Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 02-03-2009, 19:32   #1 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
8100 Disassembly
Disassembly of BlackBerry 8100
Important! Please be sure you have the proper tools for this disassembly, as well as a dust free environment you can create. I recommend that latex gloves be used to prevent fingerprints from showing on the lcd and other visible areas. Be sure to remember the dissasembly steps, as you will need to put it back together once you are done.
Tools Necassary
T-6 Driver, Prying Tool
Step 1; Remove Battery Door
Step 2; Remove Battery
Step 3; Remove Bottom Cover
Use the Prying tool, to slowly remove the bottom plastic cover to expose the screws below, unclip the two top clips, and then pull down, this is the most difficult part of disassembly as this piece is very fragile and easy to break. After doing so, unscrew the bottom screws, and the top screws as well (4 in total thus far)
Front Piece Removed
Step 4; Remove Side Covers
Use the Prying tool once more, remove the side covers, two clips per side, per piece, these are easy to get off, but be very careful to not break the clips.
Step 5; Remove front Cover
With the sides removed, you can now remove the front cover, and expose the lcd and keypad
Upclose Shot of Ball Mechanism
Step 6; Remove Rear Cover
This exposes all of the internal workings of the BlackBerry 8100
Step 7; LCD Removal
The LCD is held on using double sided tape, and seems very thin and flexible. I highly doubt that this lcd is user replaceable (at least with ease) like other BlackBerry LCD's are.
Wear your Gloves!!
This ensures that your lcd is left fingerprint free, and nothing is damaged internally from skin oil.
Instructions by "Tom Glogowski"
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Disassembly Disassemble movies Nokia Cermis Nokia Hardware & Hardware-Repair Area 28 02-03-2011 14:31
my black berry 8100 is not unlock (Answered) ravin j tejura MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 11 04-08-2010 15:05
Disassembly Disassemble movies Sony Ericsson Cermis Sony Ericsson Hardware Repair Area 14 05-29-2009 01:59
Disassembly Disassemble movies HTC Qtek Search Cermis HTC & PDA WM( With Touchscreen) 0 09-15-2008 13:55
Page generated in 0.19228 seconds with 11 queries
