12-15-2017, 11:14 | #1 (permalink) | |
Crazy Poster Join Date: Dec 2017 Location: USA
Member: 2789358 Status: Offline Thanks Meter: 13 | What Is Freedom APK? Freedom is a android app. Freedom APK Application use Some technique and increased game premium features. It is completely free app and work with thousands of mobile games. All the android lovers and also the game lovers like premium features and also new levels, stages in games and apps. But for this it need to pay. So every one can’t afford this as it needs to pay some cash with credit card. Now don’t worry about that, with Freedom app anyone can make in-app-purchases for free. It uses a fake credit card to make the payments. Unlock new levels, buy more gems and coins, go to new stages all now 100% free with Freedom app. How to use Freedom Apk
12-19-2017, 10:05 | #2 (permalink) |
Member: 2789358 Status: Offline Thanks Meter: 13 | Freedom APK 1.8.4 Download Freedom APK Download – Latest Version Officially Release Using Freedom App, you will be able to get coins, gems and other resources free for which you have to paid earlier. This app will be able to bypass in-app purchases in most of the Android apps and games. Get the full versions of any game or app available in your android phone. It is supported by every Rooted Android phone with Android version grater than Gingerbread (Android 2.3). Updated regularly so that it supports most of the android apps. It uses multiple patches and mods to exploit Android apps and games. It can remove ads from most of the installed apps in your smartphone. Freedom APK 1.8.4 Download previous versions Minimum Requirements To Install Freedom Apk: Before you go through the installation procedure of Freedom apk in your android phone, it is necessary that you should check all minimum requirements required by the app. You need to have at least:
Steps To Install Freedom Apk In Your Android Phone: Step 1: First of all, Enable Unknown Soonces option from settings. (Open Settings -> Security -> Unknown Sources) Step 2: Now, Download Freedom APK in your android from below download button. (You can download it on your Computer as well and later you can transfer it to your android phone via USB Cable). Now in further steps, we will assume that you have Freedom apk file ready in your smartphone. Step 3: Open any File Manager in your smartphone (If you don’t have pre-installed File Manager app in your phone, then you can install any other third party file manager app like ES File Explorer). From File Manager, Go to the Downloads folder or any other folder to which you have downloaded APK file of Freedom app. Step 4: Open the Freedom Apk file and click on install button now. Step 5: In few seconds, Freedom app will get installed in your smartphone. So you have successfully installed Freedom app in your Android phone. Learn How To Do In-App Purchases with Freedom Apk? So, follow below steps to use Freedom app properly in your android phone. Step 1: First of all, Open the Freedom app in your android phone from the App drawer. Step 2: Now, you will get a pop up asking for root permissions. Grant Root permissions to the app by clicking on Grant/Allow button. Step 3: Now, you will be able to see the list of all the pre-installed apps in your android smartphone. Step 4: Select any Android app from the list in which you want to do in-app purchases for free. For example – Subway Surfers or Temple Run or PicsArt. Step 5: Click on app name and wait for few seconds now. Step 6: Once, your required Android app is launched go to the store of that particular app (where you need to bypass the in-app purchases). Step 7: Just click on Buy button now for every in-app purchase. Repeat the above steps for every android app in which you want to do free in-app purchases. Have you got No Connection error in Google Play Store while doing in-app purchases? Don’t worry, it is not happening with you only. It is a very common error which many Freedom app users face. Don’t worry. You can easily fix this error by following below steps carefully. So let’s start. Step 1 - First of download any file manager in your android which allows you to edit system files like ES File Explorer. Step 2 - Now, Go to root directory of your android phone & look for a folder named as system. Step 3 - Open etc folder and find hosts file there. Step 4 - Edit that hosts file and paste below code in it. 127.0.0.1 localhost Step 5 - Save this file. Open Application Manager from settings of your android phone now. Step 6 - Select Google Play Store from the list and click on Clear Data button. Step 7 - Reboot your android phone now. |
