Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Android based Phones / Tablets > _Games and App for Android phones
Old 12-15-2012, 14:32   #16 (permalink)
Moderator
..::Nokian Care®::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
any body is there to help me installing android on Wespro NS721A
Old 01-05-2013, 18:56   #17 (permalink)
Member: 1273555
wespro ng 748 mini netbook cpu wm 8650 800 mhz 2gb ram 4 gb nand flash with wifi and windows ce 6.0 oprating system firmware link please help me
i am update software in sdhc card but not update please help me
Old 01-22-2013, 07:53   #18 (permalink)
Member: 1870786
rep.
Originally Posted by akhil_bbsr View Post
collect from me , in private
hi bro plz guide me how to flash
Old 01-23-2013, 06:46   #19 (permalink)
Member: 1454146
Sonork: 2010
NETBOOK NS721A
1.) Please buy USB cable having BOTH ends same as attached picture.
2.) Please download the attached software as mentioned below from the below link.
NS721A.zip
Extract all the files using the WINZIP or WINRAR software. You will get
1.) NS721A folder
2.) Update tool Sub folder name OTG driver & IUW software
3.) Please connect the one end of USB cable to the computer and another end at the Netbook side( where the charger and Lan connection port available). Do not connect the USB cable on the right hand side USB slots.
4.) Switch on the netbook. Your computer will detect the Netbook through USB automatically. You will get Green ARROW at the bottom of the screen near to digital clock. If The product is not getting detected follow step 5 or skip it if it already detected.
5.) If your netbook is not detected, It will ask you to supply the drivers. Click on “Select Drivers from Local disk ( Second option from the dialoug box)”. Locate the OTG folder which has driver ( The OTG folder is available in the software update tools folder.)
6.) Once connected properly, you will get a msg on netbook screen “ Communicating to computer”. Open the software folder NS721A Update tool IUW 1.2 software folder and run IUW.exe file.
7.) If everything is correct, You will see Green line at the bottom of the software ( Near Burn Icon). Please select below software from the NS721A folder. Please do not select any other option except below.
a. FOR KERNAL OPTION in ICW software: Click on BrowseNS721AUimage
b. FOR SYSTEM OPTION in ICW software: Click on BrowseNS721ASystem.img
c. FOR USER OPTION in ICW software: Click on BrowseNS721Auserdata.img
d. FOR RAM DISK OPTION in ICW software: Click on BrowseNS721ARamdisk.img
e. FOR RECVRD OPTION in ICW software: Click on BrowseNS721Aupdater.img
8.) After selecting all these options, click on burn. You should be able to see the progress on Netbook as well as on the computer screen (ICW software will show you the progress).
9.) Once process is completely done successfully, It will show “PLEASE PULL OUT OTG LINE and RESTART”. Remove the USB cable and restart your netbook..
10.) Wait till 7-10 minutes after the netbook is restarted.
Please follow the below process ONLY if it is not successfully updated.
1.) Pls switch off the netbook and connect it through computer using the USB cable.
2.) Make the software ready by selecting all the parameters. Remember to uncheck “SYSBACK “ option. It should be all blank.
3.) Swtich on your netbook, your normal computer will say” New hardware found” and will try to locate the drivers.
4.) Install the drivers manually using the manual process by selecting “OTG driver” folder.
5.) Once the drivers are installed correctly. Switch off the netbook and restart.
The Following 2 Users Say Thank You to srimantamobilecare For This Useful Post:
Old 01-23-2013, 06:47   #20 (permalink)
Member: 1454146
Sonork: 2010
NETBOOK NS721A
NS721A.zip
1.) NS721A folder
Old 01-29-2013, 07:08   #21 (permalink)
Member: 320105
wespro 10 inch netbook hang on wespro logo
Old 01-29-2013, 13:20   #22 (permalink)
Member: 1101680
wespro
sir i need wespro 786 flash file urgently
Old 02-13-2013, 07:43   #23 (permalink)
Member: 1697348
Sonork: mnchn
i can not start my wespro 7 netbook model no ns72A when I trying to start its just showing android... and freeze there plz any one know that how to solve this problem.
Old 02-20-2013, 12:22   #24 (permalink)
Member: 1772873
Arrow need Windows CE File for Wespro NS721A
Originally Posted by missime View Post
Really Very Good Post
But
I need Windows CE File for Wespro NS721A and
installation Steps .
Your Help Needed.
Old 03-02-2013, 08:18   #25 (permalink)
p.suresh's Avatar
Member: 482019
yes working for me thanks
Old 03-06-2013, 07:30   #26 (permalink)
Member: 627933
Thanks verry much............
Old 03-10-2013, 10:07   #27 (permalink)
Member: 1897405
Post ns721a laptop hangs after logo
hi,
many thx fr the software. i downloaded thw sw & followed yr instructions.
bt now after the logo it goes to 2nd screen and the word "ANDROID" is displayed & it gets stuck at this point
wud u b able to suggest any remedy.
also my laptop label says android 2.3 os
Old 04-02-2013, 17:34   #28 (permalink)
Member: 1910186
Sonork: djanil1987
Thanks 4 dis tips....
Thanks a lot
Old 05-10-2013, 12:26   #29 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
Originally Posted by choclate_ View Post
Sorry for yesterday i can't reply to you.but here is solution for your laptop.post result after done
Wespro 7 Inches Mini Laptop with Wifi-Model No.N-721 hang on logo solve
cant update wespro ng748 cpu 8650 windows ce based ?????
how to install jetro 2.95 gsnbhagawan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 03-24-2001 13:56
how to install jetro 2.95 gsnbhagawan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 03-19-2001 21:43
how to install jetro 2.95 gsnbhagawan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 03-17-2001 12:39
Is there any possibility to install the Russian language into NOKIA 8210? Jurik Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 09-10-2000 00:49
can't get pc datasuite to install linda Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-17-2000 22:21
Page generated in 0.92002 seconds with 12 queries
