Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 05-17-2014, 04:50   #1 (permalink)
shuvo007's Avatar
Member: 775086
Sonork: 100.1603609
Thanks Meter: 376
Thumbs up MTK Phones Engineering Mode
MTK Engineering Mode Start
Description:
This app supports the device that used the MediaTek chip.
It is possible to get a variety of device information.
ex. "Network Info" -> "RR 3G CsceEMServCellSStatusInd" for Check signal band .* This application Require MediaTek chip device *
* This application NOT Require ROOT *
MTK Engineering Mode is Hidden menu . This app can start this special menu .
Normal Engineering Mode by code is :
*#*#3646663#*#*
Or you can try this application.....
MediaTek MT6572 MT6575 MT6577 MT6582 MT6589 MT6592
MediaTek MTK6572 MTK6575 MTK6577 MTK6582 MTK6589 MTK6592
* Caution *
If your device not support MTK Engineering Mode function .
This application will not work .
Tested MediaTek chip device
S3 mini clone alps (MTK6577)
ZTE V807 V889S (MTK6577)
Mini One (MTK6572)
XK W450 (MTK6582)
Download
Play Store link
The Following User Says Thank You to shuvo007 For This Useful Post:
Old 05-21-2014, 08:18   #2 (permalink)
Member: 2186749
Sonork: pjhari
can we flash firmware of one mobile to anothr mobile wch are havng same mtk6572 chips?
Old 03-24-2015, 10:25   #3 (permalink)
MobileCarein's Avatar
Member: 2217517
Sonork: 1660095
Thanks Meter: 24
Iphone 6 copy mtk6572
If you lost your IMEI number, you can follow these steps:
1. Make Sure that your simcard is inserted! Deal *#06#, You`ll See INVALID! No Worries! Switch off your phone totally.
2. Wait for a while 2-3 minutes
3. Turn on your phone, once is opened, open the dialer, type *#364016# , You`ll see Engineering mode and then modify IMEI , HOW? » Under the section of Telephony —> GRPS —> At the top of the page, type this 352062067937502 —> Save by hitting "Write IMEI", It will ask for Reboot, You can say OK!
4. Once your phone is rebooted. You can deal again *#06# and see the imei is there!
5. Now You can make calls
try
Old 10-12-2015, 06:59   #4 (permalink)
Member: 2358261
Sonork: bruno
why my myphone agua rio fun v2 dont have an engineer mode?
because my phone has an invalid imei so i want to try this one to fix my imei
mtk 6571 is the chipset of my phone
Old 08-08-2016, 00:34   #5 (permalink)
Member: 2608820
Does anybody know how to access these function from the Android Tasker app? I would like to make some testing of the cell coverage and Tasker could be very useful for logging these parameters as a function of location.
Old 10-03-2016, 23:59   #6 (permalink)
Member: 2629100
thanks for the info bro, i will try it later....
Page generated in 0.18202 seconds with 9 queries
