BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
01-19-2013, 08:31 | #1 (permalink) |
Registered User Join Date: Jul 2012
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | 8520 FOS ok but (OS Installed only Blink once) I have FDRROOT file that contain IMAGE.BIN (13.0 MB). i trying to write thru cfp but i cant set correct address. what this file for? Code: Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. G:\BlackBerry\CFP>cfp -u info Connecting to Bootrom: Connected [ Uploading RAM Image 0x8002170C ] [############## 100 ##############] Device Info: PIN: 2912a0b3 Bootrom Version: 5.6.0.20 Hardware ID: 0x8C000F03 RIM BlackBerry Device HW ID Override: None Supported Bands: 0x000F Metrics Version: 6.9 Build Date: May 13 2009 Build Time: 13:25:04 Build User: rdagg Security: Enabled Supported Options: 0x00000003 Drivers: 0x00000004 Processor: 0x00000001 LDR Blocks: 0x87FEB474 Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A HWV: Board Revision 0001 - 0x07 CPU Version 0002 - 0x32 SW Compatibility 0003 - 0x01 POP Revision 0004 - 0x25 Power Mgt Hardware 0007 - 0x27 POP Security 000B - 0x01 Device variant 0042 - 0x02 Mem Config Table (ver 1.24): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-1983 OS NV: blocks 1984-2000, total 17 CRC: 0x523997A7 Flash: Number of chips: 1 Flash ID: NAND blocks 0-2020 Device ID: 68 Vendor ID: 236 Version ID: 0 Total Size: 252.6 MB Memory Map: NAND Blocks: 2021 * 128 Kb RAM Base: 0x80000000 IRAM Base: no IRAM! OS Range: 2 - 85 File System: Memory Map: 86 - 1983 Sectors: 1898 Branding: VendorID: 613 OS Version: 4.2.0.14 Hardware ID: 0x8C000F03 RIM BlackBerry Device Supported Bands: 0x0000FFFF Metrics Version: 3.16 FS Code Version: 10.0.0.0 FAT Code Version: 2.18 Package Version: "" Build Date: May 12 2010 Build Time: 16:15:32 Build User: SCM SV Number: 1 OS Address: 0x80000000-0x80A6469B App Start: * No Application Linked * Companion Binary: 0.0.0.0 RAM usage: 0x874FFFFC-0x87FFFFFC IRAM End: 0x4009E378 DSP ROM2 Address: *not present* OS Extended Addr: 0x809472E8 LDR Blocks: 0x80A2EB50 API Checksum: 0x00000000 JumpTable (<3): 0x80000310 JumpTable (>2): 0x80001F74 Radio Code: Orpheus radio code linked OS API Version: 109.40 STP Protocol Ver: 5.203.1 (factory OS) HWV: Board Revision 0001 - [0x01 - 0xFF], 0x01 POP Revision 0004 - [0x00 - 0xFF], 0x01 CPU Version 0002 - [0x00 - 0xFF], 0x01 SW Compatibility 0003 - [0x00 - 0x01], 0x01 Power Mgt Hardware 0007 - [0x24 - 0xFF], 0x01 Version Table: OS API Version: 109.40 STP protocol version: 5.203.1 BlockFS API Version: 10.0.0.0 USB driver version: 02.01 Bugdisp RTAS key: 1.0 STP RTAS key: 1.0 NVSIG RTAS key: 1.0 FAT FS Version: 2.18 Block map version: 2.15 WLAN radio version: 2.5.0.73 Kernel Version: 1.11.0.272 Hardware ID: 0x8C000F03 RIM BlackBerry Device Metrics Version: 1.1 Build Date: May 12 2010 Build Time: 15:18:53 Build User: SCM Done. G:\BlackBerry\CFP>cfp -u write 0x00020000 8520-IMAGE.BIN Connecting to Bootrom: Connected [ Uploading RAM Image 0x8002170C ] [############## 100 ##############] --> Command Range: 0x00020000-0x00020068, Allowed Secure Range: 0x00000002-0x000 00055 or 0x00000056-0x000007BF Operation/parameters invalid on secure device! Connecting to Bootrom: Connected [ Uploading RAM Image 0x8002170C ] [############## 100 ##############] --> Command Range: 0x00020000-0x00020068, Allowed Secure Range: 0x00000002-0x000 00055 or 0x00000056-0x000007BF Operation/parameters invalid on secure device! |
01-20-2013, 14:38 | #2 (permalink) |
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | only show red light once but keep restarting (1). i have another 8520 and it's ic flash problem. try to reball and problem solved. but i have a question regarding address to write image.bin for 8520 |
