BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
11-24-2010, 06:14 | #48 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | no need to write new password only after wipe when ask new pas sward connect set with cable and run desktop manger and press application loader .......applications will start reading and mobile screen will show 2 ways connecting icon now press back button from phone you will see a policy message in background the new password box.....that's done ....now power off phone and now you can use phone with out emergency call error and with out any password |
07-07-2011, 01:39 | #49 (permalink) | |
Junior Member Join Date: Jul 2011
Member: 1611351 Status: Offline Thanks Meter: 0 | i am using vista, cant find any regedit with path shown help with vist info please any help with vista, need to remove it policy on 8700. 4.2 software, did wipe and reloaded software. still no sms Quote:
07-08-2011, 18:07 | #50 (permalink) | |
Member: 1611351 Status: Offline Thanks Meter: 0 | it removal instruction dont match my file location or regedit paths I am using blackberry desktop on vista and BB version number is 6.1.0.35 when i run regedit the path for policy manager is not there. C:\Program Files\Research In Motion\BlackBerry Desktop is the path were desktop is installed. can i still use the policy bin file or is there a dll file i need to place in modules. i ask this because i see a dll file for policys. my blackberry is 8700c. it was on a enterprise server before. I have wiped and reloaded old version and lasted version. still cant get ride of it policy. cant get sms opitons. can you help? Quote:
09-24-2011, 12:21 | #51 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1660817 Status: Offline Thanks Meter: 0 | No effect on the BB [QUOTE=::.::RAMJAN::.::;3496786]you need to remove IT policy , here is the working solution how to remove IT policy tested by me many times Hi,Thank you for this tuto but it doesn't work with my BB 8820 ver 4.5.0.69 BB Desktop Software is not installed in the default directory but I changed commands and path according to that. My XP pro Register doesn't containHKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager but I created it : Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\Software\Research In Motion\BlackBerry\PolicyManager] "Path"="P:\\Program files\\BlackBerry\\policy.bin" The double anti-slash "\\" in path seems to be ok, I got the same in other path. They only appear when RegEdit export keys, noting like this in the original keys. I connect my BB, launch BB Desktop Sofware, enter code as asked. 30s later connection is established but old policy is still present and active. Any idea ? |
11-07-2011, 16:09 | #53 (permalink) | |
Junior Member Join Date: Nov 2011
Member: 1685116 Status: Offline Thanks Meter: 0 | still not :( Quote:
I did exactly how you said and i don't see Policy manager which suposed to be here : HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Please help me Thanks for reading this Yvano | |
10-17-2012, 10:47 | #54 (permalink) |
Freak Poster Join Date: Jul 2007 Location: I N D I A
Member: 541724 Status: Offline Sonork: 100.1604043 Thanks Meter: 73 | What is JL_Cmder? JL_Cmder stands for JavaLoader Commander. JavaLoader is a command line tool provided by BlackBerry. JL_Cmder simplifies accessing the most commonly used JavaLoader commands. Update 10/14/2011: v1.9.4 Whats new in v1.9.4? Updated JavaLoader.exe file so it works with OS 7 devices. NOTE: This is most likely the last update to JL_Cmder as the next handheld OS is supposed to be BBX. Update 11/21/2010: v1.9.3 Whats new in v1.9.3? Now works with Windows 7 and on 64bit OS. Fixed verbage on a couple of screens. Updated JavaLoader.exe. No functionality changes. Fixed 1.9.2 install issue. Update 11/20/2010: v1.9.2 Whats new in v1.9.2? Now works with Windows 7 and on 64bit OS. Fixed verbage on a couple of screens. Updated JavaLoader.exe. No functionality changes. Are there any system requirements? Yes. You must install BlackBerry Desktop Manager or BlackBerry USB and Modem Drivers. Both are available from the BlackBerry website. What can JL_Cmder do? Below is a brief overview of the available commands. deviceinfo - Displays information about the handheld. eventlog - Retrives and displays the handheld event log. screenshot - Takes a picture of the handheld screen. (OS 4.0.2+ required) wipe - Erases the handheld OS. Not really, but that is the simpleist way to explain it. After using the "wipe" command the device will be completely inoperative until the OS is reinstalled. (Error 507 will be displayed on the device) resettofactory - Removes the IT Policy from the device and wipes the device of personal data while leaving the OS installed and usable. (OS 4.3+ required). NOTE: If you want to use an unlisted JavaLoader command select Command-Line Usage from the menu. This will display JavaLoader help information including syntax and all available commands. Installation Instructions Download JL_Cmder. Extract executable. Double-click on executable. Vista Users: Right-click on executable and select Run As Administrator. NOTE: Do NOT use JL_Cmder to "wipe" your device if you are just wanting to wipe your personal data from the device and leave it as it was out of the box. If you use the "wipe handheld" option in JL_Cmder your device will be rendered useless (Error 507) until you reload the entire OS. If you just want to wipe your personal data but leave the OS you can use the "wipe handheld" in the Options >Security Options >General Settings Menu on your device or, if your device has OS 4.3 or higher, use the "resettofactory" command in JL_Cmder. The only difference between the "wipe handheld" in the Security Options on the device and "resettofactory" in JL_Cmder is that "resettofactory" also removes the IT policy on 4.3 and higher OS devices. Do NOT use JL_Cmder to wipe your device if your device is working fine and are simply attempting to upgrade your OS and you can't get the OS to load or be recognized by Desktop Manager or Loader.exe. Doing so will most likely render your device useless until you find the root cause of why the OS will not load to the device. Generally, this is caused by not deleting the vendor.xml file(s) or USB issues with the PC. |
05-14-2013, 15:51 | #55 (permalink) | |
Freak Poster Join Date: Jan 2012 Location: jamaica
Member: 1713576 Status: Offline Sonork: 160290 Thanks Meter: 5 | it policy Quote:
it didnt work for 8310 | |
01-24-2015, 19:03 | #56 (permalink) | |
Freak Poster Join Date: Jan 2014
Member: 2112019 Status: Offline Thanks Meter: 8 | Ravi Sharma Quote:
BlackBerry 8700g Sorry, Only Emergency Calls Are Allowed. | .:Towhid:. | BlackBerry (RIM) | 5 | 08-24-2014 10:36 |
Blackberry 8800, sorry, only emergency calls are allowed | Mobile-Expert | BlackBerry (RIM) | 6 | 06-26-2012 08:39 |
BB; sorry only emergency calls are allowed | babyelephantt | FuriousGold | 20 | 07-06-2010 23:15 |
Sorry,only emergency calls are allowed | ZoHaiB_(FoneGSM) | FuriousGold | 2 | 08-22-2007 12:34 |
Help:T-mobile BB 7290, Only emergency calls are allowed | saltedfish | HTC & PDA WM( With Touchscreen) | 0 | 09-09-2006 19:38 |
