11-12-2018, 18:22 | #1 (permalink) |
Junior Member Join Date: Nov 2018 Location: NIGERIA
Member: 2877021 Status: Offline Thanks Meter: 0 | Root All mediatek devices using sp flash tool Would be making a full detailed information on how to go about ROOTING using you Laptop by the use of SP Flashtool. For those who still don't know about Rooting i will plead you make a research or you visit previous post HERE, to know about it. For those also willing to take the step, be rest assured of a well detailed procedures to go about ROOTING. All required materials needed will be made available tomorrow as I begin the process tonight to get everything set and ready. Sorry for the long wait, guess its time to take charge of your Android.. Finally steps are ready. Tools: Download SP flash tool , SuperSu and Mediatek USB VCOM Driver Usefulness of Sp Flashtool Flashing to Android stock-ROM (scatter based) Flash Custom ROM (scatter based) Application for Fixing Bricked device. Advanced Memory testing and verifying. Read / Write parameters. Erasing / Formatting / Reset Your MTK based device. Requirements : A system or Laptop, stable USB cord, Drivers (Mediatek drivers) download above if you don't have, Scatter Files and Files to be flashed. Kindly visit Google and search for your Phone compatible Recovery files (Hovatek download is the best). When done proceed below. Unzip the Spflashtool and you should see SP flash tool application. Unzip the Recovery Zip file. Open the Sp Flashtool and click on scatter loading files, open and search for the unzipped Recovery folder choose on scatter file and open. After importing, you should see Recovery icon ticked on the screen. Make sure you use your device compatible Recovery scatter file. Click on download only and now you can click on Download at the top of the screen. When done you can now plug in your Android device. (Note: Device must be switched off). When successfully flashed you should see a green circled ticked sign. Kindly unplug your device and go into phone recovery mode by Pressing power button and + volume button together. When done you should see update zip from sdcard use buttons to select, then locate your SuperSu zip file and open it. You should see updated successfully.. You can now reboot your device! If you follow the steps accordingly am sure your device should be rooted. Check for all your apps and you should see SuperSu. Note: Make sure you know exactly what you are doing, if you have any difficulties or you don't understand a particular step kindly join our official telegram channel/group below and we could do some picture tutorials if needed. Try to get a backup of your files into your system in case anything goes wrong. I wouldn't be held responsible if your device gets bricked by this process. W w w . legitdroidphonehack . com |
11-13-2018, 19:45 | #2 (permalink) |
Freak Poster Join Date: Jun 2016 Location: jordan
Member: 2588864 Status: Offline Thanks Meter: 62 | hi sorry it is not clear how to Flash Custom ROM (scatter based)??? Application for Fixing Bricked device.??? Advanced Memory testing and verifying.???? Read / Write parameters.???? Erasing / Formatting / Reset Your MTK based device??? from where to get this ??? would you upload video for example of you method...thanks in advance |
