51   #1 (permalink)
akhtarmughal's Avatar
Member: 617073
Sonork: 100.1611349
How to Root HTC Incredible S on Any Firmware- Tutorial
htc incredible S smartphone can now be rooted easily with the help of a detailed tutorial and now in the due course of this article we will be checking out on how to root your device on the latest firmwares. In the coming days we will be checking out on how to update with many custom ROM firmwares along with the apps which require the rooting access. Follow all the instructions mentioned in this article so as to ensure that the procedure is carried out successfully.
Disclaimer: We should not be held liable for any damage caused in the process of rooting your HTC Incredible S. It is very unlikely that your device will be damaged if you follow all the instructions to the point which are mentioned in procedure.
Rooting information: Once the device is rooted, the warranty will get void. The only way with which the warranty can be restored is by re applying the update of factory firmware which we will try our level best to come out with the same.
All the data in your device should be backed up with the help of below mentioned steps so as to ensure that just in case if the data gets corrupted, the same can be restored with the help of below steps.
SMS – Use “SMS Backup & Restore app”,
Contacts
Sync with the Gmail application,
Call Log -
Call Log and Restore
Images, Songs, Videos, Files
– Copy to internal / External SD Card,
APN and MMS Settings
– Note down from the path “Applications > Settings > Wireless and Network > Mobile Networks > Access Point Names
Also, you need to make sure that the battery left is minimum of 60% and also the USB Debugging should be enabled in your device which you can do so from the Settings path.
Disable / uninstall all the security suites installed in your computer as these tools generally interrupt the rooting process.
So let’s gets started with a detailed guide on how you can root the device with a detailed Procedure to Root HTC Incredible S:
  • Create a folder named as “Downgrade” in your computer’s desktop and then download the “Download kit” from here to your computer.
  • Up next, create a new folder in “Downgrade” as “Downgrade Kit”. Extract the downloaded Download Kit into the “Downgrade Kit” and then open the folder and click on the “runme.cmd” executable file in your computer. Up next you need to make a new folder inside the “Downgrade” folder as “RUU”.
  • Download this and save it to folder ‘RUU’. Connect phone to computer, and choose ‘Charge Only’ not ‘Disk Drive’. Enable USB Debugging, and disable Fastboot.
  • Open runme.cmd file and then you just need to follow the on screen instructions. Once it’s done, you now need to run the RUU in the RUU folder (Remember it erases all data so if you need to, backup everything).
  • Now, you will see that the HBoot version will be 1.12.0000 which you can find it out from the Settings > About Phone.
  • Now, you will have to visit the revolutionary.io website and click on the “Download for Windows” and then download plus extract the .zip folder to fill in the boxes for the beta key.
  • After this you will have to fill in the details like,
Your Operating System: Windows/Linux (Depending on yours)
Your Device: HTC Incredible S
HBOOT Version: 1.13.0000
Serial Number: (Your serial number)
  • Copy and paste the beta key in the notepad file and then you will have to save the same in your desktop. Ensure that all the data is correct and is correct.
  • Connect phone, choose ‘Charge Only’, enable USB Debugging and disable Fast boot mode. After this run the revolutionary.exe file and when it asks you to input beta key, enter the same.
  • When it asks you whether you want to flash Clockwork Mod Recovery, type y and as soon as this task is done, the cmd will close.
  • Ensuring that you have S Off the boot loader, you can now proceed to rebooting the device into boot loader if you are not and then open up recovery, it should go to Clockwork Mod Recovery.
  • While phone is in Clockwork Mod, connect phone to computer, select Mounts and Storage by using the volume buttons to move and power to select.
  • Select mount sdcard (the sd card directory should pop up on your computer screen) and download the root .zip file and save it to your computer. Ensure that the files are not being extracted.
  • Copy the root .zip file to the root of your sdcard and wait for it to transfer (not in any folders, just on the sd card itself). Select “unmounts sd card” in your device and select “Go Back”.
  • Select Install zip from sdcard and choose the root .zip file and once the file is updated successfully, you now need to wait for the device to get rebooted.
  • Once the device is booted successfully, download Root checker app to check whether the device is rooted or not and then install the superuser app from the Google PLAY Store.
Tip: If the device refuses to get rooted or say gets into the boot loop mode, you need to again follow the above procedure to root your htc incredible S device.
Do let us know in the comments section below just in case if you face any issue in the process of rooting. So, here you go you have now successfully rooted your device.
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Page generated in 0.53754 seconds with 11 queries
